Old 05-02-2004, 09:15 PM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Default Silened my Cobb CAI (almost)
Just wanted to link my post on wrxforums:
http://www.wrxforum.com/cgi-bin/ulti...c;f=4;t=001204
I would like to announce, to all who thought the Cobb CAI was too loud, that it can be tamed!
Most of the noise that you hear at WOT is just the sound of the intake reverbing off the fender and outter wall of the engine bay. This reverb is easily cancled out with some double sided foam tape and a few pieces of 1in thick foam.
I just found some lying around in a box that was used for shipping electronics (Hard drive).
I put down a few strips of the double sided tape in my fender well, stuck the foam against it (directly across from the CAI opening) and put everything back together.
It's much more civil now and doesn't draw attention to you when powering through a turn.
I'll get pics online later in the week after finals.
-- Dave
AcquaCow is offline   Reply With Quote
Old 05-02-2004, 10:31 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
You loose 100 iggpoints
Old 05-03-2004, 12:52 AM   #3
obyone
Member#: 16523
Wouldn't this disrupt airflow into the intake inlet causing loss in power?
BTW...Wouldn't dynomatt, or any other smooth sided sound deadening material, be better?
obyone is online now   Reply With Quote
Old 05-03-2004, 12:59 PM   #4
Section 8
Member#: 821
Great.
A post with nothing, linking to another post with nothing.
Post when you HAVE somthing.
Section 8 is offline   Reply With Quote
Old 05-03-2004, 02:00 PM   #5
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Oh, I _have_ something...I just need to take pics.
I posted to remind myself.
As for airflow, no, it does not disrupt any at all. This was my main concern.
Dynamat? Dynamat would stop the outside panel itself from vibrating, but would not stop the sound from reverbing. You need something to absorb the sound and slow it down. Foam fits this job perfectly.
Also, the 2 squares of foam will weigh a lot less than an equal sized sheet of dynamat.
Pics tonight.
-- Dave
Oh and in response to:
I didn't say I was going to keep the foam there...this was just for testing a theory.
Old 05-03-2004, 04:11 PM   #6
MattDell
Member#: 16803
I love you.
I hate, hate, hate, hate, hate how the COBB intake just lays in the engine bay and 99% of the time it falls out of the fender opening. If your pics look good enough, I might give it a shot.
-Matt
MattDell is offline   Reply With Quote
Old 05-03-2004, 04:38 PM   #7
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
If it's falling out of the fender opening, you don't have it adjusted/tweaked right.
Lengthen it out a bit more, loosen those hose clamps and stick it a full inch into the fender well.
-- Dave
Old 05-03-2004, 04:40 PM   #8
MattDell
Member#: 16803
I might have to give that a shot.
Old 05-03-2004, 04:40 PM   #9
Alpha_32
Member#: 35876
2008 Legacy GT SpecB
Grey
piiiiiics
Alpha_32 is offline   Reply With Quote
Old 05-03-2004, 04:45 PM   #10
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Gimmie 2 hours.
Old 05-03-2004, 04:57 PM   #11
tobRS
Member#: 24440
05 lgt
I cut out the bottom of a coozie and slid it on the end that goes into the fender. Does the same thing I guess. Works well for me.
tobRS is offline   Reply With Quote
Old 05-03-2004, 05:00 PM   #12
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Mine's never fallen out of the fender, either, but I've been just short of getting into research on quieting my COBB CAI. I -did- get pulled over for a suspected exhaust problem with it...
Where'z the pics at?
LetItSnow is offline   Reply With Quote
Old 05-03-2004, 05:27 PM   #13
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I'm leaving work as soon as my freshly patched email server reboots.
Within an hour.
-- Dave
Old 05-03-2004, 05:30 PM   #14
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
I saw a post some time ago with a photo that had a part number for an actual subaru plastic part that covers up that hole that stays where the air intake resonator (snorkus) usually is. Anybody know what the part # is? That may help quiet the CAI down also...
BTW, comming from a J tube intake, the Injen CAI is not loud at all!
powerlabs is offline   Reply With Quote
Old 05-03-2004, 06:42 PM   #15
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Alright...took pics, but they aren't anything special IMO, but you'll get the idea.
(resizing and uploading now)
Old 05-03-2004, 07:51 PM   #16
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Here are the pics:
CAI Installed in engine bay
CAI
CAI detached
Hole that CAI sits in
Plastic cover removed
Old 05-03-2004, 07:51 PM   #17
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
CAI back in place
Installed position
Space infront of CAI when installed
Area above CAI (top of fender well)
Area below CAI (down towards bumper)
Spacing between CAI and that thing everyone complains it "rubs" against (note angle between filter box and top half of CAI)
The images are mostly self-explanitory, but as you can see, there's a good 4in of space infront of the CAI even with the 1.5in layer of foam.
I actually have one smaller 1/2in layer behind the gray packing foam, directly infront of the CAI opening.
The results from having the foam here removes the loud roar from the CAI at WOT and leaves you with more of a civil grumble.
If you have any questions, ask away.
-- Dave
Old 05-03-2004, 07:54 PM   #18
Defiantguy
Member#: 41268
2015 WRX
pretty cool, now if I could only hear my cobb CAI with my setup. All I got is exhaust noise now.
Defiantguy is offline   Reply With Quote
Old 05-03-2004, 09:09 PM   #19
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
That foam is going to start degrading and getting sucked into the intake.
Old 05-03-2004, 11:07 PM   #20
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Talk about the glass being half empty...sheesh...
That foam will last quite a long time there...and if it ever does degrade, the filter will catch it and it can be replaced.
Now go back to the hole from which you crawled.
Old 05-03-2004, 11:09 PM   #21
powerlabs
Member#: 45790
SUPERCHARGED
Hey, aquacow, where did you get that plastic cover that plugs up the hole in the fender well next to where the CAI goes in to?
Old 05-03-2004, 11:22 PM   #22
obyone
Member#: 16523
Ummm...Without seeing some better picturs of the inner fender well (Remove the plastic wheel well cover and there you go) I'm going to go out on a limb and say that foam IS dirupting airflow from your bumper vents, through the fender, and into the intake. How much, I don't know but it looks like it takes up quite a bit of space in there.
OH yeah...IBglassishalfemptyyoujerk.
Old 05-03-2004, 11:55 PM   #23
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
based on the above image, there's atleast 4in of free space infront of the opening for the intake (it's actually 4.5in exactly). There's plenty of air for it to grab with that kind of space all around it.
I'm pretty sure you could put a vaccum sensor in there before/after the foam and see if there's any increased suction due to not enough air...I doubt the numbers would change.
That foam would have to get within 2in of that opening before you start restricting any flow.
I took the car to WOT and watched the foam...didn't move one bit.
I can't give a firm yes or no on this w/o pricy equipment though.
-- Dave
Old 05-04-2004, 02:13 AM   #24
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Plugging up that other hole on your fender wall might help with volume.
*crawls back under his 15,000 post rock*
Old 05-04-2004, 09:22 AM   #25
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
*Note: (it is plugged foo!)
Painted my Cobb CAI ATX25RS Interior & Exterior Modification 8 12-15-2005 03:48 PM
FS: COBB CAI from my 2k Legacy LetItSnow Legacy Forum 1 11-10-2005 02:13 PM
Thinking of selling my Cobb CAI (MAP, not MAF design) AcquaCow Mid Atlantic Impreza Club -- MAIC 2 01-19-2005 12:57 PM
Cobb CAI killed my gas mileage Yebisu69 Normally Aspirated Powertrain 31 01-07-2004 09:39 AM
My snow Clogged Cobb CAI RS ING Normally Aspirated Powertrain 30 02-21-2003 08:01 PM
