Old 05-04-2004, 02:09 PM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Default valves?
does anyone know who makes valves for the 98 2.5/DOHC?
ive been trying to find some but it seems that you can only get them thrue subaru....
is subaru(oem) the only option or are there companies that make them?
snowman4us is offline   Reply With Quote
Old 05-04-2004, 02:44 PM   #2
obyone
Member#: 16523
What do you have in mind? Depending on what your goal/budget is, you may not need new valves.
obyone is offline   Reply With Quote
Old 05-04-2004, 07:20 PM   #3
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
get the sodium filled sti ones if your worried!
darioc is offline   Reply With Quote
Old 05-04-2004, 07:43 PM   #4
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Paeco does
jasona is offline   Reply With Quote
Old 05-05-2004, 05:25 PM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
im asking becoue im helping my buddy rebuild his engine and we wanted to see what we could get....and he isnt planing to run boost(in this engine)....he just needs something to last him like 2 months while he builds up a EJ22T
Old 05-06-2004, 02:01 AM   #6
Section 8
Member#: 821
Buying a set of junkyard heads for $300.00 is porbably going to be the most cost effective method for obtaining a full set of valves.
Vaves are just about the last thing that you need to worry about.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
TMIC bypass valve to intercooler bolts nolanator SCIC Private Classifieds 3 06-02-2010 03:06 PM
bypass valve hardware ?? nolanator Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-02-2010 11:26 AM
Need to buy stock recirc valve, bypass valve, blowoff valve, whatever u call it!! newbie-subie SCIC Private Classifieds 2 02-12-2009 03:35 AM
valve-to-piston + valve-valve clearance specs? HamFist Built Motor Discussion 9 08-13-2006 05:04 AM
Bypass Valve vs. Blowoff Valve kid 13 Normally Aspirated with bolt-on Forced Induction Powertrain 7 04-30-2002 08:53 AM
