Old 05-03-2004, 10:10 AM   #1
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Default Same as the "toe out" thread, but for rear camber
Where does rear camber affect a car the most?
We are having a slight problem with our WRX being awesome on turn in, great mid corner and then ok on corner exit. It is a little pushy sometimes when you get on the throttle way early. If it does that, its easy to adjust with a little lift, but I would rather not
Would taking out a little rear camber help me at corner exit but not make the car too loose for transistions? I tried a little more toe out (we run 1/8" total out right now) and keeping the shocks stiff, the car is way too loose on entry. If we turn the shocks down, it calms down on entry, but then its too "squishy" and we end up having to catch the car through the whole slalom.
Discuss
-Tom
trhoppe is offline   Reply With Quote
Old 05-03-2004, 10:43 AM   #2
KC
Member#: 442
16 SS
00 S2000
Default Re: Same as the "toe out" thread, but for rear camber
Discuss
-Tom
Step 1: Aquire funds
Step 2: Buy Nate Whipples Civic.
Step 3: Rotate
Step 4: ????
Step 5: Profit!
KC is offline   Reply With Quote
Old 05-03-2004, 11:33 AM   #3
jmott
Member#: 6713
2007 Prius
brown
don't hit the gas so hard =)
jmott is offline   Reply With Quote
Old 05-03-2004, 11:39 AM   #4
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Step 3: Rotate
Step 4: ????
Step 5: Profit!
funny, someone asked me how to win in STS yesterday, I told them to clone Hollis' car, then clone Hollis.
TyrannoSullyRex is offline   Reply With Quote
Old 05-03-2004, 02:37 PM   #5
Jsortor
Member#: 29561
2005 STX Natl Champ.
Sportin' 3/4 inches T.O.
Tom,
Welcome to the world of on throttle understeer! I hear about geometry that is supposed to correct for this, (pretty much the same stuff as you all know) but the problem seems to be so severe within the design of the car that even the best changes seem to only fix a part of the problem. If anyone finds the miracle cure (thats STX legal) I'll pay for it!
Jsortor is offline   Reply With Quote
Old 05-03-2004, 02:47 PM   #6
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Originally posted by Jsortor
Tom,
What he said...
-Steve
p.s. See ya in Farmington this weekend, Josh. (That is, if my new trailer is finished by then! )
MNbiker is offline   Reply With Quote
Old 05-03-2004, 02:57 PM   #7
Jsortor
Member#: 29561
Hope to see you there. Will be the first time I "see" the hot "East Coast" setup in person.
Old 05-03-2004, 03:04 PM   #8
KC
Member#: 442
16 SS
00 S2000
Who says he's got the hot setup?
Old 05-03-2004, 03:16 PM   #9
Jsortor
Member#: 29561
I just thought putting parenthesis around that many words, to show playful sarcasm, would look stupid.
Old 05-03-2004, 03:21 PM   #10
jmott
Member#: 6713
2007 Prius
brown
the problem is AWD
easy to fix
disconnect front axles
Tom,
Old 05-03-2004, 03:57 PM   #11
GarySheehan
Member#: 2450
1996 2005 Subaru STI
If you have maxed out front negative camber, taking some camber out of the rear will decrease rear grip in steady-state and throttle-on exit cornering. It will effect turn-in and corner entry as well, but not to the extent that toe-out does.
Gary
Sheehan Motor Racing
www.teamSMR.com
GarySheehan is offline   Reply With Quote
Old 05-03-2004, 04:00 PM   #12
zoomfactor
Member#: 30440
03 WRX
WR Blue
the problem is AWD
Don't know if I agree with your cure jmott
FWIW - I don't think that many of the 2WD auto-x'ers can appreciate the complexities of setting up an AWD car.
I've got the problem of too much rotation and my set-up is no where as aggressive as some of you. I am running a little more rear camber -- about -1.8+/- with zero toe. (22-44 RSB set on 22mm, 22 mm FSB, Tein RA 8/7).
zoomfactor is offline   Reply With Quote
Old 05-03-2004, 04:47 PM   #13
MNbiker
Member#: 18148
'08 WRX
Dark Gray
If you're rotating too much with that setup, it's almost certainly the driver, not the car. (not meant as a slam) Where are you seeing "too much" rotation?
-Steve
Old 05-03-2004, 04:53 PM   #14
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Too bad I can't drive it quite as fast as my co-driver in Topeka!
(Especially in the rain - cripes, Mike is truly an alien in wet weather!)
....and my setup isn't quite the same as KC's, so we'll call it the "Heartland" setup.
-Steve
p.s. This thread is starting to resemble a typical OT stream of consciousness thread. Sorry, Tom!
Old 05-03-2004, 05:46 PM   #15
solo-x
Member#: 37624
gary beat me to it and did a much better job at explaining it then i ever would.
when you said you softened your shocks when you increased your rear toe-out, did you mean you softened both front and rear? softening just the rear shocks should make the car tighter in slalom's too, not looser so i'm confused by what you said.
nate
solo-x is offline   Reply With Quote
Old 05-03-2004, 07:37 PM   #16
zoomfactor
Member#: 30440
03 WRX
WR Blue
Man - you name it...LOL. Steady state slalom, decreasing radius, etc. The front turns-in so nice now. I just want the back to stick.
I'm sure its over-driver related But I'm going to dial out some camber in the back to see if it has any effect.
Sorry for the hijack Tom.
Old 05-03-2004, 11:21 PM   #17
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Zoom,
What is your camber set at in the rear? Maybe you have too little camber in the rear?
DrBiggly is offline   Reply With Quote
Old 05-04-2004, 12:06 AM   #18
GarySheehan
Member#: 2450
Zoom,
Slalom is the opposite of steady state. It's constant transitions. Steady state is when the car is leaned over in a corner and stays at a constant pitch with neutral throttle.
Gary
www.teamSMR.com
Old 05-04-2004, 02:20 AM   #19
makofoto
Member#: 25243
2006 Legacy Outback
Would a change/addition in LSD's help ...
I noticed on the RallySpec site ... they mention that certain types of LSD's are better for certain surfaces/conditions ...
makofoto is offline   Reply With Quote
Old 05-04-2004, 07:52 AM   #20
MNbiker
Member#: 18148
'08 WRX
Dark Gray
In Tom's case, you bet adding a front LSD would help at corner exit. Unfortunately, diff changes aren't legal in STX.
You SM guys get all the fun toys!
(and the bills to go with them! )
-Steve
p.s. The most recent Grassroots Motorsports has a really good article on differentials.
Old 05-04-2004, 08:09 AM   #21
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Sounds like the nut behind the wheel to me....
Not sure I understand some of your comments. As Gary said, slaloms are anything but steady-state.
With regards to dialing out rear camber, are you talking about going more negative or more postive? If you go more positive, your car will get looser.
Before you do anything, I'd work on the driver issues. Your car is already set up more conservatively than is ideal for autocross. If you're driving smoothly and within the cars capabilities, there's no way it should be anything but benign.
-Steve
p.s. If you want loose, try a 1300lb Birkin (Lotus 7 clone) with 160whp and not enough tire. I scared the crap out of myself in that thing! (and had fun doing it! )
Old 05-04-2004, 09:01 AM   #22
zoomfactor
Member#: 30440
03 WRX
WR Blue
"Steady state" was a poor choice of words
I was trying to describe a steady constant radius slalom.
As far as driving I'm pretty smooth. I think that all of the years of dealing with my MR2's snap oversteer have me "edgy" when I begin to feel rotation at speed and the WRXs open front diff doesn't give that feeling of adequate power to the front.
Thanks for the feedback
As far as the Birkin, my dream car has always been the Lotus/Caterham 7...but now with the USDM Elise there may be a new car on the horizon -- one day.
is the 06 wrx rear bumper the same as the 06 sti rear bumper? sonycrr Newbies & FAQs 6 03-22-2007 09:45 AM
Window motors - rear doors the same as the front? moogoob Service & Maintenance 8 09-24-2005 01:20 AM
aircraft carrier on ebay. doesn't look the same as the other thread plunk10 Off-Topic 35 01-02-2004 09:46 AM
Crash test results for the STi same as the WRX? jcochran STi Forum Archive 42 06-25-2003 03:36 PM
FS locally: Very cool JDM WRX seats! Same as the STI ones but affordable! Check it... JSiwek Bay Area Impreza Club Forum -- BAIC 3 03-14-2003 03:37 AM
