#1 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
I've heard of a failing front crank seal, but what about the rear? I've always had a small oil leak that I couldn't pinpoint and now I pulled my tranny for my AWD swap (YAY!) I think I've found it to be the rear crank seal.
Info? Thanks! Brent
#2 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
I have the same leak. It is a slow leak. I would have changed it but did not foresee it and did not order a new one. So, mine is still leaking slowly.
I imagine it is pretty common. The oil tends to gob up with the clutch disk dust and thicken enough to not drip for a while. So it is'nt really found for quite some time. There is an inspection cover that can be removed for finding this leak. Though I believe it may require lifting the engine a tad to gain access to the bolts. Good luck with your awd swap. |
#3 |
Member#: 24956
Thanks for the info. Tomorrow when I take the flywheel off, I'll better inspect the seal and probably order it then.
#4 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper Wagon |
Also, the oil seperator plate on older engines is plastic and tends to leak. Get the replacement aluminum one for ~$30.
I think 2001 it was changed, maybe 2000? Prior to that it was plastic. |
#5 |
Member#: 60743
Vehicle:'95 Impreza L dirty and on jack stands |
yep they started of metal and didnt leak switched to plastic and the leak and now they switched back to metal and guess what, no leak.
| Thread Tools | |
| Display Modes | |
| Picture of Oil crank seal? | SubaruImpreza_power | Service & Maintenance | 3 | 02-26-2004 08:47 AM |
| leaky crank seal | synapse79 | Normally Aspirated Powertrain | 10 | 08-09-2002 09:42 PM |
| Changing Crank Seal...anyone have? | jmseven7 | Newbies & FAQs | 0 | 04-22-2002 02:41 PM |
| Replaced crank seal? Complain to NHTSA NOW. | rrubel | Legacy Forum | 4 | 11-03-2001 03:40 PM |
| Crank seal, Headgasket, etc... in 1000mi | minix42@ | Normally Aspirated Powertrain | 3 | 07-25-2001 04:31 PM |
