Old 05-04-2004, 07:23 PM   #1
WRX8U82
Member#: 38080
Default Greddy Type-s BOV...My car keeps dying???
I have the Greddy type-s BOV for my WRX...w/o the Recirc. kit....how do I prevent my car from dying? Is it even possilbe? Any help would be good? I try and tighten the screw on the top, but after awhile it just gets loose again....
There is two vaccum lines, i'm using the main one and the other is plugged.
HELP!
WRX8U82 is offline   Reply With Quote
Old 05-04-2004, 09:00 PM   #2
ZeroFourWRX
Member#: 44660
2004 WRX
When you say "dying" does that mean the car stalls out?
ZeroFourWRX is offline   Reply With Quote
Old 05-05-2004, 06:52 AM   #3
WRX8U82
Member#: 38080
Yah..stall..die...choke..
Old 05-05-2004, 08:01 AM   #4
1DOWNCLOWN
Member#: 50287
02 WRX
vac leak?
1DOWNCLOWN is offline   Reply With Quote
Old 05-05-2004, 08:37 AM   #5
I_say
Member#: 55122
get the recirculating kit. ive heard of cars stalling out because they were running to much to the atmosphere. put the stock back on and see what happens.
I_say is offline   Reply With Quote
Old 05-05-2004, 12:47 PM   #6
strohausii
Member#: 26770
'02 WRX
midnight black
yeah, the engine is expecting the air you are venting (MAF sensor property). so the ecu is gassin as normal but the air isn't there.
strohausii is offline   Reply With Quote
Old 05-05-2004, 01:04 PM   #7
cnk
Member#: 10757
2013 BRZ Limited 6MT
Using an atmospheric BOV does not cause your engine to die. It causes a momentary rich condition during shifting. The only way your car is stalling is if there is a leak in the intake track. It can also be caused by a BOV that is adjusted to be too loose. The Greddy BOV has also been known to have a leak in the diaphram. It doesn't occur for everyone, but on some BOV's, it's there. This could be the reason for your car stalling. Also, turning the nut does nothing. You're supposed to loosen the nut and then use an allen key to turn the actual post. The nut is there to prevent the adjustment from backing out.
Calvin
cnk is offline   Reply With Quote
Old 05-05-2004, 01:15 PM   #8
cnk
Member#: 10757
Old 05-05-2004, 06:40 PM   #9
WRX8U82
Member#: 38080
Thanks Calvin
Old 05-05-2004, 08:13 PM   #10
cnk
Member#: 10757
No problem. . .let us know how it turns out.
Calvin
Old 05-05-2004, 09:17 PM   #11
LqSilver
Member#: 39780
04 Wrx Sedan
World Rally Blue
WRX8U82 I see you are having some problems. Ok, first of all, do you have both springs inside the bov?
Meaning the bigger spring and the small softer spring? You need them both in the blow off valve for it to stay closed at idle.
The reason your car dies as soon as you try to start it is because you probably dont have both springs installed so it doesnt have enough force to keep the valve closed.
If you already have both springs installed then make sure that everything is tightened correctly and that the bov is seated correctly on the intercooler (or wherever you have it mounted) and that there are no leaks.
Dont pay attention to my post that cnk linked to yet.
Do you have a washer for the screw on top of the bov?
If not, then you need to get one so that when you tighten the blow off valve it doesnt unscrew itself and get any looser (thats what the washer is for).
Let me know how things go so I can continue to help you troubleshoot things.
LqSilver is offline   Reply With Quote
Old 05-06-2004, 09:25 AM   #12
strohausii
Member#: 26770
'02 WRX
midnight black
so which bov is best? for a near stock car so I can get to whootwhoot? (i'm being serious with my joke tho)
Have a free Greddy Type-S BOV,, should I put it on my car? trail*of*dead Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-25-2004 12:21 AM
WTT: My HKS SSQV BOV, for Greddy Type S BOV adamsrs Private 'For Sale' Classifieds 1 07-20-2004 01:04 PM
My car keeps dying MattDell Mid Atlantic Impreza Club -- MAIC 9 12-03-2002 09:37 PM
My car keeps dying MattDell Normally Aspirated Powertrain 2 12-01-2002 12:34 AM
Ok, my car keeps dying on me...what's up? Sauginius Southern California Impreza Club Forum -- SCIC 6 11-07-2000 12:01 AM
