Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 04-30-2004, 10:25 PM   #1
Dr. J
Member#: 31009
2002 impreza wrx
Default HELP!!! my 1.8 keeps stalling
recently my 95 1.8 keeps stalling at an idle and doesn't want to restart. it takes several minutes of trying to get it to turn over before it finally starts. i feel a hesitation when i'm idling so i try to keep the rpm's a little higher(so it won't stall). i changed the plugs and wires and fuel filter and that didn't work. any ideas?
jay
Dr. J is offline   Reply With Quote
Old 05-01-2004, 12:00 AM   #2
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
possibly clogged or bad IAC (if your car has one?). responds well to cleaning with carb/throttle body cleaner - reponds quite poorly to disassembly though - delicate and tricky to keep calibrated.
1 Lucky Texan is offline   Reply With Quote
Old 05-01-2004, 11:29 AM   #3
Dr. J
Member#: 31009
2002 impreza wrx
anyone else?
Old 05-01-2004, 11:48 AM   #4
Alpha_32
Member#: 35876
2008 Legacy GT SpecB
Grey
maybe ur battery, go to some place that checks the charge of ur battery...i had that problem a little while ago
Alpha_32 is offline   Reply With Quote
Old 05-02-2004, 09:48 AM   #5
Matt
Allergic to turbos
Member#: 181
2009 Forester
Crank angle sensor. Shouldn't cost more than $80 from a Subaru dealer and takes about 15 minutes to change.
I had a '95 1.8 AWD sedan with similar symptoms. My car did everything but the random stalling.
This was a known problem on many '95 and '95 Imprezas and some Legacies.
Hope this helps.
Matt is offline   Reply With Quote
Old 05-20-2005, 10:49 AM   #6
ATXImpreza
Member#: 18565
1995 Impreza
Red
I have a MY95 1.8ltr also... mine was doing the same thing awhile back and my mechanic, whom used to work for AustinSubaru years ago, resolved mine as the first signs of a burned valve... haven't cracked the motor open to see if that was the exact problem though... we just swapped the motor for now since I had another MY95...
ATXImpreza is offline   Reply With Quote
Old 05-20-2005, 02:10 PM   #7
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
umm fuel filter maybe
stickfiguredanny is offline   Reply With Quote
Need Help With My 1.8!! 95imprezagc8 Newbies & FAQs 7 07-22-2009 10:50 AM
L 1.8 Random stalls detailed problem PLEASE HELP xreign Normally Aspirated Powertrain 37 03-08-2009 04:56 PM
93 1.8 Impreza, stalling/engine codes??? 84cj Normally Aspirated Powertrain 11 11-20-2008 07:49 PM
HelP!!! my security light keeps blinking wrichiex_sti Car Audio, Video & Security 13 07-01-2004 02:50 AM
Help with 1.8 and 2.2 Imprezas brchco12 Newbies & FAQs 2 07-29-2002 01:50 PM
