05-26-2000, 02:45 PM | #1 |
Member#: 907
Vehicle:2002 WRX Sedan Silver |
Solid Aluminum End Links!
who has these links? i here they are the best things since sliced bread.. but i heard the ride is compromised. i am running the whiteline adj. bar on the 20mm setting and i'm not a super hardcore rally driver and i haven't caught the auto-x bug (yet!). So keep that in mind. And how good (or bad) are the whiteline links, i like the price! any info to help me make my decision will be greatly apreciated.
shaun
05-26-2000, 03:00 PM | #2 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
Maybe you should look at this - http://www.i-club.com/ubb-files/Forum2/HTML/001168.html
Or this - http://www.i-club.com/ubb-files/Forum2/HTML/001071.html Or this - http://www.i-club.com/ubb-files/Forum1/HTML/008653.html Or... <u>LEARN TO SEARCH!</u> |
05-26-2000, 03:09 PM | #3 |
Member#: 1352
Vehicle:2005 Forester XT black |
I was interested in those also...at one point. After lying under my car for many
hours and also watching those links bend and twist when jacking up the car I decided that solid links would take away a lot of the "play" in the rear end. I have 20mm rear sway bar and AGX's and to me that is enough for autox. I'm just guessing here, but would imagine that solid links would cause inside tire lift during hard cornering as well as side to side "camel ride" when negotiating certain terrain changes (i.e. driveways). I would imagine having to upgrade the sway bar mount bushings also...stiffness would probably mangle the stock ones. Ok, those with solid links, am I wrong? |
05-26-2000, 03:14 PM | #4 |
Member#: 1352
Thanks 8C. I gotta type faster to keep up with you guys! SEARCH THIS!
05-26-2000, 05:08 PM | #5 |
LOL NOSS...
Honestly... last weekend I ran an autocross with a 22mm rear sway bar setting and stock RE92's with OEM rear links. I brought the inside rear tire up off the ground 3-4" most people said. Honestly, if it is off the ground, chances are you don't need it on the ground. Endlinks in general create a better response to sudden actions (turning, etc) and IMHO make the car much more of a pleasure to drive. I am still awaiting rear links from Greg, but I have on MRT front links right now. They are ok, but I've got a solid set I made that I am going to put on soon, hopefully. Those will make my steering response even better. |
05-26-2000, 06:06 PM | #6 |
Member#: 1352
Wow! I don't know about NOT needing any of
tires on the ground but that 22mm bar must be a b*tch-slapper! I used to raise the inside rear on my VR6 Jetta all the time, but that was with full race suspension and a 29mm rear bar! Yiiihaaa, used to go up about a foot on real tight turns!Damn 8, with solid fronts & rears and upgraded suspensions we should be able to get a FRONT wheel lift too! Just like Porsches! |
05-26-2000, 08:00 PM | #7 |
Member#: 907
8complex,
i DID search and i read all those threads BEFORE i posted.. i was looking for opinion. I read all of those posts w/ YOU reviewing them. i wanted another opinion and i wanted to know if the the advantages out weighed the disadvantages for normal street driving. So please read the post.. i'm not as stupid as i look (even though i do look pretty stupid). shaun |
Solid rear end links - 04 WRX | Wagon Jon | Private 'Wanted' Classifieds | 0 | 04-26-2006 05:47 PM |
WTB solid rear end links | Rock_Strongo | Private 'Wanted' Classifieds | 1 | 05-07-2005 11:29 AM |
Perrin Sti Solid Rear End Links | red97LegacyGT | Private 'For Sale' Classifieds | 5 | 05-03-2005 10:30 PM |
FS: SPO Motorsports solid rear-end links. | Opie | South East Region Forum | 7 | 02-25-2002 07:59 AM |
Solid front end links | Mr. Gasket | Technical Forum Archive | 2 | 06-18-2000 09:38 PM |
