Old 05-08-2004, 04:12 AM   #1
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
Default Calling all jdm ecu users
I need some advise. Should I keep the AVCS on my motor and deal with the lack of engine managment (E.M) or pull off the AVCS cam gears and replace them with some jun cam gears? In doing so I can use my current setup(utec) and save some $$. But I will lose the low and midrange punch. Which brings me to my next set of questions.
I know there are a few people on the board using the jdm ecu w/AVCS and using aftermarket engine managment. AZscoobie, Sponaugle, Cronic etc. If you have input please advise.
1) What are you using for E.M ? utec, ecutec, both, jdm spec utec other(please specify) Downshift1 has tried his old utec on his jdm ecu and had some weird cels.
2) If you are running a utec do you have any problems, such as injector resistors codes massive knocking and weird idle issues. If not what version utec is it and what did you do to get it to work.
3) Im really not looking to get to complicated but do you think a standalone is best. M400 or GEMS
Im sure as this thread gets answered I will have more questions but Im tired now and my brain hurts. This is the last part I need to complete my year long quest for all the right parts to finish my car. Any help would be great!
thanks in advance
-nick
Redline8k is offline   Reply With Quote
Old 05-08-2004, 09:34 AM   #2
cronic
Member#: 9749
1- I am usind ECUTEK/ Utec combo.. The Utec is revision 6b, which has the pins in the correct location for avcs..
2- I do believe i have the injector CEL's but i just turned my CEL off completly with the Utec.. Other than that i have no problems. All i did to get it to work was plug it in.
3- I am not sure of your goals, state inspection laws,etc. For me a standalone is just too much for what i am trying to do..
What mods are you doing to the JDM motor, Turbo upgrade, injectors,etc?
D-
cronic is offline   Reply With Quote
Old 05-08-2004, 09:57 AM   #3
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
D-
Soon2Bgreat is offline   Reply With Quote
Old 05-08-2004, 11:40 AM   #4
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
I am running a V8 (I think) JDM STi ECU with an EcuTek flash on it- still have yet to hook up my AVCS, but the car seems to run great. I do feel as though I need an "on the dyno" tune as opposed to a flash "out of the box" as it were. What is the motor setup you are running?
MK19_ is offline   Reply With Quote
Old 05-08-2004, 02:42 PM   #5
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
thanks guys keep the info coming. As far as my build goes its the whole deal. motor, trans, turbo, injectors and all the bolt ons to support around 400hp on race gas. my goal is mid to high 11's and to have a fun street car/ weekend track car. This will not be my main sorce of transport.
Cronic- doesnt the car run bad with those cels? can you please check and see what codes you are throwing? In interested in knowing.
What are you guys using for knock control, because the factory ecu stops "listening" for knock after 6k or so? Does the ecutec have any added feaures like this?
thanks
-nick
Old 05-08-2004, 03:21 PM   #6
cronic
Member#: 9749
THe cels are for Injector something, one cel for each injctor and the car runs fine like that..
What turbo are you running?
I thought the Utec listens for knock till redline...
Old 05-08-2004, 03:50 PM   #7
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
I have a HKS 2540r setup and a few tricks (no nos)
the utec might but does the ecutek? Im trying to get the best of both worlds. Id like to have 2-3 maps for different driving days and such. This I cant do with the ecutek all that easily. I still have to check what version utec Im running it see if they are compatiable. Im still up in the air about this whole thing.
thanks for the info keep it coming
-nick
Old 05-09-2004, 12:59 PM   #8
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
bump
Old 06-01-2004, 12:26 AM   #9
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
still looking for more good info... anyone.... bueller....bueller...
Im this >< close to buying the JDM/AUS utec any final thoughts?
thanks
-nick
Calling all Tablet PC users! gills Off-Topic 46 10-29-2008 12:08 PM
calling all emanage blue users - idle problems mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 10 11-16-2007 09:03 PM
Calling all JDM V7 and up ECU owners Hyper Subaru Conversions 0 10-20-2006 12:58 AM
Calling all K&N Typhoon users BlueDonkeyWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-21-2006 10:59 AM
Calling all motorola Razr users tommy2hotty Off-Topic 41 01-19-2006 12:02 AM
