Old 05-06-2004, 11:33 PM   #1
wickedscooby
Member#: 55963
99rs sti v5 LISC #57
Default turbo kits- FAT stage III vs. AVO
im looking for some info about FAT stage III and AVO kits. i have a 99 rs and im looking to do pistons and rods. would that be feasible? and if i wanted like 9 lbs of boost i would just have to change the spring in the wastegate right? thanx alot -dave-
wickedscooby is offline   Reply With Quote
Old 05-07-2004, 04:44 PM   #2
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
On the FAT i believe yes. for the AVO i think you have to get a boost controler. External vs Interna. but if you do pistons, i would run more than 9. prob like 12-14psi
-Eli
squirrelmasta is offline   Reply With Quote
Old 05-07-2004, 09:06 PM   #3
wickedscooby
Member#: 55963
would the 2.5 N/A block take 12 psi?
Old 05-07-2004, 09:17 PM   #4
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
With good tuning and correct pistons, rods and rings... yes. You might not even need all that stuff. I've known a couple people that daily drove 12psi for a while on stock 2.5 internals (the motors did blow after a while, so I wouldn't recommend it though!).
To run higher than the standard wastegate boost, you just need a boost controller (electronic or manual).
-Charlie
phattyduck is offline   Reply With Quote
Old 05-07-2004, 09:40 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
-Charlie
Then that wouldn't exactly be a 2.5 N/A block....
kastle is offline   Reply With Quote
Old 05-07-2004, 11:16 PM   #6
squirrelmasta
Member#: 33445
Cherry Red
Stock block yes. stock internals no. but i think the block would be fine on 12 psi if you lowered the compression to 8.5:1 or 8:1. but if you are going that rought, and want to run that kind of psi, why not just go STi block and run 15. Just my, plunk, plunk 2 cents.
-Eli
Old 05-08-2004, 01:12 AM   #7
wickedscooby
Member#: 55963
Talking
yea i thought about that and i wanted to stay within a budget to get it done. if i had about 15k to drop into my car i would drop in a sti block and get the whole driveline redone, and make a crazy race car.......................maybe in a few years
Old 05-08-2004, 01:48 AM   #8
wickedscooby
Member#: 55963
and would my 2.5 liter heads work on an sti shortblock?
Old 05-08-2004, 02:00 AM   #9
squirrelmasta
Member#: 33445
Cherry Red
yes. i believe its around $1400 for the block, pistons, rods, and crank. not sure on that though. don't know if that is SOHC or DOHC. 99's are the best though!!!!
-Eli
Old 05-08-2004, 02:15 AM   #10
wickedscooby
Member#: 55963
i agree!
Old 05-08-2004, 05:35 AM   #11
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default DOHC
actualy 98s are the best and half of those 99s with duel overhead cams
but anyway. get an ej22t. its better than an sti block for many reasons.
1: fully closed deck block as oposed to the STI's semi closed deck
2: there is no drilling and cutting to get the coolant passages to line up to your heads!
3: forged crank and rods, ceramic heated treated pistons,STOCK!
4: gives you a lower compression ratio which means MORE boost before detonation which can equal up to some KILLER high end torque!
dont spend a DIME on your stock RS block if you want to go force fed. Its completely open deck. and it's built for N/A use....NOT forced induction.
check out this thread about the ej22t: go to the 2nd page about halfway down and start reading everything xephyr posts. That guy is the man!
http://forums.nasioc.com/forums/show...ighlight=ej22t
IllNastyImpreza is offline   Reply With Quote
Old 05-08-2004, 03:40 PM   #12
squirrelmasta
Member#: 33445
Cherry Red
the old EJ22T was that SOCH or DOHC? i just don't know if i can part with the 2.5
-Eli
Old 05-08-2004, 05:55 PM   #13
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
DOHC but the heads are quite out-dated. People seem to like using the RS heads on that, although there are some thought-to-be problems with oil passages not lining up or something...
-Ben
Soon2BturbodRS is offline   Reply With Quote
Old 05-09-2004, 02:30 AM   #14
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Cool ej22t
the ej22t is a COMPLETE bolt on to your RS heads... that is IF you have the DOHC. If you have the later edition SOHC with the roller cams be warned. SOHC are not recomended for this. as you can not dial in cam timing(aftermarket cams). Under high boost some of your intake air is lost straight out the exhaust port during compresion. DOH ! though......it still works.
the legacy turbo heads dont flow verry well @ all.
INTAKE FLOW DATA
IN MAX FLOW @ MAX LIFT
EJ25 SOHC: 240 CFM @ 0.375" Lift
EJ22T SOHC: 193 CFM @ 0.350" Lift
GM LS1: 231 CFM @ 0.500" Lift
EXHAUST FLOW DATA
EX MAX FLOW @ MAX LIFT
EJ25 SOHC: 182 CFM @ 0.310" Lift
EJ22T SOHC: 147 CFM @ 0.350" Lift
GM LS1: 193 CFM @ 0.500" Lift
gives u a little comparison....
so in short, 98 RS DOHC heads with ej22t block= BULLETPROOF bottom end.
and as far as a turbo kit goes...why spend twice as much on a "kit" when you can buy the parts seperatly and save a SZHITLOAD of money.
just my 2 cents
Old 05-09-2004, 09:48 PM   #15
wickedscooby
Member#: 55963
i have the SOHC so i would have to buy new heads if i got a ej22t block. i just dont wanna do the leg work with building my own turbo set up.
Old 05-09-2004, 10:09 PM   #16
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
btw, AVO kit is soo much better than the FAT st3 because of 2 things: Better quality and standalone!
Old 05-09-2004, 10:46 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
There is so much wrong with this thread that I don't know where to start.
1.EJ22T's were a SOHC engine with the old hydraulic lash adjusters. They flow OK, and would be fine for anyone who doesn't have better heads to work with. There are several guys making close to 300CHP with stock heads and TD05's.
2. Larry Witherspoon decided he didn't like how the SOHC ej25 heads lined up to the EJ22T block, so he didn't do it. Somehow this has become one of those internet myths that they won't work. There are a couple of guys on this very board using SOHC EJ25 heads with EJ22T bottom ends. It can and has been done.
3. The guys who have done this did not cut and drill oil passages! They just block them with a head gasket.
4.Lower compression is not the end all fix to detonation woes. And going with lower CR affects driveability off boost, so you better have a turbo that is perfectly mated to your block and spools real early. And stand alone engine management is a must. Some dude up in the NW blew up his EJ22T block w/EJ25 heads because he had detonation.
5. This is the first I have heard of EJ22T's having ceramic treated pistons.
6. If the EJ22T block is SOOOO superior, how come Marc Rameriz aka Xephyr has sold all of his EJ22 blocks and now runs and EJ257 in his RS-T? They are both good blocks.
7. Going rate on an EJ257 is $1250 including gaskets. If you pay more you are getting ripped off.
8. The SOHC cams on the EJ25 do not have a problem with FI applications. The intake air is lost straight out the exhaust port during combustion? Only if you have huge overlap aftermarket cams designed for NA use will that happen. Look at Graham's build. EJ257 block with SOHC EJ25 heads with stock cams and upgraded springs.
And what does any of this have to do with AVO vs. FAT? NOTHING AT ALL. But I just couldn't sit by and watch such ignorant misinformation being spewed all over the place...
Old 05-09-2004, 11:15 PM   #18
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
If I was as informed as you, I'd be pissed too
Old 05-10-2004, 01:09 AM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
BTW,
YOU never bothered to reply and tell me you weren't interested in either of my Ej22T blocks...
Old 05-10-2004, 01:31 AM   #20
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
oh damn, PM'd you.
Old 05-10-2004, 09:02 PM   #21
wickedscooby
Member#: 55963
thanx for the info matt. i think im gonna stick with my 2.5 SOHC block and heads. im just gonna throw in je pistons eagle rods and see how well they perform with the turbo kit. what would u suggest to do with my block
Old 05-11-2004, 02:20 AM   #22
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Impreza GC8 ej22t
obviously matt you like to settle for mediocre. 300 crank HP? its common sence that a FULLY closed deck block, is stronger than a SEMI closed deck block.
"lower CR affects driveability off boost"....I dono about you, but I'm not not exacltly a sunday driver, I'm talking about performance... PERIOD. I dont even drive my car unless the pedal is on the floor.why use the stock crappy restrictive head when it only takes a little bit of inginuity to construct a MONSTER.
I was simply giving INFORMATION, not wasting everyone's time(like I am now) to bash someone who I disagree with.
You like the STI block, thats nice.
and as far as the thread goes, I was simply progressing the inevitable....>Once you get a turbo, you want MORE boost! And Wickedscooby, why spend all that money on rods and pistons and the hassel to rip it ALL out and put it back together? thats a decent amount of money. like Matt said even the STI block is around 1250 bucks! Thats RELIABLE 450+ crank HP capability.Dont even get me started on how much better then ej22t is.
PLEASE talk with someone with some long time experience if you're gona spend all that money. Living up to his reputation, Mark AKA zephyr can answer pretty much ANY question you ask him. Mark I hope you dont mind
O yea BTW why dont you ask him why hes TESTING the STI now?
Toronto: EJ251 RS-T Turbo Kit FAT, Vishnu, etc. agryguc 1993 - 2001 Impreza Specific Parts 3 12-28-2009 04:33 AM
2.5 Rs Turbo Kit!!!minnam Stage 2 Really Cheap!! subyrscanada Private 'For Sale' Classifieds 5 02-06-2005 11:41 PM
AVO Turbo Kit vs TSI Turbo Kit Mechkiller31st Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-01-2004 08:02 PM
Which turbo kit ? AVO vs. Ludespeed vs.ForcedAirTech wighti Normally Aspirated with bolt-on Forced Induction Powertrain 72 09-12-2003 04:19 PM
Ludespeed Stage III VS Forced Air Tech Stage III VS AVO kit Blu25RS02 Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-23-2003 11:56 AM
