Old 05-02-2004, 10:28 AM   #1
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Default Head gasket: which one?
I'm currently building a new engine for my track car. I'm using a EJ22 open deck short block and MY90 JDM DOHC Legacy Turbo heads. Don't ask why, I just happen to have this combination laying around.
Question is what head gasket to use, regarding alignment of cooling passages.
MY91-94 USDM EJ22T? I know the standard early MY SOHC gaskets won't work. What about the Phase-2 thinner gaskets, anyone have a picture of one?
And just out of curiosity, any pics available of closed deck EJ22T heads or engine deck?
Any help is appreciated.
Marnix is offline   Reply With Quote
Old 05-02-2004, 01:12 PM   #2
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Already found what I was looking for; the USDM EJ22T head gaskets match the coolant passages of the JDM EJ20G heads.
Old 05-02-2004, 01:50 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
graham did you use a HG for 99rsheads of that stiblock?
alex
Old 05-03-2004, 10:39 AM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Lightbulb
really.....you confirmed this? any pics?
I'm putting EJ20G heads on my legacy turbo short block......this will save me doing some research
Scoobyslack1 is offline   Reply With Quote
Old 05-03-2004, 01:56 PM   #5
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Well, I compared the pictures of the closed deck EJ22T block that Wedge posted a few months back, and coolant passages are 95% identical to the closed deck EJ20T engine that I have in sitting my basement. The heads I want to use came off that engine. So basically, it's 1+1=2 but I still want to check with the head gasket just to make sure.
Please note that if you put early Legacy Turbo EJ20G heads on the stock EJ22T block, you'll end up with a compression ratio of 6.7:!
I'll be running stock EJ22 pistons, which will give me compression ratio of 7.7:1, perfect for some serious boost capabilities!
Both calculations based on info on EJCALCS and the 57cc of head volume I have measured on my EJ20G heads. Both with 1.52mm gasket thickness.
If I can find info on cooling pattern of later, thinner (0.58mm) EJ22 gasket (that is compatible with the EJ20G DOHC heads), I will use that to reach a calculated CR of 8.3.
Anyone have a thin EJ22 gasket laying around and willing to take some pics?
Old 05-03-2004, 02:21 PM   #6
Scoobyslack1
Member#: 2780
junk yards rule!
Arrow
I thought it would be about 7.8:1...
I must look into this further.....I don't want to loose all that nice torque I have now
Old 05-03-2004, 02:48 PM   #7
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Don't give up just yet, there's a difference in head volume between MY89-93 Legacy Turbo EJ20G DOHC heads, and the later MY93 and onwards Impreza EJ20G DOHC heads (later version EJ20K) and Legacy TwinTurbo heads (EJ20H on 260bhp auto and EJ20R on 280 bhp manual).
The 'first generation' heads are 57cc, and the 'second generation' EJ20H heads (similar to later EJ20G and EJ20K and EJ20R heads) that I have measured aswell, are around 47cc. This is due to the different valve angles.
EJ22T stock pistons with Gen1 EJ20G heads -> CR = 6.7
EJ22T stock pistons with Gen2 EJ20G/H/K/R heads -> CR = 7.4
It may well be that EJ25 DOHC heads have the same head volume as the Gen2 EJ20G/H/K/R heads, as EJCALCS mentions 46cc, which could well be down to my crude measurements.
Old 05-03-2004, 03:09 PM   #8
Scoobyslack1
Member#: 2780
junk yards rule!
Impreza GC8
I haven't given up hope......besides the heads I have are adorned with some nice titanium springs
Old 05-03-2004, 04:42 PM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
ru sure theyre titanium and not steel w/ titanium retainers?
Old 05-04-2004, 08:27 AM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
Talking
well, I paid Axis tuning to put in some titanium springs w/STi retainers.....so I hope they are
Old 05-04-2004, 04:41 PM   #11
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Anyone has a supplier for thinner - 1.00mm - gaskets instead of the standard 1.52mm parts? For EJ22T obviously.
Old 05-05-2004, 12:04 AM   #12
inpreza kid
Member#: 3334
try cometic. they make several headgaskets for the ej22t. you can go custom too.
inpreza kid is offline   Reply With Quote
Old 05-05-2004, 12:56 AM   #13
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I used the EJ25 Cometic's
Graham is offline   Reply With Quote
A new head unit..... which one?? mvorchard Car Audio, Video & Security 20 12-22-2005 01:32 PM
Of that 3 plug bulb connector, which one is high, and which one is for low beam? Kwyjibo Electrical & Lighting 1 10-21-2003 08:07 PM
i wanna keep one cat, which one? Gundoo Factory 2.0L Turbo Powertrain 5 10-09-2003 09:48 PM
DVD head unit, no screen- which one? andygold Car Audio, Video & Security 2 10-11-2002 04:09 AM
Need to buy air tools - Which ones/which features? FutureWagon General Community 33 09-16-2002 03:04 AM
Message Board Statistics All times are GMT -4. The time now is 02:40 AM.
