Old 05-03-2004, 05:47 PM   #1
rukusduk
Member#: 61098
Default Low boost
My current mods are:
up pipe
turbo back exhaust
Utec running stage 2 map
VF22.
Just put vf22, running 11psi. Have the injectors and fuel pump waiting to be put in, but i am unable to boost more then .8 bar. At first everything was hooked up the way Turbo XS said to with the ABC they provide you with. Messed around with bypassing the factory boost solenoid and just going with ABC and still nothing. went back to factory with no ABC and still 0.8 bar. only until i completely took the line off the wastegate i saw higher boost (and lots of it )
Question is:
Do i need to get a MBC or EBC in order for me to see boost or could it be something else? before when i had my stock turbo on, i could boost as much as i wanted (probably why i needed a new turbo)
rukusduk is offline   Reply With Quote
Old 05-03-2004, 08:39 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
What car?
kastle is offline   Reply With Quote
Old 05-03-2004, 08:42 PM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I will take a wild stab in the dark, WRX!
benjaminetanyahoo is offline   Reply With Quote
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 31 05-18-2006 04:06 PM
Low Boost Low Boost silvarex2004 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-12-2006 08:04 PM
Low boost when low on fuel rich728 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-28-2004 01:26 PM
low boost and low vac. QfactorRS Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-25-2003 01:30 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 10:55 AM
