Old 05-09-2004, 02:29 PM   #1
Kuonji
Member#: 44406
2004 STi
Silver/Silver
Default How can you tell if you have exhaust leak?
I just finished installing the Vishnu TBE on my STi and took the car for a short drive. When I returned, I was checking under the hood for leaks, etc, and I noticed the area around the downpipe had light wispy bits of smoke wafting out of it. Not blowing out of it, just sorta floating. I thought it was an exhaust leak at the downpipe/turbo but my dad is 100% positive it's just paint/coatings burning off because of the newness and the heat. There is no noise that I can hear. All the bolts were tightened down well and double checked, so am I just being paranoid? Any way to tell for sure?
-Chad
Kuonji is offline   Reply With Quote
Old 05-09-2004, 02:51 PM   #2
Massive
Member#: 32773
2003 WRX
Kuonji,
The smoke is probably lubricant that was used during the downpipe install. Drive around for a while, and it should burn off.
Massive is offline   Reply With Quote
Old 05-09-2004, 09:33 PM   #3
Houdini
Member#: 51379
Sedona Red
After I install my TBE and uppipe it smoked quite a bit from all the liquid wrench I used, but was gone after about 10 miles of spirited driving
Houdini is offline   Reply With Quote
Old 05-09-2004, 11:26 PM   #4
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Ya, after doing installs like that under the hood its common to use liberal amounts of WD40 and the like to help get the bolts loose. This is probably whats burning off.
N'CTRL is offline   Reply With Quote
Old 05-10-2004, 08:47 PM   #5
redhammer082
Member#: 61544
'02 impreza wrx
Default exhaust installation
High all I'm new. Great info tips. But my turn , I just purchased a bosal 3" daul tip cat back. This is a bad as? looking set up. Any pionters on install? I have all the tools and knowledge. I have to wait a week to do it though the sincrods in the tranny are getting replaced. O , I own a '02 wrx. Thanks.
redhammer082 is offline   Reply With Quote
Old 05-10-2004, 10:03 PM   #6
Kuonji
Member#: 44406
2004 STi
Silver/Silver
cat back? Man...that will be a piece of cake. Don't let the car fall on you while you are down there.
How Can I Tell If I Have a Leak? john_eldorado Newbies & FAQs 3 02-20-2008 10:12 PM
How can I tell if I have 02 or 03 calipers? MidRex Brakes, Steering & Suspension 18 08-05-2004 10:08 PM
How can I tell if I have been banned at Honda-Tech? JewPac42 Off-Topic 6 02-26-2004 04:43 PM
how can i tell if i have sti strut tops? no_rex_yet Brakes, Steering & Suspension 0 01-09-2003 06:30 PM
How can I tell if I have the short-throw shifter? rharder General Community 3 07-18-2002 11:06 AM
