Old 05-06-2004, 09:15 PM   #1
abaxter34
Member#: 34723
fwd FTL!
Default 3 point harness install question
i have a sparco 3 point driver side harness i tried installing but had no luck with. my problem was with the lap belt part of the harness. the drivers right side lap belt part of the harness, the section from the buckle to the mounting point, is longer than the left side which from what i have seen on other harnesses is correct. however, after i bolted each end of the lap belt to the factory seatbelt mounts the right side of the lap belt is still too long, even after being sinched up all the way. by the time i get the lap belt pulled tight enough by sinching up the left side lap belt, the right shoulder harness is pulled to the middle of my waist. i tried moving the belt mount to the seat bracket bolt on the right side slightly begind the driver on the sliding mechanism which took care of the slack but the belt mount was stuck in a really awkward, unsafe looking angle. is there another way i should be mounting the lap belt to get rid of this extra slack? i bought the harness off of a nasioc member so i cant return them. id like to make it work but not if its unsafe.
another question separate from the lap belt issue is the mounting point for the shoulder harness. the incredibly crappy instructions recommend using the rear seat lap belt location but i know schroth recommends the c-pillar. which would you recommend?
link to harness im trying to install
abaxter34 is offline   Reply With Quote
Old 05-06-2004, 10:06 PM   #2
abaxter34
Member#: 34723
fwd FTL!
an afterthought: the lap belt is sewn around the sliding adjuster, which is why i cant get rid of the extra slack. if i were to cut the stitching and use sparco's belt looping technique to take care of the slack, would it still be safe to use?
FS: Seat Belt Harness and 3-Point Harnesses WRXSuShi Interior/Dressup/Audio & Security 2 02-28-2010 10:38 PM
Where to point a 3-point harness in 09 WRX Hatch CletusTheDwarf Interior & Exterior Modification 1 04-04-2009 07:09 PM
3 point harness install? harrisont Interior & Exterior Modification 5 03-04-2009 10:48 PM
3,4,5 point harness install? LB2.5rs Interior & Exterior Modification 5 09-02-2003 01:15 PM
('93-'01) Sabelt 3-point harness bryanw Impreza Forum 3 04-17-2001 09:32 AM
Message Board Statistics All times are GMT -4. The time now is 04:15 AM.
