05-24-2000, 09:55 PM | #1 |
Member#: 175
E. Canada
Vehicle:'00 Impreza 2.5RS |
Intake hoses and breather filters.
The 2 tubes going into the pipe; Someone was told that if he removed the tubes then performance would increase but emissions would be bad. And replacing the tubes with those mini breather filters. Would these filters be put on the pipe or the engine part where the tubes were? Or all 4 holes? What exactly are these tubes for? And are there any cheap alternatives (Like nothing there) or makes other than the Weapon-R?
05-24-2000, 11:40 PM | #2 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 15 Forester XT, 21 Ascent |
I can't help you, but you should edit your post to include your model year...
Larry |
05-25-2000, 10:36 AM | #3 |
Member#: 1130
Vehicle:2013 STI Hatch DGM |
I got the weapon r intake and found that the kit was incomplete. And even if I bought more hoses etc, it still wouldn't all fit. So I bought the K&N breathers and mounted them straight to the heads. Power increase? Doubt it. Less crap in the engine compartment? Definitely. Smog? NOt legal.
05-25-2000, 01:07 PM | #4 |
Member#: 175
E. Canada
Sorry, I have a 2K, So Nightmare you're against the breathers? Anyone else?
05-25-2000, 02:06 PM | #5 |
Member#: 1352
Vehicle:2005 Forester XT black |
Some have mounted those small breathers at
the end of short lengths of hose so it would be farther for the oil to travel, but the fact remains that the breather filters will be coated with engine oil eventually, and be a real mess cleaning them. What I have done is cut a short (4") aluminum "stack", put on 3 self tapping hose fittings and just connected silicone hoses to replace the factory ones. I have a "ricey" yellow color scheme going on now! Yellow cone filter, yellow silicone reducer (for the 3" stack to mount directly on the T/B), and yellow hoses! Don't laugh! My Suby is BRP BTW! Anyways as I have posted many times before, this allows me to run cool air with an open hood scoop.If you search archives I used to be "SubyRS". |
05-25-2000, 02:13 PM | #6 |
Member#: 296
Hi guys..
Oil can (and does get) into the intake system.. the oil comes mainly from the cam covers. What you need is an oil catch can fitting... plumbing the breathers into that.. and then fitting a filter onto the can... and plumbing the drain into the sump. Or block it off. If you block the drain off, then you can get rid of the filter and connect it back into the intake. Oil in the intake system will affect performance... it lowers the RON of the fuel. J. |
05-25-2000, 04:00 PM | #7 |
Member#: 175
E. Canada
Holy Crows,
This is all new to me, is there any detailed instructions with pics or anything like that? Pics of you guys' engines? Verrry interesting. |
05-25-2000, 04:00 PM | #8 |
Member#: 175
E. Canada
Holy Crows,
05-26-2000, 12:26 AM | #9 |
Member#: 1352
Slide, be careful with those breathers! Oil
mist is what comes out of those ports on the covers. Oil WILL accumulate and eventually spray out when you rev high! Just speaking from experience! |
2006 sti stock intake box with maf hose and air filter | SUBIEDUDE33 | Engine/Power/Exhaust | 5 | 04-30-2009 07:45 PM |
Perrin Intake Hose (Blue) / Ebay filter | ohxietviet | Engine/Power/Exhaust | 6 | 04-14-2009 03:59 PM |
MD: Stock 2006 wrx intake box, hose, and new filter | Poekin | Engine/Power/Exhaust | 0 | 08-20-2007 07:22 PM |
GP moto MAF hose and K&N filter!!!! | IIdiceII | Private 'For Sale' Classifieds | 7 | 06-23-2006 01:48 PM |
intake hose and intercooler hoses worth the money? | jimtweet | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-02-2004 09:46 AM |
