Vancouver Impreza Club
Old 05-10-2004, 02:53 AM   #1
[YeS.SiR]
Member#: 56602
2012 SWP STi
Default Improperly Towing WRX
What, if any, damage might result from towing a WRX by the front wheels only for about 500 metres?
[YeS.SiR] is offline   Reply With Quote
Old 05-10-2004, 04:23 AM   #2
stisp33d
Member#: 45122
5xtra hp for sti in name!
a broken face to the tow guy.
stisp33d is offline   Reply With Quote
Old 05-10-2004, 04:31 AM   #3
carmaniac
Member#: 43015
2002 Mazda Protege5
Pure White
unless the front axle was disconnected, i'd imagine there would be some damage to the center differential....
carmaniac is offline   Reply With Quote
Old 05-10-2004, 07:10 AM   #4
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
if you only have to go 500 meters, could you get away with just towing it on the ground with a tow strap?
alexs001 is offline   Reply With Quote
Old 05-10-2004, 11:34 AM   #5
Kevin
Member#: 1082
2015 Q50S
Dull
There would be an extreme build up of anti-matter in the viscous coupling causing the centre diff to spontainiously combust
Actully, since there is a viscous coupling in there somewhere it might not do anything if only towed such a short distance. I've done countless e-brake turns and nothing has blown up yet.
As usual, this is just my opinion and shouldn't be taken as fact.
Kevin is online now   Reply With Quote
Old 05-10-2004, 12:02 PM   #6
Sperm
Member#: 25038
2002 PSM WRX sedan
Sperm is offline   Reply With Quote
Old 05-13-2004, 04:16 AM   #7
[YeS.SiR]
Member#: 56602
2012 SWP STi
He pulled up with one.
Don Docksteader was great with my car. They haven't found any drivetrain or anything, but they advised me to keep my ears open.
Long story short: this all began with a dead battery, a foreign tow truck driver crossing the polarities, blowing a fuse, wiping out the battery, improperly towing my car, taking 40 minutes to release it from the dolly, breaking my screwdriver and wasting 5 hours of my time, and quite a bit of money.
Sigh.
Old 05-13-2004, 05:18 PM   #8
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
I have had my old 2.5RS improperly towed a short distance (about 150 meters at mission) with no long term damage..
Orbiter is offline   Reply With Quote
Old 05-14-2004, 12:51 AM   #9
STinger
Member#: 19410
'16 STI ISM
'95 LWRX Stage Rally Red
Talking about tow truck drivers, did anybody read about Citywide Towing in Richmond and what one of the drivers did to a customer's car? Raised the rear end up and dropped it onto the ground, bottoming it out, deliberately when he found out that the customer had called another company because he didn't show up for a long time. Nasty.
Martin
STinger is offline   Reply With Quote
Old 05-14-2004, 02:27 AM   #10
tony_subaru
Member#: 22742
You'll be fine.....we had emailed SOC and they said nothing should get damaged......(similar situation with a friend)
tony_subaru is offline   Reply With Quote
Old 05-14-2004, 05:43 AM   #11
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Sorry man, your car is hosed. FUBAR. Stick a fork in it, it's done.
Actually I'm surprised it didn't jump out of the towing harness or at least spin the rear wheels.
Anyway, all sarcasm aside, the car does exactly the same thing when spinning a wheel or two on, say, ice. Damage to the centre diff is usually a thermal thing -- make it rub long and hard enough (hey that sounds dirty) and it'll cook itself, that's all. The chances of this happening during a short, low-speed tow are slight, at least.
Necromancer is offline   Reply With Quote
Towing WRX behind RV with RV mounted tow hitch Ardrossan General Community 36 03-17-2016 01:07 PM
Center differential damage due to improper towing kid 13 Newbies & FAQs 36 06-28-2004 05:41 PM
Towing - Does anyone tow trailers with their WRX 143paul Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-22-2003 08:04 PM
tow tow tow like any good diesel should FreeBMW Mid West Subaru Owners Club Forum -- MWSOC 6 08-11-2003 02:20 PM
Anyone Heard Of An Improper Fuel Pump Install Causing Car To Explode? the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 18 08-11-2001 12:46 AM
