Old 05-02-2004, 05:57 PM   #1
import111
Member#: 24447
2010 Evo GSR
GG
Default more boost on 10:1?
I want to know if there is anything I can do to my 01 Impreza 2.5RS motor to handle more than 5-6 PSI w/o lowering compresion ratio or using high octane race gas. Forged aluminum pistons/rods? Bigger injectors, more fuel?
Ryan
import111 is offline   Reply With Quote
Old 05-02-2004, 06:03 PM   #2
kaos200
Member#: 2692
with the catpiss 91 you get (same as our cali 91) why wouldnt you want to lower your compression?
Its not cheap to drive around on 100 all the time
kaos200 is offline   Reply With Quote
Old 05-02-2004, 06:34 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Agreed.
kastle is offline   Reply With Quote
Old 05-02-2004, 06:58 PM   #4
import111
Member#: 24447
2010 Evo GSR
GG
I didn't say I wanted to use race gas either. If I lower the compresion and raise the boost, it will be the same as if I never lowered the compresion. It's like trading a dollar for 4 quarters. I want to keep 10:1 compresion. I might go down to 9.7:1 but that's it, and that's cause the 98 RS has the 9.7:1 but still has 165hp and 166 torque. So is there anything I can do to my car besides lowering compresion or race gas to make it safe to raise the boost?
Ryan
Old 05-02-2004, 07:00 PM   #5
kaos200
Member#: 2692
Originally posted by import111
If I lower the compresion and raise the boost, it will be the same as if I never lowered the compresion. It's like trading a dollar for 4 quarters. I want to keep 10:1 compresion. Ryan
that is entirely false, please do a search.
with that theory, might as well go 15:1 and stay N/A, less weight without a turbo and intercooler and you'd make the same amount of power.
Old 05-02-2004, 07:05 PM   #6
import111
Member#: 24447
2010 Evo GSR
GG
Look, all I am asking is, does anyone know what I could do to my car to make it safe to run high boost on 10:1 compresion w/o high octane gas?
Ryan
Old 05-02-2004, 07:07 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
o2 inj
alc inj
good timing control
Old 05-02-2004, 07:07 PM   #8
kaos200
Member#: 2692
Ryan
yes, run pig rich, retard the timing, run colder plugs, run water injection at all times, and knock on wood 10x a day.
and in the end you could have just installed the lower compression pistons instead of the 10:1s and not had to worry.
/done with this thread.
Old 05-03-2004, 12:06 AM   #9
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Why is it a big deal any how? do you want a slower car? cause if you do, you can raise your compression and lower your boost. but really, why?
-Eli
squirrelmasta is offline   Reply With Quote
more timing less boost vs less timing and more boost? NJ2.5RS Engine Management & Tuning 6 08-27-2007 05:51 PM
More Boost on colder air? JCKing71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 10-14-2006 09:10 PM
what prevents us from running much more boost on stock turbo? ez bturbo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 12-03-2004 08:47 PM
what boost on the 10:1 pistons? jdchmiel Normally Aspirated with bolt-on Forced Induction Powertrain 11 01-14-2004 07:36 PM
Less boost with more timing or More boost less timing? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2003 10:13 PM
