Old 05-04-2004, 09:07 AM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default AWD gas tank question
My first question is here.
My second question is also about the gas tank. Does the AWD gas tank have a seperate pump on the opposite side to pump it to the side with the main pump? Just wondering what some people did for their AWD swap.
Brent
scoobyimprza is offline   Reply With Quote
Old 05-04-2004, 06:24 PM   #2
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default tank
Hi Brent. No pump as it is normally thought of. The return line runs the extra fuel from the fuel pressure regulator through a device called a jet pump. This is a siphoning device that works using the Bernulli (sp) principle to "suck" over the gas from the driver side to the sump side. I never have installed this piece in my tank from a 1999 conversion and it still works well. Except I can get only 10 gallons of gas out of the tank and the fuel level sender is lop-sided. The gauge reads full for 150 miles then goes to empty within the next 50 miles. To get the gas over, I run a couple of 1g left hand turns. Gotta fix that someday.
Hope this explains it to you.
Mike McBride
MZM is offline   Reply With Quote
Old 05-04-2004, 11:11 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Haha, I can handle that!
So I'll be okay to not have it plugged in? I just ran the line that comes out of it to one of lines on top of the tank.
Old 05-04-2004, 11:19 PM   #4
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
It works with the limitations mentioned above.
Mike M
Need help installing awd gas tank!! wal.lin Subaru Conversions 11 08-18-2006 03:21 PM
AWD Gas Tank, Really Different..? Natoe Subaru Conversions 10 05-09-2006 10:51 PM
WTB AWD gas tank Wayne_Coots Private 'Wanted' Classifieds 4 03-02-2006 12:30 PM
AWD gas tank questions scoobyimprza Mid Atlantic Impreza Club -- MAIC 3 05-05-2004 10:08 AM
difference between FWD and AWD gas tanks scobaru Subaru Conversions 2 08-11-2003 03:44 PM
