Old 05-09-2004, 03:00 AM   #1
Icon25rs
Member#: 20728
2006 STI
Default Front mount intercooler turbo kit
Okay, I have a MY2002 EJ25 RS and I have looked all over the place but I can't find what I want. What I am looking for is a front mount intercooler turbo kit that doesn't interfere with the fog lights. Anyone know where I can find this?
Icon25rs is offline   Reply With Quote
Old 05-09-2004, 03:03 AM   #2
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
kit doesn't exist right now. you will have to wait or piece one together yourself.
-Eli
squirrelmasta is offline   Reply With Quote
Old 05-09-2004, 03:25 AM   #3
Icon25rs
Member#: 20728
2006 STI
damn!
Old 05-09-2004, 08:01 AM   #4
03imprezaRS
Member#: 51655
2002 WRX PSM
2003 2.5RS BRP (SOLD)
i've seen a WRX with front mount intercooler and still have the fog lights...it should fits the 2.5 RS...
03imprezaRS is offline   Reply With Quote
Old 05-09-2004, 02:32 PM   #5
squirrelmasta
Member#: 33445
Cherry Red
Oh, don't get me wrong, you can do a FMIC on our GC8's but you have to piece it together your self, or modify the kit once you have it. And most likely you will have to do custom pipes. search this forum about FMIC and there should be some threads by me and some other guys about them, and there were some good links.
-Eli
Old 05-09-2004, 03:27 PM   #6
Daveish
Member#: 8935
2001 Impreza 2.5RS
Why not look at getting a non-intercooled turbo kit, then having a shop mount a FMIC and custom-make you the piping? That's what I did, and the FMIC + piping + labor only cost me $950, and the FMIC dosen't get in the way of the fogs.
I think any FMIC kit you find is easily going to cost at least that, and heck, even when Tom at Ludespeed was still making kits, his price on a TMIC was $700 alone...
Daveish is offline   Reply With Quote
Old 05-09-2004, 03:35 PM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
Since you have a 2002..any wrx FMIC should fit. You'd just need custom piping made.
BTW...why go FMIC? Could probably get a REX hood here used fairlt cheap and the 2002 EJ25's are only good for up to 5psi (IIRC).
Tats is offline   Reply With Quote
Old 05-09-2004, 03:50 PM   #8
Icon25rs
Member#: 20728
2006 STI
I thought about that, but long time ago I saw stats that said a front mount is bigger and works a lot better then one that sits on top of the engine. I saw it in like Sport Compact Car or Import Tuner, I can't remember where. Plus I think it looks a lot better, I still might try to get a REX hood if I can find a way to filter the air, then have it go over the engine just for cool purposes. I want vents in my hood to dissapte heat like the ones on the older models.
Old 05-09-2004, 05:24 PM   #9
squirrelmasta
Member#: 33445
Cherry Red
TMIC vs FMIC doesn't really make that big of a difference unless you are talking some serious PSI. but i think for what we do with our cars, i don't think it's going to matter that much. i think it comes down to what you want.
-Eli
Old 05-09-2004, 09:18 PM   #10
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
FMIC cars aren't nearly as fun to drive as TMIC's either, much more laggy. If you only plan on running 5psi a front mount is total overkill. On that level of boost you MIGHT pick up 10hp at the expense of MUCH responsiveness.
no-coast-punk is offline   Reply With Quote
Old 05-10-2004, 01:24 AM   #11
Icon25rs
Member#: 20728
2006 STI
I plan on running 8psi at least still more work is done to the car and then I will go higher.
Old 05-10-2004, 05:46 AM   #12
Tats
Member#: 5692
WTF? YES! I am
better than you!
I think I heard from some where that the 2002-up ej25's couldn't hold more than 4-5psi reliably. Check that out first.
Old 05-10-2004, 10:34 AM   #13
squirrelmasta
Member#: 33445
Cherry Red
huh? go GC's!!!!
-Eli
Old 05-10-2004, 05:41 PM   #14
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
Buy a nice big core and get pipes custom made and you should be pushing a healthy PSI to make it effective.
seven881 is offline   Reply With Quote
Old 05-10-2004, 05:52 PM   #15
squirrelmasta
Member#: 33445
Cherry Red
so in theory here, correct me if i'm wrong, even on the stock motor, if we do a bigger FMIC we can crank up the boost and not hurt anything??? TRUE?
-Eli
Old 05-10-2004, 06:10 PM   #16
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
No, I was saying that for a big FMIC to work efficiently you should be pushing higher than 5psi. You should not crank the boost on a stock EJ25 even with a Big FMIC.
-Eli
Old 05-10-2004, 10:31 PM   #17
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
Pi7467mp is offline   Reply With Quote
Old 05-10-2004, 11:24 PM   #18
squirrelmasta
Member#: 33445
Cherry Red
just wondering if it worked that way at all. Thanks.
-Eli
Old 05-10-2004, 11:31 PM   #19
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Wait till FAT gets his new kits sorted out .
imprezzakc is offline   Reply With Quote
Old 05-11-2004, 12:19 AM   #20
mycarsux
Member#: 32049
2010 sti
http://www.isrperformance.com/main.html
click on the "intercooler" link. should be the first one. mrt.
mycarsux is offline   Reply With Quote
Old 05-11-2004, 01:26 AM   #21
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Question new kits
what new kits??? you got my attention
IllNastyImpreza is offline   Reply With Quote
Old 05-11-2004, 01:34 AM   #22
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Lightbulb front mount VS top mount
YES a FMIC looks much better than its comparison.
But if your only gona be running 8 pounds of boost, you will actualy be HURTING your performance.
As a turbocharger spools it generates heat. And the more it boosts the hotter the incoming air becomes.
I'm not sure on the exact measure of temperature rise vs boost level. BUT @ only 8 PSI you will only see a moderate gain in intake temperature, therefore the addition of the extra piping and the extra air needed to flow through the vast distance of intercooler piping will actualy SLOW down your boost. and the added bennefit of a couple degrees colder(more dense) incoming air will be less benneficial.
Old 05-11-2004, 12:25 PM   #23
dennisla
Member#: 48178
MY99 Impreza 2.0 T
555 Rally Blue
I have seen turbokits.com have this kit with FMIC. :-)
98 - 01 Subaru Impreza Turbo Kits:
Brand: TSI
Desc: 98-01 Subaru Impreza
Type: Extreme Kit
Status: Ready to ship
Price: $2799.00
Buy Now Impreza Extreme Turbo Kits Include:
- Garrett T25 Turbo w/ Wastegate
- Cast Exhaust Manifold
- Chrome Heat Shield
- Downpipe w/ Gasket
- Map Unit (Black Box)
- 2 Injectors & Interface Block
- Injection Control Unit w/ Turbo Timer
- Blow Off Valve (BOV)
- High Flow Front-Mount Intercooler
- Polished Aluminum Intercooler Piping
- SS Braided lines for Water Cooling
- SS Braided lines for Oiling
- Return Hose and Fittings for Oil to Pan
- All Hoses & Clamps
- All Necessary Hardware & Fittings
- Generic Install Instructions
- Injector Control System Settings
Maby You can use this..
Dennis LA
Denmark
dennisla is offline   Reply With Quote
Old 05-11-2004, 02:19 PM   #24
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Default Re: new kits
Same here, more details please! Is this the same one kastle spoke about, that lets you keep the stock fogs?
Wedge is offline   Reply With Quote
Old 05-11-2004, 03:21 PM   #25
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default TSi extreme
that kit requires imense customization, I've been told its actualy easier to fabricate your own.
But it actualy USES the hoodscoop for cold air intake
FS:CSS Black front mount intercooler complete kit SmokedWRX Engine/Power/Exhaust 11 01-26-2009 06:12 PM
Front mount intercooler piping kit? amelnikov Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-16-2002 09:06 PM
Front Mount Intercooler Piping Kit amelnikov Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-08-2002 10:24 AM
Is there a turbo kit using front-mount intercooler? aek Normally Aspirated with bolt-on Forced Induction Powertrain 13 04-15-2002 01:28 PM
