Old 05-02-2004, 02:09 AM   #1
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
Default don't wait 60,000 miles to change your cabin air filter
between lazyness, autocross, and other mods, i never got around to it until it was too late. from the beginning my wrx emitted various different smells from each selection on the hvac control panel. lately the smells had somehow become slightly more offensive:
there were more screws than i expected to get the glovebox off, but overall it wasnt a very hard task to accomplish.
i would burn it, but that would release to many toxins into the already polluted suburban chicago air. instead i will hang this on my famously infamous 'wall of shame' in my garage.
Achilles38WRX is offline   Reply With Quote
Old 05-02-2004, 02:47 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You're not supposed to wait until 60k for the cabin filter. I think it's supposed to be changed every 12-15K.
Calvin
cnk is offline   Reply With Quote
Old 05-02-2004, 07:51 AM   #3
collegedropout
Member#: 42569
adds to the douchery
level round' here...
:janetjacksonon: N-A-S-T-Y :janetjacksonoff:
collegedropout is offline   Reply With Quote
Old 05-02-2004, 10:35 AM   #4
Infymus
Member#: 20588
I'm Harrassed By
NASIOC Mods
I must stress, but I must, and I will use caplocks.
NEVER LET A DEALER CHANGE YOUR CABIN FILTER.
There, I said it.
Dealer will charge you labor + cost of filter. $130 DOLLARS.
Infymus is offline   Reply With Quote
Old 05-02-2004, 10:57 AM   #5
dust12
Member#: 13417
Default Re: don't wait 60,000 miles to change your cabin air filter
I agree, mine looked just like that. I waited until 85k before I changed it. It wasn't smelly or emitting smells. It was reducing airflow to the cabin when the selector was in the fresh air position. I won't wait that long next time.
dust12 is offline   Reply With Quote
Old 05-03-2004, 04:26 AM   #6
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
does a MY99 RS have this filter? i dont think my car came with the air filtration option. but what would i look for if i had this?
Nate
NateDogg is offline   Reply With Quote
Old 05-03-2004, 11:22 AM   #7
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default under dash
Nate
On CG8's the cabin filter is located under the dash directly below the glovebox. One phillips head screw and you can take off the cover. It's long, vertical and narrow.
The one in the picture actually does not look that horrible. Mine look about the same after 10k-12k. I think they should be renewed annually.
vvk is offline   Reply With Quote
Old 05-03-2004, 01:33 PM   #8
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
I just replaced mine this weekend as well. It's suppose to be replaced either 12 months or 7500 miles, whichever comes first. I was going to stick to 12 months, but put it off a little longer. If I was to go by miles, I'd be on my 5th one.
The instructions say there are 7 screws, but I took off 9. Also, there was wiring blocking the filter door, so removal and installation was a bit tricky.
merlot is offline   Reply With Quote
Old 05-04-2004, 09:18 PM   #9
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
Calvin
thanks for the hint mr. goodwrench!
i found it easier if you disconnect the mini-harness that holds that wire up.
Old 05-04-2004, 09:22 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check this thread for how to make your own-
http://forums.nasioc.com/forums/show...hreadid=476514
Old 05-05-2004, 07:55 PM   #11
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Which end did you disconnect? I fiddled with end that went to the glove box, but I'm no electrician. I wasn't sure how to pull it out without damaging it, so I left it.
Old 05-05-2004, 10:07 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The connector on the glovebox has a tab that can be released with a small screwdriver to separate it, but it is a PITA.
Old 05-05-2004, 11:17 PM   #13
cnk
Member#: 10757
No problem. . here to serve.
Calvin
Old 05-06-2004, 03:02 PM   #14
RSarte
Member#: 4965
2004 WWhite Evo8 GSR
2010 Outback 2.5i Premium
Awesome! I had this idea after finding out I didn't have the "filter system" with the car when I bought it in 2001.
I just never thought about it again.. glad to see more geniuses at work.
RSarte is offline   Reply With Quote
Old 05-06-2004, 08:18 PM   #15
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Hmm, at 132k now, I think I'll check and see if I have one
MYfirst00 is offline   Reply With Quote
Old 05-06-2004, 11:16 PM   #16
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
I just changed mine out this past weekend. I used a 3M Filtrete 1250 from Home Depot. Since all the sizes were the same price, I got the biggest one they had, 24X30. That's big enough to make 12 filters! So for $15 you can make 12 high quality filters, or you can pay $30 for one from the dealer. It seems kind of silly really.
-Bryce
Carnot is offline   Reply With Quote
Old 05-06-2004, 11:23 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Good move, but you won't make 12 filters from that one. The OE filter is about 7" x 8", so a 24 x 30 might yield 3 if you cut them out carefully. Still quite cost-effective vs. buying them at the dealer.
Old 05-07-2004, 04:45 AM   #18
Carnot
Member#: 34596
'05 WRX Wagon PSM
24/8=3
30/7=4.286
3*4.286=12.9
But you're right, I will have to cut carefully.
-Bryce
Old 05-20-2004, 03:14 PM   #19
billmidd08
Member#: 39599
08 STI Hatch
I have the exact same filter but 20 x 30, and I made 6 of em, so you should be able to make at least that much
two across and three down.
2 * 7 = 14 outta 20
3 * 8 = 24 outa 30
if you went the other way around with yours you should be able to get 9
three across
3 * 8 = 24 outta 24
3 * 7 = 21 outta 30 (they are a about 7 3/8 or so, so trying to cram 4 rows in would be pushin it.)
billmidd08 is offline   Reply With Quote
Old 05-22-2004, 04:53 AM   #20
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
Wow that filter is black!
I also plan on picking up something from Home Depot and cutting it to fit.
Any tips?
Do I just cut it with regular scissors?
-Scott A.
cky211 is offline   Reply With Quote
Old 06-05-2004, 02:49 PM   #21
rich22
Member#: 34662
2004 WRX Wagon
Can someone make a quick install guide and how to cut the filter properly... I dont have a filter (never had that option) so i dont know which way to put it in or how..
Thanks,
Rich
rich22 is offline   Reply With Quote
Don't forget your cabin air filter! hdempsey General Community 1 04-02-2010 02:51 PM
Your cabin air filter + mesquite tree = TukeeWRX South West Impreza Club Forum -- SWIC 11 07-30-2009 04:54 AM
Remember to change your cabin filter! slowguy Vancouver Impreza Club Forum -- VIC 36 09-10-2008 11:51 AM
Be sure to change your Cabin Air filter!!! Engmus Service & Maintenance 59 05-24-2008 04:55 PM
FYI: Changing your stock air filter funscooby Normally Aspirated Powertrain 0 02-04-2002 06:08 AM
