Old 05-02-2004, 06:51 AM   #1
Chi_San
Member#: 53558
2002 WRX Wagon
Subaru Stars Urg. Another head gasket.
At 90k, my 1995 Legacy L went in for the routine checkup, and they found a worn headgasket. Now, it's at 98k and it's making the same sound it did before. It also is showing a momentary rapid drop on the temp sensor. I'm assuming the thermostat sees a temp increase and goes 'Oh! noes!' and opens or closes a little more.
It's not gone yet. But it's going to go soon. Maybe it'll get replaced again at the 100k.
Oh, yeah, that's right. They replaced the clutch too. While dropping a friend off at his house, my car got stuck. My foot slipped off the clutch, and it got smoked. There was excessive slip on the way home... Then, the next day, it was gripping like it always did. It hasn't slipped since, but still. I think it's going to get replaced again.
Should I have anything else done while it's in for the 100k? Maybe have the tranny rebuilt, due to the clutch drops I did that caused the first clutch replacement?
Chi_San is offline   Reply With Quote
Old 05-02-2004, 10:18 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
? Did they replace the HG at 90K?
How do you "find" a worn HG?
If they replaced it the first time, what warranty did they give you and are you still covered?
As to the clutch and trans, if it is working now correctly I would leave it alone. Save some money for when it goes again.
Old 05-02-2004, 03:40 PM   #3
Chi_San
Member#: 53558
2002 WRX Wagon
Yeah, they replaced the Head Gasket at 90k.
I don't know. We didn't take it to a stealership. We took it to someplace else that does foreign auto. And, no, I don't think it's under warrenty.
After the 90k was done, the hill holder stopped working and the clutch throw changed. I'm not sure if they installed the clutch correctly. Going to have them check it out and fix it.
Old 05-03-2004, 01:46 PM   #4
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
I believe it tells you how to adjust the hill holder mechanism in the owner's manual (I'm pretty sure it does on mine, a 98 L). You can also adjust the amount of free play on the clutch. When the stealership changed the clutch on my car, they put in 2" of free play
jey is offline   Reply With Quote
Old 05-03-2004, 10:10 PM   #5
Chi_San
Member#: 53558
2002 WRX Wagon
Not a thing in the manual. I've looked. I'm pretty sure that the hill holder isn't working because the freeplay is off.
I kept an eye on the temp gauge today. It kept wavering at the normal line and dropping a little. It was a warm day today, too. I don't understand why it wasn't going up?
I reset the ECU. Idle is a lot smoother now.
another head gasket repair cost Gixxer1K Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-15-2007 06:01 PM
Another Head Gasket Gone! kbrate Legacy Forum 28 08-30-2004 11:49 PM
Another (?) Gen II warranty head gasket Valkaru Outback Forum 5 01-27-2004 07:06 PM
Yet another head gasket problem, will I be denied warranty? mmmprza Warranty Issues & SOA Problems 4 12-11-2003 01:54 AM
Yet another head gasket question... MHC Normally Aspirated with bolt-on Forced Induction Powertrain 7 06-29-2003 02:40 PM
