Old 05-04-2004, 12:53 PM   #1
Alfaneggio
Member#: 58430
Default Rough Idle on new car?
I noticed that my car has a unstable idle? Is this normal, Basically it plays it goes from below 1000 to around 800 and then raises up a little more, but most of the time its at 1000. At times I can even feel some vibration or the engine kinda shaking. Car is completely stock with a little over 3k on it.
Alfaneggio is offline   Reply With Quote
Old 05-04-2004, 01:07 PM   #2
happasaiyan
Member#: 37731
idle should be at 750. maybe theres a leak of some sort.
...doh. i remember. i had the same problem when stock. i had to re-tighten the clamps on both ends of the throttlebody <-> intercooler hose. it was a little loose. that would cause irratic idle.
happasaiyan is offline   Reply With Quote
Old 05-04-2004, 02:43 PM   #3
Thumper23
Member#: 11571
that sounds abnormal
even when everything is OK, its gonna shake some
gotta love the boxer engine
Thumper23 is offline   Reply With Quote
Old 05-04-2004, 06:43 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Rough Idle on new car?
Where do you refuel? PA or OH?
Jon [in CT] is offline   Reply With Quote
Old 05-04-2004, 08:25 PM   #5
Alfaneggio
Member#: 58430
CA, haha
Old 05-04-2004, 08:53 PM   #6
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
1. My idle was pretty unstable until around 1k miles - then it smoothed out.
2. Idle is always more erratic/higher when you have the AC on or the car is just warming up.
-st
singletrack is offline   Reply With Quote
Old 05-05-2004, 09:43 PM   #7
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Mine shakes a good bit at idle,i think all Turbo engines idle rough its there nature.I had a 03 Baja non Turbo before this one and when the engine was idling you couldn't tell it was running.Its kinda disapointing that a new car idles this rough.This is my first Turbo car,the power and speed is nice but so is a smooth running engine.I don't think i'll be buying another Turbo car after this one is gone.I've had too many problems for the amount of money spent and only 5 mos old with 5,200 on the clock.
ajabobrut is offline   Reply With Quote
Old 05-06-2004, 04:35 PM   #8
capaWRX
Member#: 37768
MY12 wrx ltd
98 2.0rs (sold!)
Originally posted by happasaiyan
idle should be at 750. maybe theres a leak of some sort ...
750? my wrx and my sti both idle at 500 and around 650 when ac is on... neither burn oil and both are smooth as butter
but 250 rpms is nothing to flame about - im just in that kind of mood
capaWRX is offline   Reply With Quote
Old 05-06-2004, 04:39 PM   #9
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
My STi has done this since day 1. It typically settles in at 500 or so, and will climb as high as 1500 when it's cold. Once amply warmed up it tends to stay at the 500'ish level. I wouldn't be overly worried unless it's still acting as fickle once you're at the 2-3k in mileage.......
Stu
mindchatter is offline   Reply With Quote
Rough idle, need new IAT? graphicsman Service & Maintenance 8 06-06-2010 12:11 PM
Rough idle, misfire CEL, car stumbles when cold roksax Service & Maintenance 6 07-22-2006 03:53 PM
Questions on Rough idle on 06 STI with the following mods... origonalp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-07-2006 11:34 AM
Rough Idle, almost like car will shut off.. Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 03-20-2006 12:12 AM
Slightly Rough Idle in New XT XT_Mike Forester Forum 12 04-12-2004 09:57 AM
