Old 05-03-2004, 04:29 PM   #1
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
Default 99 Manifold on a 01
I keep on hearing that a 99 Manifold is very suitable for the WRX injectors I have an 01 w/ the stock injectors and I am running about 7 pounds of boost I know that my injectors are running at well past their operating range... I was just wondering if anyone has done this on their ride and what are the issues if any did you encountered when you did this change over?
Thanks
I am Frakk is offline   Reply With Quote
Old 05-03-2004, 05:22 PM   #2
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
It'll work on an 01 with a little drilling work. There's a sensor that needs to sit on top of the manifold that needs 1 holes for the sensor and 2 for the screws. The screw holes need to be tapped too. Also, buy new manifold gaskets since the old ones can tear easily.
seven881 is offline   Reply With Quote
Old 05-03-2004, 05:27 PM   #3
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
I would imagine I would need to upgrade my fuel rails to fit the WRX or STi injectors correct?
Old 05-04-2004, 11:30 AM   #4
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Are you trying to get WRX injectors???..... wouldn't it be cheaper to just buy injectors and fuel rails than changing your intake manifold?
maxiav is offline   Reply With Quote
Old 05-04-2004, 11:40 AM   #5
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
or I can do that...as far as I know though or to my knowledge I haven't seen a manufacter that makes fuel rails and injectors for the SOHC EJ25...do you know of any? if so it'll be greatly appreciated...
Old 05-04-2004, 12:27 PM   #6
maxiav
Member#: 40413
2001 BRP RS-T EJ257
I have Vishnu fuel rails and RC550 injectors that fitted beautifully in my car. You need some spacers for the fuel rails, but I believe Vishnu sells those too. NO LEAKS!!! Perfect fit
Old 05-04-2004, 12:47 PM   #7
seven881
Member#: 8828
01 BRP 2.2T Hybrid
The benefit is to be able to use WRX aftermarket injectors or use the WRX injector mod and you'll have fuel for just about any turbo. Also, you won't have to hack your injector harnes or run low impedence injectors when you get bigger. You can use the RS rails with the WRX injectors.
Old 05-04-2004, 02:02 PM   #8
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
Thanks
Old 05-04-2004, 06:23 PM   #9
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
i think you throw a cel if you change the manifolds for the air assist thing in the 00 injectors being disabled, i think kaos200 told me this. I dont know if theres a way around it, its the only thing stopping me from getting a 99 mani cause i dont want a cel constantly
Derk1127 is offline   Reply With Quote
Old 05-04-2004, 06:35 PM   #10
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
Would a CEL damage the engine or make the car not run reliably? or is it something that I can live with?
Old 05-04-2004, 07:11 PM   #11
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
i think its something you can live with but if you live in a state with emissions testing youll fail because of the cel
Old 05-05-2004, 11:52 AM   #12
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
Like California? I'm running straight pipes so right now I am not what you call street legal, as long as it works I think it's fine with me...
Old 05-05-2004, 05:50 PM   #13
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
just anywhere that plugs into obd 2 ports during emissions testing, i know WA does
Old 05-05-2004, 06:26 PM   #14
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
if you are runnign a link or something with its own map sensor u dont need to drill the hole, nor will u see anything like a CEL
akcel is offline   Reply With Quote
Old 05-06-2004, 05:37 PM   #15
SubaFastR
Member#: 5786
You are WRONG sucker!!! The map sensor is also a inlet air temperature sensor.
SubaFastR is offline   Reply With Quote
Old 05-06-2004, 06:06 PM   #16
akcel
Member#: 10268
gc8 I ride ride 24s
but will u see a CEL? NO
Old 05-06-2004, 06:17 PM   #17
I am Frakk
Member#: 35739
01 R.I.P. My GC8
07 WRX WAG0nz FTW!
I see said the blind man...
Old 05-06-2004, 06:18 PM   #18
SubaFastR
Member#: 5786
doesn't mean it's running right.
Old 05-06-2004, 06:38 PM   #19
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
lets just say that he drills the hole for the map and he uses a oem ecu is there a way around the air assist cel? i havent taken out my injectors or anything but is there a way to keep it connected but just not have it do anything just so the CEL wont pop up?
Old 05-06-2004, 06:42 PM   #20
akcel
Member#: 10268
gc8 I ride ride 24s
i denno i havent tried it...kevin?
Old 05-06-2004, 07:41 PM   #21
SubaFastR
Member#: 5786
take out the cel light bulb.
Old 05-06-2004, 09:28 PM   #22
akcel
Member#: 10268
gc8 I ride ride 24s
I think the cel adds character...it was my first mod ;P
Old 05-07-2004, 12:44 AM   #23
Lo0mis
Member#: 12469
2000 2.5 RS
BRP
Damn, not something I wanted to hear. Do you know how important this is to the Links functionality?
Lo0mis is offline   Reply With Quote
Old 05-07-2004, 12:57 AM   #24
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
You can wire in a gm air temp sensor in the intake pipe to your turbo instead.
Drac9 is offline   Reply With Quote
Old 05-07-2004, 02:19 AM   #25
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yeah if someone finds the part # lemme know im too bored/lazy to search
thanks guy!
PS im sure a couple people would like to know that
alex
AT will a 99 rs cruise control module work on a 01 RS Sir Punk Transmission (AT/MT) & Driveline 0 02-27-2009 12:29 PM
the 99 obs and 01 wrx do not take the same filter the 99 obs and the 01 wrx do not kaisersouse General Community 20 05-24-2005 02:57 PM
Whats the difference? 99 RS intake manifold & 00-01 RS? STi - IMPREZA Normally Aspirated Powertrain 10 10-03-2003 09:10 AM
Has anybody used a 99 intake on a 01? Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 15 01-23-2003 11:55 AM
99 sparks on 01? Mantis69 Normally Aspirated Powertrain 1 07-30-2001 02:30 AM
Message Board Statistics All times are GMT -4. The time now is 07:41 AM.
