Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 05-09-2004, 12:54 AM   #1
mslasube
Member#: 58900
2005 Forester XT
Crystal Gray Metallic
Default 15 inch wheels- forester xt
I am soon to buy forester xt. I am hoping I can mount my set of 205/15/60 Artic Alpins on a near new set of Impreza 15x6 inch 6 spoke alloy wheels that I have and put these on the Forester in the winter. I understand the forester may use a slightly different offset (48mm) wheel than the impreza (53 or 55 mm). My question is, will the 15 inch wheels I have described fit the Forester? Thanks!
mslasube is offline   Reply With Quote
Old 05-09-2004, 01:50 AM   #2
lucien2
Member#: 1519
1998 Volvo V70R
No chance. The FXT uses the bigger brakes from the WRX, and a 15x6 rim won't clear those brakes. You are right about the offset, though. But that isn't your problem, it's the rim dimensions.
lucien2 is offline   Reply With Quote
Old 05-09-2004, 02:39 AM   #3
mslasube
Member#: 58900
2005 Forester XT
Thanks for the quick reply! It sounds like I would run into the same problem on a WRX. Right?
Old 05-09-2004, 10:21 AM   #4
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Yessir, you would see it hitting the brake caliper if you even tried to mount them.
You best bet would be to sell those off and pick up some 16" OE wheels from an RS, WRX or Legacy and just getting some new tires.
Bry.
BrysImpreza is offline   Reply With Quote
Are there any 15 inch wheels that fit over the rex brakes? mcu81 Brakes, Steering & Suspension 8 10-28-2002 12:29 PM
15 Inch Wheels? GQ Brakes, Steering & Suspension 15 08-02-2002 11:22 AM
15-inch wheels for WRX Drover Brakes, Steering & Suspension 7 07-23-2002 05:32 PM
4 piston calipers on a 15 inch wheel? Heavy Fuji Brakes, Steering & Suspension 7 06-03-2002 09:58 AM
Can I still fit 15 inch wheels over 4 pot calipers? Greg555 General Forum Archive 3 12-29-2000 08:14 PM
