Old 05-04-2004, 03:05 AM   #1
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
Default Catch Can location
all you rs-t peeps out there, where do you put your catch can at? i finally broke down and made one, no more autozone breather filters jammed into the tubes. - IC
IdenityCrisis is offline   Reply With Quote
Old 05-04-2004, 03:45 AM   #2
kaos200
Member#: 2692
have you relocated your battery to the trunk? opens up ALOT of space
kaos200 is offline   Reply With Quote
Old 05-04-2004, 09:28 AM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
I put mine on the firewall behind the TB after I went FMIC.
Tats is offline   Reply With Quote
Old 05-04-2004, 09:44 AM   #4
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
my supercharger is sitting right there, i think its gunna be going next to the antilock thingy - IC
Old 05-04-2004, 05:26 PM   #5
I am Frakk
Member#: 35739
1 2001 GC8 R.I.P
R.I.P 2007 WRX Wagon
Hey Kaos was it a pain in the ass to relocate your battery to the trunk?
IdentityCrisis here is a pic of my catch can not the best quality since I used my camera phone...but here it is...
I am Frakk is offline   Reply With Quote
Old 05-04-2004, 09:40 PM   #6
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Could you please describe how is hooked up?? I still cant get it,I know Im dumb, I did a search and still cant get it. My catch can only has two outlets
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 05-05-2004, 12:50 AM   #7
kaos200
Member#: 2692
no it wasnt hard, the key is just using the proper wire, get it from a stereo shop, those wires are the most flexible, run it INSIDE THE CAR. and I soldered (with the help of a blowtorch ) all the connectors
Old 05-05-2004, 01:38 AM   #8
Member#: 5354
anyone please care how to hook up mine? it has two outlets. Can I Tee my pcv line to one of the valve breathers, I think this is part of my oil burning problem.
Old 05-05-2004, 01:59 AM   #9
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
THere was an awesome thread started by imprezarsx, if you do a search for "PCV the right way" you will find some good info
Pi7467mp is offline   Reply With Quote
Old 05-05-2004, 03:31 AM   #10
Member#: 5354
Sorry to hijack your thread but since you are also trying to hook up your can, it might worth it.
Ok, I searched and found this pic. I dont get where are these two lines that come from the block. I know the two valve cover breathers but i dont know where are the block ones.
Old 05-05-2004, 09:20 AM   #11
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
This is for someone who is using the STi short block. There is an additional vent on the sti block, that the 2.5rs block doesn't have
Old 05-05-2004, 10:21 AM   #12
Tats
Member#: 5692
WTF? YES! I am
better than you!
I have no bung on my turbo inlet hose for the lines.....can I vent the valve covers and crankcase to atmosphere and just keep the PCV to the manifold with my checkvalve?
Tats.
Old 05-06-2004, 12:53 AM   #13
Tats
Member#: 5692
WTF? YES! I am
better than you!
Anyone?????
Old 05-06-2004, 04:48 PM   #14
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
YES
I am running to the bung-hole on my turbo inlet hose, but I have seen countless people run hoses to the catch-can and the can vents atmospheric. The only advantage to running to you inlet pipe is more vacuum which creates a more negative crankcase pressure....
Kreeger is offline   Reply With Quote
Cusco catch can install+location questions STIRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-26-2007 09:52 PM
Helix Catch Can Install Locations Killian Maynard Member's Car Gallery 8 10-22-2006 04:12 PM
Catch Can Mounting Location ForesterXT04 Forester Forum 11 05-13-2005 09:32 AM
Catch Can Location, Firewall Marketresearch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-12-2003 03:06 PM
Catch can hose locations. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-29-2003 08:38 PM
