Old 05-09-2004, 11:43 PM   #1
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
Default wiring help for my motor *pics*
well i looked at my motor today and realized all the wiring on the engine is intact and nothing is cut! Everything is hooked up, that means everything that would not permit the engine to be attached to the chassis. The only spot where its cut, is at the brown/gray SMJ connector? along with another harness next to it.
Like so in the pic
And the harness over by the turbo.
Thats the only thing i found to be cut, other than the throttle cable. So do i really need to shell out 500 bucks for a complete sti chassis wiring harness or can i just extend the cut wires and splice them into the sti harness?
Dont laugh at this but is this mainly what i have to wire ? I cant just put in the jdm ecu in and call it a day because all the sensors and wires and connectors and different size,shape, colors, purposes etc. But do i just need to wire the RS bulk harness up so that it goes to the STi ecu?
Like B20 on RS harness is crankshaft position sensor, and B10 is crankshaft position sensor on wrx/jdm ecu so i solder those wires at the shown pic?
Again dont laugh
ImprezaRSfan! is offline   Reply With Quote
Old 05-10-2004, 07:18 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
best diagram EVAR!!!
you seem to have it correct but im not sure because that diagram is so awesome!!
Ben
Old 05-10-2004, 11:49 AM   #3
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
so then why would i need to pull off the dash ?
Old 05-10-2004, 12:52 PM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
wait so you have a v8 ecu?
you would need to pull of the dash to put in the rest of the wiring, because you need wires to go from the engine harness to the ecu and it will connect to the speedo and stuff, which you may have an issue with, plus running all the wiring.
i dont know, im no expert in the swap department, if i saw a wiring diagram i could help more, but i dont even think your RS ecu harness will connect to the V8 ecu will it? that is the problem, your V8 ecu needs wires for the avcs, TGV's, TBW, etc...which your current RS harness doesnt have. you may have empty slots to put them, but its still prob not gonna plug into the V8 ecu, unless you have already checked.
like i said i cant really tell from your wiring diagram but from you typed about the crankshaft sensor, you have the right idea, you need to match those up.
Ben
Old 05-10-2004, 03:27 PM   #5
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
i *think* i know what im doing
Old 05-10-2004, 04:11 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Is the engine a V8 (twin-scroll) engine or what? The V8 JDM engine has NO TGVS and is NOT throttle-by-wire. The only thing you'd have to run are AVCS sensor/solenoid wires.
Do you have the ECU connectors for the STI ECU? You could theoretically re-use the wires in your RS chassis harness for the wiring, but I don't know if there are enough wires.
Old 05-10-2004, 05:14 PM   #7
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
No, no. You've got it all wrong. It goes like this:
DeusExMachina is offline   Reply With Quote
Old 05-10-2004, 06:43 PM   #8
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
lol
akcel is offline   Reply With Quote
Old 05-10-2004, 09:07 PM   #9
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
thats my twinscroll v.8 jdm ecu. Woudlnt i just be able to splice the harness part where its slashed into the RS harness if i slash it at the same spot? THen i wont have to pull the dash and anything? Maybe run some wires for avcs and thats it?
What am i missing? It seems like this will take lots of time but it looks pretty easy just very time consuming.
Old 05-10-2004, 09:20 PM   #10
serious
Member#: 22879
For what it's worth, take out the dash. It will take you all of two hours to yank it and will make things go sooooo much smoother. Your wirring will be much more professional and you won't hate your car once you're done.
Another option you might want to look into is getting a complete 02+ wrx harness and making it run with that with intergration into your rs harness.
This is what i'm doing with my legacy. 2002 wrx harness and swapping the tumble generator wires around and adding the 4 wires for the magnetic pick sensors. I think there is one more wire that is something like a intake temp sensor you have to hook up.
B
serious is offline   Reply With Quote
Need your help for my motor ... darko Built Motor Discussion 5 01-26-2009 02:07 PM
Help direct me for my motor/turbo route pulser9 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-25-2008 02:28 PM
Anyone around? Help diagnose my motor moss Mid Atlantic Impreza Club -- MAIC 22 07-18-2006 09:21 AM
Help diagnose my motor issues moss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-17-2006 10:26 PM
Need help identifying my motor ej20g jparent33 Subaru Conversions 4 02-22-2005 04:12 PM
