Old 05-01-2004, 12:28 AM   #1
Jaz_rs
Member#: 60800
00 Impreza RS
BRP
Unhappy Clutch pedal not coming back up
I have an Exedy clutch and it has been working wonderfully for the past 10 months. But now the clutch pedal won't come back up unless I use my foot to bring it up. Other then that the clutch works fine.
What is the problem and what is the solution?
Thanks.
Jaz
Jaz_rs is offline   Reply With Quote
Old 05-01-2004, 01:40 AM   #2
stiturbo
Member#: 48400
99 impreza GC8
black
thats wat happen to my car.. they just did the swap and after startin it my clutch isn't coming up.. they said they have to bleed the clutch, and there was something else that needed to b replace.. waiting for the part right now.. just order it from the dealship.. cost about 60
stiturbo is offline   Reply With Quote
Old 05-01-2004, 07:18 AM   #3
Jaz_rs
Member#: 60800
00 Impreza RS
BRP
So something would be wrong with the hydraulic system.
Any other possible cause?
Old 05-01-2004, 10:42 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
It's the clutch slave cylinder if it's not air in the system.
Brian
Old 05-01-2004, 11:09 AM   #5
SAINTSOFSPEED
Member#: 40596
03 WRX
MBP
Post RE:
I agree. I had to replace my slave cylinder. I did the following: Check your pedal, bleed the system, check slave cylinder.
If either of these is the cause than you will find it in that direction.
Greg
SAINTSOFSPEED is offline   Reply With Quote
Old 05-01-2004, 12:06 PM   #6
Z1 Performance
Member#: 9327
agree with brian - if the car ahs around 40k, more than likely the bad slave
Z1 Performance is offline   Reply With Quote
Old 05-01-2004, 11:53 PM   #7
Jaz_rs
Member#: 60800
00 Impreza RS
BRP
That's it, the slave cylinder is shot. Will be replaced. Everything else it fine.
Thanks for the help.
Jaz
Old 05-03-2004, 12:44 AM   #8
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
Ok...the other night I was driving my car pretty hard.....I have recently changed to an Exedy Flywheel and Clutch. Once I had been driving for a few minutes the clutch went to the floor and didn't come back up until I put my toe under it and kinda popped it up.....like it has a spring that didn't engage but then did once my foot was under it.....I have just under or at 21,000 miles. Is this similar.....I didn't bleed my clutch when I replaced it...should I have done this/do it now just because I replaced it?? Thanks
Impulsivegoat23 is offline   Reply With Quote
Old 05-03-2004, 01:04 PM   #9
Jaz_rs
Member#: 60800
00 Impreza RS
BRP
No need to bleed or change the fluid when changing the clutch or flywheel. My clutch would engage but the pedal would not come back up more then an inch maybe. In the past year, the clutch pedal stayed to the floor at least once that I can remember. Worked fine after that until now. Maybe it is a first sign of the slave cylinder going? I don't know.
Jaz
Clutch pedal touching the back? chrisdeaner Transmission (AT/MT) & Driveline 3 07-21-2009 07:17 PM
Help! Clutch Pedal Not Working! slprwgn Transmission (AT/MT) & Driveline 6 04-14-2008 01:27 PM
Help! Rebuilt my motor and now clutch pedal not coming up? mokujin22 Transmission (AT/MT) & Driveline 4 07-24-2007 08:44 AM
Clutch pedal feel doesnt spring up "quick" bren wrx Transmission (AT/MT) & Driveline 1 09-29-2006 09:44 AM
clutch slave not coming out? shadymilkman129 Transmission (AT/MT) & Driveline 4 06-19-2006 09:46 PM
