Old 05-03-2004, 09:46 AM   #1
pha qed
Member#: 57198
Default When the temperature needle moves, is it OK to start driving?
pha qed is offline   Reply With Quote
Old 05-03-2004, 10:01 AM   #2
Slowpoke
Member#: 19879
2004 WRX
Java Black
You don't even need to wait that long. I typically let my car warm up between 10 and 30 seconds depending on how cold it is. I drive very gently until the car has warmed up (temp needle in "normal" zone for a few minutes).
The way I see it, I'd rather warm up all components of the car simultaneously (engine, tranny, suspension, etc) by driving it rather than warming up just the engine by idling.
Slowpoke is offline   Reply With Quote
Old 05-03-2004, 10:19 AM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
You're actually supposed to drive it around gently in order to warm up the car. Letting the car sit there and warm up is not good for today's cars.
Calvin
cnk is offline   Reply With Quote
Old 05-03-2004, 10:24 AM   #4
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Calvin
Reason being is that if you let the car sit and warm up, you have nice warm water and oil with cold brakes, a cold tranny, cold everything else.
Just start it and go, drive nice and easy until the temp gauge reaches operating temperatures.
Neek is offline   Reply With Quote
Old 05-03-2004, 10:59 AM   #5
Hayes
Member#: 11808
I start my engine and quickly bump the idle down and let it idle for about 30 seconds and then drive easy untill the tempeture gage stabilizes which takes about 5-8 minutes depending on outside tempeture. Ed
Hayes is offline   Reply With Quote
Old 05-03-2004, 01:02 PM   #6
rich22
Member#: 34662
2004 WRX Wagon
Yeah just wait till its right in the middle and go go go
rich22 is offline   Reply With Quote
Old 05-03-2004, 03:08 PM   #7
MistaOctamopus
Member#: 53561
2004 WRX
You just need to give the car a few seconds to get the oil moving through the engine. Probably about the amount of time spent putting on your seatbelt and making sure you have everything for your trip. Then just drive gently and let 'er warm up for about 10 mins.
MistaOctamopus is offline   Reply With Quote
Old 05-03-2004, 04:43 PM   #8
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
That's not entirely true. The stock guage is a coolant temperature guage and it is designed to be "in the middle" over a wide range of operating temperatures. Unless you have an oil temp guage, the best advice is to wait a few minutes before driving the car hard in order to ensure that the oil is up to temperature. Coolant heats up more quickly than oil.
Stanley is offline   Reply With Quote
Old 05-03-2004, 08:23 PM   #9
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Very good point. My stock temperature gauge will usually get to its normal position when my oil temperature is still about 30 degrees Celsius below than its normal position.
driggity is offline   Reply With Quote
Old 05-03-2004, 09:00 PM   #10
chaddeus
Member#: 56624
2004 Subaru WRX STi
Iyah. for me, i start my engine. wear my seats belt and turn on the radio etc.. Then straight away drive off which is roughly around 10-20 seconds.
I dont like to idle my car for no point.
- Charles
chaddeus is offline   Reply With Quote
Old 05-04-2004, 02:41 PM   #11
glepko
Member#: 19651
I'll add to this and say for those without oil temp gauges that it's good 'insurance' to allow the cooling fan to cycle through at least once before going WOT or pushing into the upper RPM band.
And to reiterate others, just start the car, make sure everyone is strapped in and as soon as the dinging stops you're good to go. I pretend I'm breaking the engine in until the cooling fan cycles through twice (under 3000 RPM, never more than about half throttle). This thing is going to last forever
glepko is offline   Reply With Quote
Old 05-05-2004, 12:19 AM   #12
joebobanaught
Member#: 43566
2002 WRX Sedan
Is that the ideal warming up? Keeping it under 3000 and never more than 1/2 throttle?
joebobanaught is offline   Reply With Quote
Old 05-05-2004, 01:20 AM   #13
chaddeus
Member#: 56624
2004 Subaru WRX STi
According to BMW M3, keep it under 4000 RPM. On those BMW M3, they have this indicator. So if the engine is cold, the "Redline" RPM is 4000 but as you gradually heat up the engine, the "Redline" RPM increase to maybe 6000RPM etc....
- Charles
Old 05-05-2004, 10:05 PM   #14
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
In cold weather it takes 8-9 mins for the oil temp gauge to stabilize. In warmer weather, more like 5-6 minutes. I stay off boost and under 3K until then. Oil temp and/or oil pressure gauges are good to have
john
I25: When you're pokin' a bitch, is it ok to let her see you sniff your fingers? Asinine Off-Topic 78 02-03-2010 02:29 PM
Is it ok to start and run the car while it's on jackstands? skydes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-16-2007 12:30 AM
Is it ok to drive on WG pressure to get to the tuner? Nettalp Newbies & FAQs 3 04-24-2007 06:26 AM
Is it OK to start car USING reverse?? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-13-2004 06:37 AM
Last Followup: Is it ok to drive with the intake blockers off? jodathmorr Interior & Exterior Modification 3 02-17-2004 09:14 AM
