Vancouver Impreza Club
Old 05-03-2004, 05:30 PM   #1
EA704life
Member#: 39714
05 WRX
Noir
Default Steering wheel Swap
Any idea where I can find DIY instructions on a Sparco steering wheel swap with hub?
thanks
Chris
EA704life is offline   Reply With Quote
Old 05-03-2004, 05:33 PM   #2
fukamoto
Member#: 13339
2014 SWP WRX Wagon
BHWAHA!
I had to go through hell and back to install it ebcause I couldn't find instructions. Its definately a learning experience. I'd offer a hand but I'm not even sure if I installed it right. I'm re-doing the install later this weekend once I get my quick release installed. Still trying to find a way to secure the ground wire ebcause I'm without a horn Ground wire keeps moving away
fukamoto is offline   Reply With Quote
Old 05-03-2004, 07:50 PM   #3
EA704life
Member#: 39714
05 WRX
Noir
It's like trying to find out how to do home surgery.
I'm not worried about a horn since God gave me 2 middle fingers. They seem to work just as well accompanied by a volley of curse words out the window.
Chris
Old 05-03-2004, 08:31 PM   #4
fukamoto
Member#: 13339
2014 SWP WRX Wagon
I just didn't know how to disconnect the cruise control properly, but other than that, its pretty straight forward.
www.scoobymods.com
Go to GC8 >> Interior >> Swapping WRX steerling wheel into the GC8. Its pretty much the same.
Old 05-03-2004, 08:35 PM   #5
EA704life
Member#: 39714
05 WRX
Noir
Thanks. I found that one too so I should be all good unless I blow the airbag and knock myself out.
Old 05-03-2004, 08:37 PM   #6
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Just make sure you disconnect the battery before you do anything or you might get blown away..no pun intended
Old 05-05-2004, 06:31 PM   #7
EA704life
Member#: 39714
05 WRX
Noir
Default this swap is not helping my drinking problem
this has taken more days of my life than drinking ever will.
I get everything off running smoothly until I try and figure out if I really need the 2 sets of wires that plug into the original hub. One undoes by plug but the other seems to be sodder in there. No mal, female bit but melted together. We guessed it was the ground sinc ethe other one looked like all the cruise control wiring. Question is do I need these wires or can we give the yank since I won't be using the horn or the cruise.
Thanks
Chris
Old 05-05-2004, 06:36 PM   #8
fukamoto
Member#: 13339
2014 SWP WRX Wagon
You'll lose cruise control with a Sparco steering wheel. You should hook up the horn as its not too much of a hassle. One wire is for connecting and the blue one is your ground. Once you get everything in, you'll have a grind between your console and your hub. Its horrible.
Old 05-05-2004, 06:41 PM   #9
EA704life
Member#: 39714
05 WRX
Noir
thanks.
Do I basically have to pry them out of the connector and wrap it in? the cruise hook up is a male/female on if I've got it right. I don't care about the cruise control since I rarely use it.
Thanks
Chris
Old 05-05-2004, 06:46 PM   #10
fukamoto
Member#: 13339
2014 SWP WRX Wagon
I can't do it off memory seeing as I don't remember anything past two days. Where in Vancouver do you live? Maybe I can help after I get off work.
The tricky part is ripping everything out, the wires should be self-explanatory. In fact, wires freak the **** outta me but I just fiddled around until it worked.
Old 05-05-2004, 09:14 PM   #11
EA704life
Member#: 39714
05 WRX
Noir
Kits right across from thebeach. I'mm gonna take another stab at it and worst case scenario I have no horn..
Chris
Old 05-06-2004, 03:04 AM   #12
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Well, I'm on the other side of Burrard bridge but I'm totally confused becuase I don't rememebr
Old 05-06-2004, 05:17 AM   #13
bwco
Member#: 44137
grind?
The grind occured because of the hub is grinding the turn signal actutator? that happened with my previous car....
bwco is offline   Reply With Quote
steering wheel swap question: 01 outback wheel to my95 impreza flyguyeddy Interior & Exterior Modification 1 06-06-2010 01:34 PM
Steering wheel swap (4 spoke wrx wheel into sti) cervantes21 Newbies & FAQs 5 06-07-2009 06:37 PM
Help with steering wheel swap & steering lock torque? mekkon Interior & Exterior Modification 4 03-06-2004 08:58 PM
02 WRX OEM Steering Wheel Swap w/ JDM STI Steering Wheel WRXerist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-23-2003 02:36 AM
Steering wheel swap - pics Skeandhu Interior & Exterior Modification 15 03-23-2001 05:35 AM
