Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 04-26-2000, 04:22 PM   #1
Corey
Member#: 618
2000 2.5 RS #89 STS
MODERacing / Bridgestone
Have a Nice Day? Ground Control Rattle/Banging/Noise problem! HELP
I installed my Ground Control springs and KYB/AGX struts this weekend. I lowered the car exactly 1" from stock. I have a rattle comming from all 4 corners now. I have deduced that it is the top hats for the springs banging against the strut piston rods. The hole in the middle of them is just a bit too big to fit snugly on the piston. Anybody else deal with this problem? Anybody have any ideas?
Corey is offline
Old 04-26-2000, 06:43 PM   #2
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
I wonder if this is the same problem I'm having, but only on my front passanger side. I thought at first that it was the speed sensor bracket, but after tying it down better it made no difference. I never really thought that it might be the hats, but it is very possible. You can't really have a "perfect" fit around the piston so the hats must move some.
Strepto is offline
Old 04-27-2000, 03:35 AM   #3
Corey
Member#: 618
2000 2.5 RS #89 STS
Post
To assure myself that it was the hats I wrapped electrical tape around the top of the piston and jammed the hat up over it. What do ya know, the noise went away. It is not a permenant fix though because it came back in a day when the tape wore through. I think there is alot of play, more than needed, maybe GC sent the wrong ones?
Corey is offline
Old 04-27-2000, 08:03 AM   #4
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Question
Did you safety wire or zip-tie the hat to the spring?
Tony
Tony is offline
Old 04-27-2000, 08:32 AM   #5
Corey
Member#: 618
2000 2.5 RS #89 STS
Post
Yep. I zip tied it through the hole in the hat and around the top coil.
Corey is offline
Old 05-17-2000, 06:41 PM   #6
nightshade000
Member#: 23
Question
I know this is an old topic, but I'm getting a squeaking sound from my front passanger side as well. It's not the tires rubbing, as there's absolutly no marks on the tire whatsoever...not even dirt being removed Did anyone ever find a good fix for this? The guy at les schwab tire (where I got everything aligned) said it might be a dry seal, but couldn't find anything wrong by inspecting it... Any idea's?
nightshade000 is offline
Old 05-17-2000, 06:54 PM   #7
Corey
Member#: 618
2000 2.5 RS #89 STS
Post
I am not going to act like this may be a good remedy to your problem BUT! Wait about a week or two. For some reason, once the stuff settled back in, my noises went away. I know this doesn't seem logical but I can just report what happened to me. I was all set to rip the stuff back apart and... Silence...
Corey is offline
Old 05-17-2000, 06:58 PM   #8
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
The noise on mine went away a couple weeks ago. Very strange to have a noise for about a month, then it goes away. Oh well. I'm not complaining
Strepto is offline
Old 05-26-2000, 11:19 AM   #9
RRinDC
Member#: 204
1998 Impreza OBS
Glacier White/Slate
Question
Corey & Strepto:
I've had my GC/AGX coilovers installed for about a month now. I noticed rattling from one of the rear corners from the beginning, but wasn't sure if it was the strut or the hatchback. I did a 500 mile trip last weekend, including about 75 miles on gravel, with lots of rattling. But when I drove the car yesterday, the rattle was less evident. Do these things just take a long time to break in and/or settle? You've had yours on longer than me -- any rattling now?
RRinDC
1998 Impreza Outback Sport
BTW, I'm running 10-inch springs, 250front/200rear.
RRinDC is offline
Old 05-26-2000, 11:41 AM   #10
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
I no longer have any rattling. I do have road noise coming from the fronts, but that's due to having the Tein adjustable PBMs. Besides that I don't have any noise.
Strepto is offline
Ground Control coilover help/problem? Don Arm Brakes, Steering & Suspension 21 05-06-2006 02:05 AM
Problem with engine/ground/RF noise. Please help. gharari Car Audio, Video & Security 16 05-15-2005 09:52 AM
STI noise problem help NaVaWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 10-11-2004 02:45 AM
ground control install in progress need help GregBolby Brakes, Steering & Suspension 13 12-22-2003 09:37 AM
Stock struts with Ground Control Coilover's (making weird noises in rear) ResQDawg3 Brakes, Steering & Suspension 6 02-06-2003 08:37 PM
