Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 05-03-2004, 01:54 PM   #1
ScoobyMods.com
Vendor Sales Rating: (6)
Member#: 23928
1996 STi 555 RHD
Default Open Loop Manager
This is a brand new product that we are introducing, from Vaus / SubieShack, with the discussion thread over
here
The Open Loop Manager 2, or OLM-2 for short, is the incredible new device for the WRX. This little device is tapped into +5v, ground, MAP, and TPS signals. It watches the MAP signal and once it sees a certain MAP value (boost), it simulates a WOT signal for the ECU. This does two things:
1) It immediately forces the ECU into open loop fueling.
2) If stock boost control is still being used, it makes the ECU shoot for full boost no matter what the actual TPS value is.
Note: For those who have not heard of the PTFB issue, read on. The stock ECU limits boost to ~7psi until you go past 63% throttle (TPS). It also stays in closed loop fueling (stoich a/f of 14.7:1) during this 7psi. When installing an MBC, you will be able to boost a lot more than 7psi at lower throttle positions. The problem is that during this situation, the ECU does not switch to open loop fueling (rich) no matter how much boost you are running as long as you are under 63% throttle. Doing this for an extended period of time causes high EGTs, detonation, and engine damage.
Price is $129.98 + shipping and available for purchase from our website . We have 5 in stock back in stock, so get yours while you can.
Kevin
Kastle's Korner
www.kastleskorner.com
[email protected]
ScoobyMods.com is offline   Reply With Quote
Old 05-03-2004, 09:54 PM   #2
testingtesting123
Member#: 50185
Actually, the unit taps in to +5v, not +12v. If you tap in to +12v you will fry the microcontroller.
testingtesting123 is offline   Reply With Quote
Old 05-03-2004, 11:05 PM   #3
Kwyjibo
Member Sales Rating: (8)
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
quick question....i'm on my way out the door, but will read the other thread later....
If i have a UTEC and Profec B for boost, and get ptfb, can I use this or will the UTEC freak out cause it will constantly see 100% tps??
Kwyjibo is offline   Reply With Quote
Old 05-04-2004, 10:21 AM   #4
cdvma
Member Sales Rating: (11)
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If you have a UTEC you have no use for this device. Tune the UTEC to play nicely with the Profec B.
cdvma is offline   Reply With Quote
Old 05-04-2004, 04:19 PM   #5
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
That is correct. This OLM is more for Manual Boost Controllers or people using the Factory Boost Controller.
Old 05-04-2004, 04:21 PM   #6
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
thanks for the heads up on the typo.
Old 05-04-2004, 04:26 PM   #7
Equilibrium Tuning
Vendor Sales Rating: (1)
Member#: 26933
2006 STI
CGM
Actually, with a UTEC, you could use this device to run PTFB. As I understand it, when running a UTEC, you have to limit boost to wastegate spring pressure bellow the TPS crossover. If you ran the OLM with a UTEC, you could run ptfb all day long, since the OLM would be forcing the UTEC to take over apropriately above 7psi of boost. I'm not a UTEC guru, but I'm pretty sure I understand how it works. If my comments are not completely accurate, please provide the right info
Thanks
-- Ed
__________________
Equilibrium Tuning
631 Railroad Ave. Suite A
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Equilibrium Tuning is offline   Reply With Quote
Old 05-04-2004, 04:37 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Also, lets not forget the unichip crowd. The OLM is pretty much a must for anyone running a unichip (especially in conjunction with an MBC).
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-04-2004, 07:38 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Thanks
-- Ed
He is running the Profec B to control boost, not the UTEC so he can get more than wastegate below the TPS.
Anyways, sorry for messing the thread Kastle.
Old 05-04-2004, 07:48 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
In that case, he could certainly use the OLM to manage his OL/CL crossover.
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-05-2004, 12:02 PM   #11
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
This sounds like revised boostmonkey. Any affiliation with this refunked product?
lstepnio is offline   Reply With Quote
Old 05-05-2004, 12:26 PM   #12
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Super duper NONE.
Old 05-05-2004, 03:37 PM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
This has nothing to do with the boost monkey at all. In the linked discussion thread, that point was raised and the explanation was provided. The boost monkey is a simple two-stage open loop boost controller that used the TPS sensor to switch to the high boost stage. This allowed one to run low boost (7psi) while bellow the 63% TPS crossover, and only run full boost past this point. A car with a boost monkey installed behaved similar to a stock car but with allowed adjustability of the high boost stage.
The OLM on the other hand, allowes you to run as much boost as you want/can at any throttle position using any boost control you like. It does this by converting the TPS triggered OL/CL system to a MAP triggered system. In other words, the OL/CL switchover is no longer based on TPS, but rather on boost, the way it should have been in the first place.
Thanks
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-05-2004, 05:26 PM   #14
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
w/ open loop fueling in the UTEC this should not be needed by anyone w/ a utec.. if you think you need it you need to work on your tuning.
For people who wanted cheaply upgrade power in their WRX an MBC plus one of these should allow some great & still safe power gains for a very small price... I would say the 120 bucks is a small price to pay for safety.
MustGoFast is offline   Reply With Quote
Old 05-05-2004, 06:03 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Agreed... with the new firmware that allows open loop fueling, the OLM is not necessary since the UTEC takes the OL/CL switchover into its own hands.
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-05-2004, 07:43 PM   #16
thoughto
Member Sales Rating: (1)
Member#: 29145
1998 Version 4 STI
White, gold wheels
Can this do anything for cars with an Ecutek reflash, or does the reflash already take care of this issue?
thoughto is offline   Reply With Quote
Old 05-05-2004, 08:06 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
If you want to run an MBC or EBC with a reflashed ECU, then the OLM will provide a nice level of safety. Although most reflashed ECU's allow more boost at partial throttle than stock, it is still possible to make much more boost with an MBC at the same throttle positions. As far as I know, ECU reflashes don't actually change the fact that TPS is used as the main trigger for the OL/CL switchover.
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-06-2004, 12:14 PM   #18
Big Joe
Member#: 3722
2002 WRX Wagon
Easy install? How does it tap into the MAP and TPS?
joe
Big Joe is offline   Reply With Quote
Old 05-06-2004, 02:56 PM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Install is very easy. You will only have to cut one wire (TPS). For MAP, +5, and GND, you'll use the provided tap-in connectors that require no cutting or stripping.
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-08-2004, 01:12 AM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Here are the installation instructions:
http://www.scoobymods.com/forums/showthread.php?t=3548
Thanks
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-08-2004, 02:31 AM   #21
Big Joe
Member#: 3722
2002 WRX Wagon
Thanks for the instructions. I have have a OLM on order.
Me having the auto tranny, wonder if there will be any problems with the TPS wire. I believe wire #7 from the ECU on connector B135 goes to the TPS connector #3 (manual trannys). With auto's, #7 wire will go to connector #3 TPS but will first tap into the auto TCM wire #3 on connector B54 AND wire 12 on connector B209. Whew. I'm referring to page AT-53 in the serivce manual. I can email you the diagram if you don't have it. Comments?
joe
Old 05-08-2004, 03:43 AM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That's interesting.... I'd like to see the diagram for sure, but it sounds like you still need to tap the TPS wire at the ECU harness. Seems like the TPS signal goes from the sensor to the TCM to the ECU. You want to splice the wire so that only the ECU sees the simulated OLM signal. I'm not really sure what would happen if the TCM saw the modified signal... probably nothing good .
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-08-2004, 11:01 AM   #23
Big Joe
Member#: 3722
2002 WRX Wagon
pm'd you.
It should be OK if the auto TCM reads the TPS signal and does not go back to the ECU to read something there. I guess I'll be the first to test.
joe
Old 05-08-2004, 02:54 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I don't really see why it would ever go to the ECU after it already gets the TPS signal. IMO you'll be good do go, but just be careful the on the first drive to make sure. Do you by any chance have deltadash?
-- Ed
__________________
Equilibrium Tuning
Fairfield, CA 94533
Phone: 707-425-2137
Fax: 707-637-8771
Old 05-08-2004, 05:27 PM   #25
Big Joe
Member#: 3722
2002 WRX Wagon
Yes, have DD and will run some logs. I figure if it doesn't work I should get an immediate CEL.
thanks,
joe
Vaus's Open Loop Manager (OLM) imprez25 Car Part Reviews 27 01-01-2005 05:22 PM
open loop vs. closed loop Mancini Normally Aspirated with bolt-on Forced Induction Powertrain 24 09-25-2003 11:55 PM
Open Loop vs Closed Loop UTEC boost map. Example? mav1c Engine Management & Tuning 3 02-01-2003 10:58 PM
open loop VS closed loop iloveturbos Newbies & FAQs 4 11-12-2002 07:33 PM
My thoughts for closed-loop to open-loop with link. Chav Normally Aspirated with bolt-on Forced Induction Powertrain 0 06-28-2002 02:10 PM
