Old 05-01-2004, 03:16 PM   #1
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Default Engine Studs
I'm in the middle of putting new headers on and have run into a problem. The new stubs for the headers don't seem to tighten real well. They don't have a head to use so hand tightening is really all i've got. Am i missing something??
Brindor2.5 is offline   Reply With Quote
Old 05-01-2004, 03:21 PM   #2
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
The studs should have 2 sides: one that tapers on the end and is a little longer, then a small unthreaded gap, then a shorter blunt threaded side. You screw the shorter side into the block until you get to the unthreaded part. Then you just screw the nuts onto them when you install the headers. IIRC, you basically just screw them in until it starts to get difficult and then stop. You don't want to try and tighten them too much cause you could damage the threading in the block. The old ones shouldn't have been in there too tight either.
bigdweeb is offline   Reply With Quote
Old 05-01-2004, 03:38 PM   #3
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
ok so i just hand tighten them on? Oh and i have two studs that i can't get out. Is there a trick for me to try?
Old 05-01-2004, 04:35 PM   #4
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
I couldn't budge any of the nuts when I was doing my headers. I soaked them all with PB Blaster and kept working on them slowly until I got them free. I actually removed all 6 studs from the block... I only got the nut free from the flange, not the stud. So all 6 studs came rigtht out for me once I broke the rust.
If you cannot get the nut free from 2 of the studs, I would try BP Blaster (any auto supply place should have it) and slowly work on turning them until they break free. If you just cannot get the studs out of the engine block, I'm not sure. You could probably back 2 nuts against one another and use an open ended wrench to turn it out, maybe using some PB Blaster to assist. But if the threads are in okay shape on those, you can just reuse them.
Good luck.
Old 05-01-2004, 07:20 PM   #5
SjYankee006
Member#: 33943
Sorry I don't have anything constructive to add, but while we're on the subject... Does anyone have the part # for the header bolts/nuts? I'd probably like to replace mine when I do my headers in a couple weeks as they are probably all rusted to hell. And any other tips for a successful header job? thanks
SjYankee006 is offline   Reply With Quote
Old 05-01-2004, 10:31 PM   #6
obyone
Member#: 16523
....I think I do. give me a few.
[edit]
Crap! I just had two header bolts replaced at my dealer but it seems they didn't charge me for them so I don't have a part number.
............. wait that's a good thing isn't it?
BTW...I know for sure they are roughly $5 a piece.
obyone is offline   Reply With Quote
Old 05-02-2004, 08:16 AM   #7
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
I looked back at my invoice from when I did this... it looks like they charged me for the 6 nuts but not the studs
So the P/N for the nuts is 902370029
Just go to the dealership and ask for the header studs and nuts... they should know what you are looking for.
Old 05-02-2004, 06:20 PM   #8
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Got the old studs out and put the new ones in. Used the two nut trick, worked good. So i've got the new headers on (wicked awesome) but i've got another question. When i installed i tightened the nuts on the studs, then just cus its the way that i am, after driving around for a while and letting the car cool down i checked them. They we not real loose but i could tighten them, is this normal?
I thighted then and will check them again tomorrow.
Old 05-02-2004, 06:28 PM   #9
That Guy
Member#: 23212
2002 Impreza RS
Probably just your gaskets smooshing a little. No worries.
That Guy is offline   Reply With Quote
Old 05-03-2004, 10:25 AM   #10
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
*nod*
It's not a bad idea to check things to be on the safe side. Just make sure everything is torqued properly and you should be good to go. The magic number is 22.4 3.6 ft-lb for those nuts.
ej257 engine feeler C-DAY Engine/Power/Exhaust 38 06-12-2010 02:18 PM
GF8 STI block of the engine Mirone Car Care & Detailing 2 06-02-2010 08:35 AM
Exhaust to engine stud torque? pieces Newbies & FAQs 9 11-27-2008 04:11 AM
***Innovative Tuning crate engines, head work, NEW ARP Head Stud Kits, and MORE!!!*** Innovative Tuning Engine/Power/Exhaust 17 07-22-2008 03:33 PM
Engine to bellhousing studs eqlized_aero Transmission (AT/MT) & Driveline 5 03-24-2006 11:35 AM
