Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 05-02-2004, 05:58 PM   #1
Tkacik
Member#: 847
'06 Titan Crew Cab
'03 Odyssey - EXL/RES
Default Brake Pads.
Well, it's about time to change out the pads on the Loyale. What should I expect? I haven't ever tried this before, but I helped a friend change out pads on his Tacoma once, didn't take us too long.
Any tips to make the process go more smoothly? Anything else I should check out while I have everything off?
Thanks.
Joe.
Tkacik is offline   Reply With Quote
Old 05-02-2004, 06:20 PM   #2
twisty
Member#: 59966
1988 GL-10
Tan
I just hope it isn't as bad as my brakes on my gl-10 were.
twisty is offline   Reply With Quote
Old 05-02-2004, 06:48 PM   #3
Tkacik
Member#: 847
'06 Titan Crew Cab
That's encouraging
What was so bad about them?
Old 05-02-2004, 09:27 PM   #4
twisty
Member#: 59966
1988 GL-10
Tan
Getting the piston that pushes the brake down was a pain in the ass.
Old 05-04-2004, 02:47 PM   #5
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
If you're just doing pads, it should be easy, except for the piston in the caliper like twisty said.
If you're doing rotors though, you have to:
Take the castle nut and washer off the axle stub
Unbolt the rotor from the hub
Take the caliper off
It's not like new Scoobs where you just take the caliper off and the rotor comes right off
DerFahrer is offline   Reply With Quote
Old 05-05-2004, 09:09 PM   #6
dusktilldawn
Member#: 57766
1987 GL Wagon 4WD
The Silver Bullet
If I remember right, the Haynes manual that I had said not to depress the brake pedal while the caliper is off. Being the super genius that I am, I did it to see what would happen. I never did get the piston reset, and ended up buying rebuilt calipers.. Moral of the story is... Don't be like me.
dusktilldawn is offline   Reply With Quote
Old 05-10-2004, 01:27 PM   #7
Tkacik
Member#: 847
'06 Titan Crew Cab
Ha ha, no problem
Old 05-10-2004, 03:44 PM   #8
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
the whole process is really easy.. even if you have to replace the rotor..
Theres a tool you can buy from just about any auto parts store to compress the caliper pistons... WARNING!! they do not 'push' in.. they turn in.
Calebz is offline   Reply With Quote
Old 05-10-2004, 07:47 PM   #9
twisty
Member#: 59966
1988 GL-10
Tan
LMAO well atleast I know that now for the back ones and don't have to drain out the brake fluid.
Endless Brake Sale - Vita Nuova/SS-S Brake Pads w. RF650 Brake Fluid DriveLineSales Suspension/Brakes/Handling 3 10-09-2009 09:07 PM
STi Brake Pads / SS Brake Lines / Brake Fluid TicketsForMePlease Private 'Wanted' Classifieds 4 11-30-2006 10:47 AM
Who Needs Brakes Pads? I Need Brake Pads! SupaSizeFries Tri-State Area Forum 10 04-15-2005 11:11 AM
TS (L) pads, rotors = RS Brake pads, rotors? youthanasia Brakes, Steering & Suspension 2 02-02-2001 10:08 PM
Message Board Statistics All times are GMT -4. The time now is 10:53 AM.
