Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 04-30-2004, 12:09 PM   #1
ryan_lobo
Member#: 13437
2001 Forester
Sierra Gold
Default Oxygen sensor
Hi !
Im a little confused about the oxygen sensor, seems like there are 2 in the forester the "front" and the "rear", when subaru did a recall on the 2001 forester O2 sensor, which one did they recall ? My dealer says they replaced the oxygen sensor (they did not say which one) and I want to chack if they actually replaced it or not.
Also is there a way to check the functionality of the sensors with a multimeter ?
Thanks !
Ryan
ryan_lobo is offline   Reply With Quote
Old 04-30-2004, 12:47 PM   #2
SCutchins
Member#: 59209
2004 Forester XT
Cayenne Red Pearl
I think that your sensors are okay as long as your check engine light isn't on since they are constantly monitored. If you happen to know someone with an OBD-II reader, especially one with "I/M Monitors" (Inspection/Maintenance) you can have them check their status to make sure they are ready.
I have such a reader, if you want to take a short drive to Centreville I would be more than happy to check your car out with the reader, only takes a minute.
SCutchins is offline   Reply With Quote
Old 04-30-2004, 12:51 PM   #3
ryan_lobo
Member#: 13437
2001 Forester
Sierra Gold
My CEL light came on and reset itself so I know there is an intermittent problem, the question is did the dealer fix it.
I used to be in the DC area, I just relocated to Dallas TX so I dont know anyone here.
Thanks for the info
Ryan
Old 04-30-2004, 02:49 PM   #4
kendo
Member#: 24829
2000 Forester S 4EAT
Just the front oxygen sensor.
-Kendo.
kendo is offline   Reply With Quote
Old 04-30-2004, 08:41 PM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Forester
The front sensor has input in how the car runs (A/F mixture) the rear one is just telling how the cat is working but has no bearing on the performance of the motor. I had a front one go bad and eventually throw a CEL, my car ran crappy and my MPG's went way down too.
Peaty is offline   Reply With Quote
Old 03-07-2006, 05:08 PM   #6
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Question
Originally Posted by ryan_lobo
Hi !
Thanks !
Ryan
OK...this is an old post ..BUT....I never knew that the 01 Forester had a recall on the O2 sensor.
I bring this up because I just threw a CEL and it points to the O2 sensor. Can I get it replaced at a Subaru dealer under a recall?
lakepop is offline   Reply With Quote
Old 03-07-2006, 07:45 PM   #7
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
OBE.............I think I have answered my question.
Perhaps WXW-80 dated 01/2001 will provide what I need when I go and deal with the Suby dealer.
Will let you know how it goes.
Old 03-07-2006, 11:22 PM   #8
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
If you PM me the last 8 digits of your VIN number, I can tell you if the recall applies or is open on your vehidle (it may have already been done.)
RexyGirl is offline   Reply With Quote
Old 03-07-2006, 11:33 PM   #9
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
If it was already done you will have to pay for the sensor (unless it is within 1 year)
Also have the dealership check and see if the ecm is eligible for a reflash (covered 8/80k)
Old 03-08-2006, 08:14 AM   #10
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Thumbs up
Rexygirl......sent you a pm.....thanks again.
hondaslayer.......I don't think my vin number fits that....but I'll double check with dealer.
Again I appreciate the inputs.....it's what makes this place special!
Old 01-16-2008, 12:03 PM   #11
Kimithy
Member#: 169215
Angry How can I check if my car applies for recalls?
I've looked everywhere and can't seem to find out how I can check to see if any of the Forester recalls apply to my car. Any help on this one?
Feeling a bit duped, since a week after I bought my '01 Forester S Auto and after $800 worth of repairs to fix problems not visible on purchase, the check engine light came on and I'm suspecting an O2 sensor issue (gas mileage is barely 14MPG!?!). Hoping that some of the recalls apply, since I'm really having problems with this car. So far (this is after 2 days of driving it):
Leaking radiator
Brakes replaced (they were at less than 10%)
Head Gasket leaking
Car noticeably shaking/vibrating at idle
Jerky shifting between first & second
TONS of wind noise from bad seals
CV joint issue
Dome light dysfunctional
Check Engine Light just popped up
Most troubling - EXTREMELY BAD GAS MILEAGE - 12-14MPG
Is this normal? Ugh - I just got this car and already it's been in the shop more than I've driven it Help!
Kimithy is offline   Reply With Quote
Old 01-16-2008, 01:42 PM   #12
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Originally Posted by Kimithy View Post
Leaking radiator
Head Gasket leaking
CV joint issue
You can take your car to an auto parts store and get the exact CEL codes pulled, and then you can be certain whether or not it's an O2 sensor issue. If you are getting serious shaking/vibration you may have other issues, possibly serious. If your head gaskets are leaking, you are on track for some more expensive repairs that will need to be performed soon.
If you got the car from a dealer it may be worth trying to take it back and get a different car. With leaking fluids you may not even pass a safety inspection if your state requires one.
jey is offline   Reply With Quote
Old 01-16-2008, 01:43 PM   #13
pleiad7
Member#: 71056
MY04 Forester XT
wow, that kind of ****ty mileage is definitely not normal! Did you pull the CEL code yet?
The wind noise and the jerky 1-2 shifts are somewhat common, but it sounds like your Forester has been abused or not properly maintained with this many problems. How many miles on it?
pleiad7 is offline   Reply With Quote
Old 01-16-2008, 01:57 PM   #14
Kimithy
Member#: 169215
Angry Engine problems/O2 recall
Not quite 90, thinking it was definately poorly maintained. I'd heard that most of the problems I've been having (head gasket, Check Engine Light, O2 sensors, etc) were plaguing the early 00's Foresters (didn't they do a recall based on the leaky heads, wheel bearings, etc as well as the O2 sensor?) - any idea on how to find out whether or not I qualify for the sensor recall?
Response to dealer questions - I bought my car from an independent dealer (not Subaru), so not sure how repairs work in that case - if I qualify for the recalled sensor, I'll have to have a Subaru dealer replace, correct? Arg, never this many problems with a car before.
Front Oxygen sensor AKA air/fuel sensor swap out Peaty Tribeca Forum 0 02-20-2010 05:36 PM
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 12:49 PM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 03:16 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 02:09 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-21-2007 12:56 AM
