Old 05-04-2004, 02:02 PM   #1
ursine
Member#: 51771
2000 Impreza GC6 SRP
1980 G2 Celica Rally Taxi
Question What to do about my cel?
My cats are throwing a cel. Seeming as though my car was smogged about 5 months ago is it just time to gut the cats until I have to re-smog my car? What is the best way to gut a cat? Is there a way to make the cel turn off?
ursine is offline   Reply With Quote
Old 05-04-2004, 09:55 PM   #2
BlackAndBlue
Member#: 40617
guttin a cat isnt goin to get rid of cel, and ur better off just gettin a straight pipe. there is a cat cel fix but i dunno where it is or whether itll help ya
BlackAndBlue is offline   Reply With Quote
Old 05-04-2004, 10:05 PM   #3
blueimpreza25rs
Member#: 21821
2004 Fxt
Psm
blueimpreza25rs is offline   Reply With Quote
Old 05-04-2004, 11:56 PM   #4
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
I have the Mil eliminator and a scan tool. I can pass by also.
joubtt is offline   Reply With Quote
Old 05-05-2004, 02:21 AM   #5
ursine
Member#: 51771
Well I just would rather gut the pipe instead of buy something. And I know it wont make the cel go away, but is there a cel fix I could use for after I gut the pipe?
Old 05-05-2004, 02:24 AM   #6
ursine
Member#: 51771
I got ya, I will definately hit you up after I gut the pipe
Old 05-05-2004, 12:17 PM   #7
00RScoupe
Member#: 57535
2004 FXT
Maroon
The Pep eliminator is designed to be run on cars with no cat. So if you gut it and us the PEP eliminator you should be good to go. Those running track pipes have reported good luck with that combo.
Before cutting up an O2 you might try the Flat 4 extender. It is the same price, seems to work well, and can be installed in about two minutes.
Here's my thread on the subject from RS25.com
http://www.rs25.com/forums/showthrea...anical+CEL+fix
00RScoupe is offline   Reply With Quote
Old 05-05-2004, 01:04 PM   #8
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
You should get the code read, it might not be a Cat failure code. Then go to this thread:http://forums.nasioc.com/forums/show...hreadid=298963 and figure out what it is and what needs to be done to fix it.
JewPac42 is offline   Reply With Quote
Old 05-05-2004, 01:14 PM   #9
ursine
Member#: 51771
Well I know its a cat failure code and when I checked it out I found that my cats need replacing, but instead of replacing them yet I thought I would gut them and have some fun before I had to spend money.
Old 05-05-2004, 01:42 PM   #10
Julian
Member#: 1182
MY00 RS
BRP
Ursine, you never listen to anything anyone says. What code is your car giving you? P0420? That could just as easily be a bad rear O2 sensor. Or half a dozen other problems. If your car passed smog, the cats are probably good (unless you did something to them in the last five months).
Post your code. If you know what it is and know what you think you're going to do, why ursine worthless post?
Julian is offline   Reply With Quote
Old 05-05-2004, 02:52 PM   #11
ursine
Member#: 51771
Well I took my car into my friends shop and they pulled the code, on the code reader machine it said it was either an exhaust leak or a bad cat, I checked but no leaks were found so henceforth, it must be a bad cat. And I dont want to buy a new cat so I figured I would just gut mine for the time being.
And why do you say I never listen, you are the one not reading my post. I asked how to gut my cats and how to fix the cel, not how to fix the code that is being thrown, I already have that part covered.
Old 05-05-2004, 06:22 PM   #12
Julian
Member#: 1182
MY00 RS
BRP
You're operating under the assumption that your cats are bad. You're not reading JewPac's post. If you want to gut your cats, go ahead and try. Have fun. When you fail and you're screwed, don't come back and whine about it.
OR, you could figure out what code is being sent by the ECU and run down the checks to figure out the problem. If you did nothing to them in the 5 months since your cats passed the smog test, they most probably did not end themselves since. You still haven't posted the code. And unless you removed the exhaust and replaced all the gaskets, it is possible you missed an exhaust leak.
Old 05-05-2004, 08:03 PM   #13
ursine
Member#: 51771
Well I am working frantically to try to get my car ready for Rim so when I get back on Monday I will pull the code again so you guys can help me out.
Old 05-05-2004, 08:35 PM   #14
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I'll bet my 2 cents that it's a cat inefficiency code.
Tim Sanderson is offline   Reply With Quote
Old 05-19-2004, 01:46 PM   #15
ursine
Member#: 51771
Alright everyone, I pulled the code and it was P0420 (I think, I just remember it had 420 in it). What should I do or what does it mean?
Old 05-19-2004, 01:49 PM   #16
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Check out the mechanical CEL fix that was discussed a while ago. It's a $5 part from pep-boys and some drilling.
BlkTS02 is offline   Reply With Quote
Old 05-19-2004, 02:19 PM   #17
Julian
Member#: 1182
MY00 RS
BRP
Search, n00b. P0420 is the most common OBD code in N/A. If you can't read the above responses, and you won't search...
Old 05-19-2004, 03:00 PM   #18
ursine
Member#: 51771
I have the cel fix, I just havent installed it yet, but what is it that actually causes it?
Old 05-19-2004, 04:35 PM   #19
Julian
Member#: 1182
MY00 RS
BRP
Give the man a fish, he eats for a day. Teach the man to search, dotdotdot
Old 05-19-2004, 05:16 PM   #20
ursine
Member#: 51771
So are you just going to continue to be a deusch bag or are you going to help me? You said to get the code and I did, I tried to search and didnt find the info I needed. So either help me or shut the fcuk up.
Old 05-19-2004, 06:29 PM   #21
Julian
Member#: 1182
MY00 RS
BRP
I did help you. Ten years from now, you'll look back and be amazed at how much I helped you out. If you did search and didn't find the information you needed,
Old 05-19-2004, 06:34 PM   #22
ursine
Member#: 51771
I find plenty of info on how I need to use a CEL fix on the rear o2 sensor to make the light not come on but most threads say that I should try the mechanical fix before I use the thing I need to solder in. Do have a link to directions on making the mechanical CEL fix or can you tell me how to do it? I have the MIL eliminator thing but I want to try anythign else I can before I start hacking up my o2 sensor.
Sorry for getting pissed, I just get frustrated when people tell me to "search n00b" when I have and havent found the answer.
Old 05-19-2004, 10:21 PM   #23
BlkTS02
Member#: 50142
2002 2.5TS
MBP
http://forums.nasioc.com/forums/sho...960#post4813960
Check out the link for info on the mechanical CEL fix.
Old 05-20-2004, 03:16 AM   #24
ursine
Member#: 51771
Linky no worky
Old 05-20-2004, 09:24 AM   #25
BlkTS02
Member#: 50142
2002 2.5TS
MBP
What to do about my car; input appreciated! Stivie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 03-24-2009 07:16 PM
What to do about my Tails dewmudgeon Interior & Exterior Modification 18 11-22-2007 05:51 PM
What to do about my tint ticket? sonicblue Off-Topic 36 05-02-2007 10:40 AM
Serious question about what to do about my job *Now with 100% more resolution!* WagonMonster Off-Topic 118 11-08-2006 12:19 PM
What to do about my Superleggera's HS WRB-rex Tire & Wheel 0 12-14-2003 12:16 AM
