Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 05-09-2004, 06:31 PM   #1
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Talking DOH!!! CEL, Finally!
Go figure,
Go on a vacation and the cel decides to come on 150 miles into it
Now its time to figure out whether its my uppipe, Downpipe, Intake, or upped boost that is causing the problem.
What the hell did I break this time?
You gentlemen may start your betting pool. I'll post results tommorow.
Old 05-09-2004, 07:25 PM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
All of the above
Peaty is offline   Reply With Quote
Old 05-09-2004, 08:45 PM   #3
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
One or the other.
Winner receives one Guru "Your Cool" pt.......
Old 05-10-2004, 12:29 AM   #4
bliz
Member#: 12065
08 evo x mr
wicked white slow pos
i would have to say the uppipe if you dont have the resistor mod done or the wrong resistor.intake wont do it,the bosal still keeps the 3rd cat right,maybe an overboost cel.
bliz is offline   Reply With Quote
Old 05-10-2004, 07:53 AM   #5
DriftZero
Member#: 39616
Everyone has
stories they bore me
up pipe
DriftZero is offline   Reply With Quote
Old 05-10-2004, 11:22 AM   #6
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
w00t
P0420.
Time for a Fix. Mechanical or P.E?? Hmmmmmmmmm
Old 05-10-2004, 10:46 PM   #7
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Did the mechanical fix. Won't know its effectiveness until I head to Chicago in a few weeks ( only trips on freeway) should be fine though.
Old 05-11-2004, 01:40 PM   #8
bliz
Member#: 12065
08 evo x mr
because you stay at a steady speed for awhile
Old 05-11-2004, 06:54 PM   #9
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Yep,
Old 05-12-2004, 04:44 PM   #10
corndogs
Member#: 49322
2004 Forester XT
Java Pearl Black
I used the 10ohm resister on mine and it works perfect. The only time my cel comes on is when I start to boost to much with the VF39 and I hit fuel cut.
corndogs is offline   Reply With Quote
Old 09-07-2004, 02:43 AM   #11
jeffsnyder
Member#: 10039
hey what fix did u use. i pulled the same code this weekend after i did an up and down pipe install.
JEff
jeffsnyder is offline   Reply With Quote
Old 09-07-2004, 03:29 AM   #12
VSB XT
Member#: 45034
12' WRX Limited
That dark grey color
There seems to be a couple of fixes, but I went through this myself after the up/downpipe install. The Pony Express cel eliminator,think there is a perrin fix also, and that (10 ohm resistor), but that did not work for me either. Luckily the reflash got rid of it all together.
VSB XT is offline   Reply With Quote
Old 09-07-2004, 08:58 AM   #13
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Mechanical fix.
Worked great.
Old 09-07-2004, 12:19 PM   #14
jeffsnyder
Member#: 10039
cool. i'm goin to order the pony express one
Old 09-07-2004, 12:48 PM   #15
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Why?
2 spark arrestors is like $5 and does not cut the harness.
Old 09-07-2004, 12:51 PM   #16
jeffsnyder
Member#: 10039
okay show me how to do it and where do i get the parts at radioshack
Old 09-07-2004, 01:31 PM   #17
jeffsnyder
Member#: 10039
(two spark plug defouler's together with the center bored out to fit the 02 sensor).
or can i do the mec fix
Old 09-07-2004, 01:36 PM   #18
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
That is the mechanical fix.
The Pony express is the electronic fix.
Old 09-07-2004, 02:36 PM   #19
GriffinREX
Member#: 36054
How do you do the 10ohm resistor fix?
GriffinREX is offline   Reply With Quote
Old 09-07-2004, 08:18 PM   #20
bliz
Member#: 12065
08 evo x mr
im pretty sure the 10k ohm fix is for the uppipe,unplug the egt harness clips,cut the 10k ohm resistor and bend the ends so that they go into the egt harness the female side and tape it up.i have had it like this for atleast 3,000 miles no cel.
Old 09-07-2004, 08:29 PM   #21
bliz
Member#: 12065
08 evo x mr
jeff ,you can get the anti foulers at auto zone or pep boys,they are in the help section part number 42002.the one you are going to use on the top,use a 1/2 drill bit and drill all they way through it,put the 2 together insert into the d/p thats it.
Old 09-07-2004, 11:01 PM   #22
jeffsnyder
Member#: 10039
i'm goin to try it this way thanks for the info bliz
Jeff
PS i also got a new beater car a 86 gl10 turbo
Old 09-07-2004, 11:29 PM   #23
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
BASTARD!!!!
Old 09-07-2004, 11:43 PM   #24
jeffsnyder
Member#: 10039
ohh this will heat u up too: got it off ebay for $175 needs a tranny
JEff
Old 09-08-2004, 12:54 AM   #25
GriffinREX
Member#: 36054
That's what I was thinking. I used that fix for my uppipe, but I was hoping that there was an easy fix like that for the rear o2 sensor.
Need some help please cel plus more!!!! thrasher679 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2010 09:21 AM
DOH....DOh....Doh....doh scarywoody Off-Topic 7 06-09-2007 02:43 PM
Cel finally came Nactos Newbies & FAQs 7 12-17-2006 02:22 PM
Just threw a CEL...doh! dlh1999 Newbies & FAQs 4 09-08-2006 02:37 PM
MRT exhaust finally complete, no CEL Patrick Olsen Normally Aspirated Powertrain 3 09-10-2001 01:00 PM
