#1 |
Member#: 477
Vehicle:GC4 -> GGA -> GM6 Yeah, that's about right. |
... and this is what the old stuff looked like...
![]() After a long pull up the Coquihalla, we stopped for a quick break ... started the car again and the clutch went 1/4 of the way to the floor without any engagement whatsoever! Crapola, crapola... first stop was the pet store for some aquarium tubing, 2nd stop was crappy tire for some DOT-4 fluid. Seems to have solved the problem for the time being but it still feels like there's an air bubble in there, or something needs lube. Err so the moral of the story is, if you haven't changed out your clutch fluid or brake fluid recently, maybe a good idea. What with this temperate rain forest we live in, and the fact that the RS hood scoop drain is located right above the clutch slave cylinder, the boiling point of your clutch fluid might be lower than you expected. I've got 75000km on a 2001 RS, btw...
#2 |
Member#: 44137
VIC
OMG, that looks like some coke in your clutch !
Guess i should do mine sooner than I expect |
#3 |
Member#: 1234
Vehicle:2000 |
Hmm.. I wonder if those Speed bleeder will work for the clutch slave cylinder.
#4 |
Member#: 477
Probably -- it's a standard bleed valve. HOWEVER, I dunno if I'd risk it. The clutch slave is sitting right on top of the tranny and it stays hot for long periods of time (unlike brakes that get hot and get cold pretty quickly, unless you drive like TMR). Those speed bleeders have a spring-loaded valve, right? I dunno how long that spring is going to hold up under constant high temp. And suddenly losing your clutch would be really, really bad.
![]() By the way, I should mention that the airbox does have to be removed for easier bleeding, unless you've got really fly elf wrenches or something... I gotta grease up the fork and piston next time I'm down there. That part is sure subject to a lot of abuse, located between the tranny heat and the hood scoop drain (darn non-functional hood scoops!)... |
#5 |
Member#: 477
Oh and the clutch pedal has a weird spring mechanism, so it will stick to the floor and has to be brought back by hand when pumping. Freaked me out the first time I saw that!
#6 |
Member#: 1234
Vehicle:2000 |
I think the brakes goes through hotter temp. than the engine would (at least my driving), so I think if the spring was to loose tension it would be on the brakes. I'll go buy another pair next week and take a look at it. From what it seems it is the same as the one on the brake.
Plus I don't have the air box anymore.. and it is very open. ![]() |
#7 |
Member#: 28203
Vehicle:03 Impreza WRX Black |
hmm just curious ... how often r u suppose to change ur clutch fluid?
#8 |
Member#: 477
Umm yeah, I guess a Search didn't come up with the right pages??
http://www.scoobymods.com/forums/sho...=&threadid=491 |
#9 | |
Member#: 769
VIC
Vehicle:04 SoBaLo EsTea-ai ZERO/SPORTS/99 GM6/05 BP6 |
usually bleed it every 3000km w/ the oil change...and i feel like the clutch will be working better everytime i did so... yet...honda is soooo easy to do... it's a good DIY service if u know how to do it ![]() |
#10 |
Member#: 1839
VIC
I do mine once a year, at the same time that I flush my brake fluid
| Thread Tools | |
| Display Modes | |
| Recommend a shop to change my clutch fluid | streko | Bay Area Impreza Club Forum -- BAIC | 8 | 01-21-2007 06:42 PM |
| So I'm changing my tranny fluid in my awd outback sport... | chillington | Service & Maintenance | 5 | 09-17-2005 11:41 PM |
| How long before you should change your clutch fluid? | 0260B4U | Service & Maintenance | 16 | 02-27-2005 10:02 PM |
| Interested in changing your clutch fluid? | P.K. Motorsports | Normally Aspirated Powertrain | 0 | 04-14-2001 10:36 PM |
| where and how to change my diff fluid? | GregBolby | Normally Aspirated Powertrain | 3 | 11-26-2000 09:38 PM |
