Old 05-01-2004, 05:48 PM   #1
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Exclamation Holy Overboost, Batman
So I decided to try and make a boost controller. $3 in parts later I was ready. Install, easy. 12 psi in 2nd gear... EEEK!!! 14 psi in 3rd.... YIKES!!! I didn't try shifting to 4th.
back to the drawing board
Old 05-01-2004, 06:31 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Sounds like you need to cut a few coils off that spring.
Old 05-02-2004, 02:32 AM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I think I have a MBC in the garage I can give you if you pay shipping.
wcbjr is offline   Reply With Quote
Old 05-02-2004, 03:01 PM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Charlie, is that the one we hooked up at FIS last year? I forget, was it a bleed type or just a bearing & spring?
Either way, let me know how much shipping is to Wichita Falls, 76308
Old 05-02-2004, 11:30 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
That's the one. I believe I still have it somewhere. I see if I can locate it tomorrow.
Old 05-03-2004, 08:15 PM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
SWEET!!! Just let me know the cost of shipping. I PMed you my address yesterday.
muahahaha
BTW, please someone smack me for helping my buddy tune his WRX... his 04 is faster than a raped ape with just the 3/16th mod, silencer and axle-back removal When will I learn
Old 05-03-2004, 10:09 PM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Yah I think Charlie's is that little Dawes Device...those things work quite well.
Graham
Graham is offline   Reply With Quote
Old 05-04-2004, 12:43 PM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
No luck. Will keep searching.
Old 05-04-2004, 06:52 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Dawes' device was my plan "C". Plan "B" was to remake what I had with larger fittings to reduce the effect of a restrictor. Dawes' devices will work but they're trickier to make from scratch... then again, if Charlie finds his I won't need a plan "B" or "C"
Old 05-07-2004, 07:56 AM   #10
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
What turbo are you using? What wastegate?
Old 05-07-2004, 12:13 PM   #11
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
EBC?
HOK is offline   Reply With Quote
Old 05-07-2004, 04:06 PM   #12
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
VF10, stock internal WG.
Old 05-14-2004, 09:17 PM   #13
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Eureka! Found the Dawes Device.
Old 05-15-2004, 01:17 PM   #14
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
SWEET!! Charlie, PM me your phone number so we can work out shipping!
Old 05-19-2004, 07:53 PM   #15
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
And the verdict is???
I hope you didnt leave it set for 17psi.
Old 05-19-2004, 08:17 PM   #16
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
what parts and design did you use for the homemade boost controller?
mr. m is offline   Reply With Quote
Old 05-20-2004, 11:10 PM   #17
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
It'll go in this weekend or next... if I can get my hands on my buddies laptop that is. And no, I'll be backing it off all the way to start
Mr M. I used a male and femal 1/8" x 1/4" NPT hose barb, a spring and a 3/16" ball bearing. The 1/8" barb was probably part of the problem (acted as a restrictor) but the spring either was WAY too soft and sealed the output side or way too stiff and just didn't open enough. The project only cost a few dollars so it wasn't (luckily) a big deal. My next attempt was going to be a t fitting and a needle valve, cost a little more but should be better at minute changes in pressure. If the dawes device doesn't work for me then I'll be trying the needle valve.
Holy whacked Batman..Batman! blubaja03 Off-Topic 4 10-07-2005 08:06 PM
Holy Cow Batman!!! Everyone Must See These!!!!! daytontp Brakes, Steering & Suspension 14 02-20-2002 08:07 PM
Holy WRX Batman! Valien Member's Car Gallery 17 11-22-2001 01:14 AM
OT: Holy cow batman, its the batmobile! gumball General Forum Archive 14 09-14-2000 06:56 PM
Holy smokes batman! Andrew General Forum Archive 32 07-20-2000 05:20 AM
