Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 05-06-2004, 10:40 AM   #1
SCutchins
Member#: 59209
2004 Forester XT
Cayenne Red Pearl
Question Auto HVAC self-diagnostic
Not sure everyone with auto climate control has seen this self-diagnostic thread on scoobymods:
http://www.scoobymods.com/forums/showthread.php?t=2801
I found out about this diagnostic and ran it this morning, and after the end of the 6-step sensor check my def/heat light flashes continuously, which if I read the attachment in the above thread correctly means that my "sun load sensor" has a problem.
Any thoughts on this? Am I reading this correctly? The dealer just installed the factory boost gauge, did they somehow disconnect the sun load sensor?
SCutchins is offline   Reply With Quote
Old 05-06-2004, 10:59 PM   #2
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Someone else had problems w/ their HVAC after a boost guage install. For them it seemed that they did not plug the harness back in all the way. When you install the gauge you have to remove the radio and the trim in front of it. That involves taking the HVAC harness off the controls. Wonder if they messed something up.
I have pics on the install of the guage on our site.
Peaty
Peaty is offline   Reply With Quote
Old 05-07-2004, 02:03 PM   #3
SCutchins
Member#: 59209
2004 Forester XT
Cayenne Red Pearl
I just thought of something, the dealer also installed the air cleaner, did they have to unplug any harnesses when they were taking out the glovebox or working behind it?
I assume the Sun Load Sensor is the one up by the passenger side windshield, is that correct?
Old 05-07-2004, 02:23 PM   #4
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
When doing the cabin air filter you don't have to unplug any harneses (that's not to say they didn't hit something by accident)
The sun load sensor it a plastic button looking thing on the dash by the glass.
Old 05-10-2004, 10:36 AM   #5
SCutchins
Member#: 59209
2004 Forester XT
Cayenne Red Pearl
Default Problem found - Sun Load Sensor must be tested in sun
Good news, the sun load sensor was working correctly but to test it you have to be out in the sun. When I checked it the first time I was in the garage, so the warning light from the diagnosis meant that the sensor wasn't sending a signal. I rested a spotlight on the window and voila, a signal, so all is working correctly.
Man. HVAC to Auto HVAC Swap help please! Buc Em Interior & Exterior Modification 5 01-22-2011 08:26 PM
02 HVAC swapped with 05+ auto HVAC Loomin Interior & Exterior Modification 14 01-04-2009 03:22 AM
self diagnostic dblok4eva 'Old School' Subaru Forum 0 10-28-2007 06:00 AM
Self Diagnostic test? SubaruLover General Community 2 08-10-2002 10:39 PM
ABS Codes & Self Diagnostic arejay SVX Forum Archive 6 02-18-2001 09:42 PM
