Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-07-2000, 08:19 AM   #1
redbaron
Member#: 1265
06 06 STi
white
Question MSD ignition?
has anyone tried it? will it work ???
redbaron is offline
Old 08-07-2000, 08:55 AM   #2
Kyle Paton
Member#: 1184
2012 Impreza
Dark Grey Metallic
Post
I belive you have to use the MSD DIS digital ignition because of our distributor-less ignition.
The TecII comes with new coil though
Kyle
Kyle Paton is offline
Old 08-07-2000, 04:16 PM   #3
Mr. Gasket
Member#: 1427
Post
i tried to find any aftermarket ignition upgrade for my 99, but MSD does not fit and called Jacobs elecr. to see what they've got but their answer was that they tried their power pack but no HP changes were found. they belive that our ignition is good enough and not to mess with it.
i guess that if you go Turbo you'll need a computer to reprogram the ignition timing that's all.
Jose
Mr. Gasket is offline
Old 08-07-2000, 06:38 PM   #4
slide
Member#: 1130
2013 STI Hatch
Post
I havea 95 with the dis 2. Itworks. Gas mileage improves. As for hp i haven't checked w/ the g-tech. But as for the stock being great. I doubt it. One small coil for two cylinders. And the ignitor is about the size of a match book. If you run any sort of turbo or s/c and no tech-II then the msd is great for ignition retard and a soft rev limit for when you startto spike the rpm's.
slide is online now
Old 08-08-2000, 07:13 PM   #5
redbaron
Member#: 1265
06 06 STi
white
Cool
thanx!
-2000 w/ NOS-
redbaron is offline
Old 08-08-2000, 08:09 PM   #6
Avenger
Member#: 1234
Question
I know nology have product called powercore is this product any good? or is the MSD system better? Planning to get some nology hot wires.. Thanks.
Avenger is offline
Old 08-09-2000, 03:45 AM   #7
doripreza
Member#: 574
99 Impreza RS
Post
i have spent about a week attempting to get an MSD DIS-2 to work with an 99 impreza coil-pack.
i don't think it will work at all with this year coil pack due to the fact that the ignitor and coil pack are in the same unit
unlike other years and models. like 95 and 92 etc..
i'm going attempt converting to an older coil pack type but as far as working with the new coil pack its a no go for me.
anyone else had any luck?
Gino
doripreza is offline
Old 08-09-2000, 07:14 PM   #8
XT6Wagon
Member#: 524
04 STi
Post
Idea....
Use a High output coil for a Ford 4.6L. They use two coil packs a car so each one has the correct 4 leads. The big problem useing them is the need for custom Plug wires. you would need to put the Ford coil ends on a set of 2.5RS wires. This may be possible just by asking Jacobs or MSD to make them....
XT6Wagon is offline
Anyone familiar with MSD ignitions? IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-03-2001 11:08 PM
MSD Ignition. What will I need to make this happen? olie Normally Aspirated Powertrain 11 09-06-2001 01:32 AM
('93-'01) MSD ignition System Santo Domingo 2.5 RS Impreza Forum 12 08-28-2001 12:45 AM
How many of you would like MSD Ignition wires imprez_kyoso General Forum Archive 2 03-29-2001 03:54 AM
MSD Ignition? SSLegacyGT Legacy Forum 5 12-20-2000 07:05 PM
