Old 05-09-2004, 09:29 PM   #1
cedata
Member#: 61579
1996 Subaru Outback
Green
Default Help...96 Outback 2.5 Cylinder 4 Misfire
My Outback is a 96 2.5 w/150k miles. Some months ago I got a check engine light. Code idicates cylinder 4 misfire. I have swapped the plug, ignition wire and fuel injector with other cylinders to see if problem follows part. I finally bought a new ignitor pack. No help. I would greatly appeciate any suggestion that might help me resolve this. Thanks..Cedata
cedata is offline   Reply With Quote
Old 05-09-2004, 11:25 PM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
So the CEL is still on right?
How is the car running, is it using lots of gas, shaky, hesitation?
do you have any mods?
i has a missfire is cylinder 2, the car studdered one time and a stop light and the cel came on and wouldn't go off, until i had the dealership clear it. never came back (only been 3k miles).
RS_to_WRX_swap is offline   Reply With Quote
Old 05-10-2004, 02:56 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
How are you pulling the codes?, yourself or a shop/friend?
Are you getting the same CEL?
Common issue is bad plug (or new ones that are bad for our car, like Bosch plugs)/bad wire.
When was the last tuneup? Even though you may have swapped parts, doing new NGK copper plugs and OEM wires is a good start.
Can you add anything to this?
Old 05-11-2004, 01:11 PM   #4
cedata
Member#: 61579
1996 Subaru Outback
Green
Thanks for the response...My car is not modified in any way.I bought an OBDII diagnostic package from Ease Diagnostics a couple of years ago. Works great for reading and clearing codes. I'll take your advice and buy NGK plugs and factory wires. If that will work it will be an easy fix. I replaced plugs (used bosch)and wires (got'em at AutoZone) last year. When I initially start the car it idles great...I drive down the road a minute or two and suddenly I can tell it runs a little rough and CEL flashes.Car will run rough for a minute or two then everything smooths out and the car runs great . Thanks, for your help. If you have any other thoughts on this let me know...Dave (CEData)
Old 05-11-2004, 02:08 PM   #5
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
bosch are bad. they just dont fit up well with the factory plug wire boot on most cars. and if they are split fire they are worse yet. all those electrode prongs do is block fuel from getting to the spark.
F/S Outback 2.5 Cylinder Heads Just Freshened Hayaboosted Engine/Power/Exhaust 7 07-13-2009 02:26 PM
Cylinder 4 misfire help Turbo NV Factory 2.0L Turbo Powertrain 3 02-12-2008 02:32 PM
F/s 96 Outback 2.5 $5500 02WRX2.5 North West Impreza Club Forum -- NWIC 0 08-14-2005 06:29 PM
96 subaru impreza with cylinder one misfire melissa General Community 1 01-20-2005 12:44 PM
cylinder 4 misfire....help! left footed whooten Normally Aspirated Powertrain 31 11-22-2003 10:00 PM
Message Board Statistics All times are GMT -4. The time now is 06:55 AM.
