#1 |
Member#: 29845
RMIC
Vehicle:2005 STi OBP & 1999 Forester L |
After my gc8 bit the dust... or a concrete barrier if you will, my wife and I are now pimpin a sf5 ('99 forester L). My question is will gc8 intakes headers and exhaust bits fit on my new (body) roll machine? It does have the 2.5l in it... any help is greatly appreciated
p.s. I won't mind if brand names are mentioned when suggesting intakes headers and exhaust systems ![]()
#2 |
Member#: 29845
RMIC
please?
#3 |
Review Crew
Member#: 34269
AKIC
Vehicle:Only marginally funny. |
Intake should fit. Headers and exhuast might not since the chassis is different.
#4 |
Member#: 2003
Vehicle:'99 BGP Legacy GT '98 QS Legacy L (auto) |
Boostmen - depending on model year, your intake & header should fit (this depends ofcourse on whether your Forester is auto or manual tranny). The cat- back portion won't fit b/c the one of the Impreza will be too short (tip wise)
#5 |
Member#: 29845
RMIC
JaxxaJ and GTBGUY, thank you. I figured that the intake and headers wouldn't be a problem but the exhaust on the other hand would be.. btw It's a '99 manual
#6 |
Member#: 2003
Boostmen - The intake won't fit your Forester b/c your '00RS uses MAP vs. the MAF used on the '99 Forester. To get your intake to work (depending on the intake) you could cut off the excess length and get an extra reducer for the MAF -> pipe.
#7 |
Member#: 29845
RMIC
Unfortunately the intake was actually damaged in the wreck, what intake would you and anyone else recommend for my MAF Forester set up??
#8 |
Member#: 61052
NESIC
Vehicle:1999 2.5 RS White |
the header should fit, being the same motor. if you're maf equipped, stay away from intakes all together. K&N panel filter is fine, even with a FULLY BUILT motor. If you want power in the forester, try some cams. Cobb tuning.com (stage 1 cams) will work well, as long as the valve lash is set properly by the shop doing it....they made the biggest difference in power on my 99, and only cost 500 beans.(after the core charge)
#9 |
Member#: 29845
RMIC
yeah cams were in the plan as well. Infact if I plan on doing power upgrades they'll most likely all be from Cobb, excluding some cheaper suspension mods. It is MAF based and I know that the Cobb cai can work but thanx for the suggestion Boost-Free. Cobb's new equal length header looks outstanding!
http://www.cobbtuning.com/impreza/pr-headers.html |
| Thread Tools | |
| Display Modes | |
| The Real McCoy on The Leyland P76 - Giving it the Boot | AVANTI R5 | Non-Subaru News & Rumors | 0 | 06-09-2008 08:36 AM |
| The real real doll | saturn2wrx | Off-Topic | 12 | 08-09-2006 03:33 PM |
| The real *real* angry Pika | Marc Sawaya | Interior & Exterior Modification | 19 | 03-24-2001 09:55 PM |
| The REAL pictures from the import show... | Rancid | Texas Impreza Club Forum -- TXIC | 3 | 12-27-2000 10:31 PM |
| The REAL story of the STi rabbit and P1 | Necromancer | General Forum Archive | 4 | 08-22-2000 07:11 PM |
