Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 10-11-2000, 10:48 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post Why winter steel wheels?
I always see posts about using 15" steel wheels in the winter. What's wrong with just switching tires? Are my 98 gold rims some how going to be effected by winter driving? I have some 15" available to me for free is this what I should be putting on my car? (no tires on them)
Joshua
MY98 RS
Subaru Salesman
yebokmj is online now
Old 10-11-2000, 10:53 AM   #2
Gambit
Member#: 102
Post
15" steel rims are cheaper. It is better to mess up a cheap piece of metal rims than your alloys. Also you want narrower tires so that it can cut thru the ice.
Rally cars uses 4" width during ice stages.
Gambit is offline
Old 10-11-2000, 11:02 AM   #3
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
I got a set of Legacy take-offs (alloy) from tire rack with snows mounted. I just wanted something thinner and already mounted so I can switch back and forth easily. I wouldn't want to bring the car back to the tire shop every winter.
Chuck is offline
Old 10-11-2000, 11:22 AM   #4
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Post
Also, the road salt and sand will chip and eat away at your wheels. Plus... if you get any water, slush or snow into your wheels... it can freeze and mess up your wheel balance. The steel wheels are closed, as compared to the open design of the alloys. And yes... if you lose traction in snow or ice, and hit a curb... saying goodbye to a $30 wheel is much nicer than saying goodbye to one that's over $100.
Hey... if you can get them for free... go for it. Plus, with the steels... you don't have to go out and change your tires each season. You just change your wheels. Much easier and cheaper.
[This message has been edited by Pinochle (edited October 11, 2000).]
Pinochle is offline
Old 10-11-2000, 01:00 PM   #5
boxerman
Member#: 644
Post
Also by going with a 15" rim you are in effect minus-one sizing, giving you a taller sidewall. The taller sidewall will flex more and absorb energy making your throttle/brake/turning response less crisp, wich is a benefit in low traction conditions.
Tim
boxerman is offline
Old 10-11-2000, 01:04 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Also if you nail a curb you have to spend a lot less replacing the winter wheel - if it even gets damaged since there is so much sidewall to protect it.
8Complex is offline
Old 10-11-2000, 04:11 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
Cheep.. started with UGLY black ones now i have forester steel rim ($25 each)
Jaxx is offline
Old 10-11-2000, 04:24 PM   #8
SubEd
Member#: 717
Have a Nice Day?
Have to go along with Pinochle on this one. The main reason is that the alloy's will fill with snow and turn to ice, weighing about 50 lb.s each. Go for steel. You can change them over yourself at the first storm! They're also narrower, which cuts through snow better.
Ed (36 Vermont winters and counting....)
SubEd is offline
Old 10-11-2000, 06:14 PM   #9
WRC666
Member#: 2351
Post
15" steel wheels, dark grey hammereffect spraypaint. Looks cool and at 30.- per wheel a real bargain.
And if they get ruined by salt, who cares!
WRC666 is offline
Old 10-11-2000, 06:59 PM   #10
Siper2
Member#: 1134
2007 BMW 328xi wagon
Post
How much does TireRack charge for steelers?
I'll be needing some soon...
Hey what's this "hammereffect spraypaint" ..?
-S2-
Siper2 is offline
Old 10-11-2000, 07:10 PM   #11
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Post
What size tire would you run on a 15" rim? What's close to the stock size?
Jim
Impreza Rider is offline
Old 10-11-2000, 07:29 PM   #12
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
You should run 195/65-15 if you are stock ride height, 195/60-15 if you are lowered more than ~1".
ColinL is offline
Old 10-12-2000, 04:27 AM   #13
Don
Member#: 1597
2005 Legacy GT
Atlantic Blue
Post
Joshua,
I think there are two reasons why people get a set of steel wheels for snow tires.
First, as others have pointed out, salt can have a corrosive effect on some alloy wheels, leading to pitting and other unsightly nasties. This isn't a problem with steel (it's probably not a problem with a well-clearcoated alloy rim, either).
Second is the cost. Your snow tires will last for maybe 4 winters. Mounting and balancing a tire costs maybe $12 - $15 per corner. And over the life of your snow tires, you'll be mounting and balancing all 4 corners twice per year (snows on in the fall, off in the spring). So that's easily over $100, never mind the time you spend waiting while BillyBob mounts the tires (and maybe scratches your pretty alloy rim in the process). Much cheaper and more convenient to pick up a set of steel rims and mount the snows on them. If you're concerned about looks, TireRack is selling wheel covers at around $22 per set right now.
Don is offline
Old 10-12-2000, 05:20 AM   #14
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
ColinL,
Didn't you get that backwards? Wouldn't a lowered car need more ground clearance in the Winter than less? Unless you're refering to the tire hitting the wheel well which I don't think'll be a problem, well not as much as getting high centered in the snow (which I've done at stock height ).
Tony - Just keeping you honest
[This message has been edited by Tony (edited October 12, 2000).]
Tony is offline
WTB: 16" STEEL WHEELS w/ Winter Rubber roffle Private 'Wanted' Classifieds 1 08-11-2004 10:42 AM
FS: Winter tire set with steel wheel ET Vancouver Impreza Club Forum -- VIC 18 11-28-2003 12:18 AM
Winter steel wheels rusted to hubs ForceFed4 Tire & Wheel 10 04-21-2003 04:21 PM
Steel Wheels for Winter vt00rs Brakes, Steering & Suspension 17 11-01-2000 05:08 PM
Cheap steel wheels for winter tires? DoctorMoo Technical Forum Archive 6 07-27-2000 12:06 AM
