05-23-2000, 06:13 PM | #1 |
Member#: 987
Vehicle:2000 Impreza 2.5 RS Blue Ridge Pearl |
Help!! Brakes are mushy after pad install!!
Today I installed some new barke pads and after reassembling everything the brakes are completely mushy. I can push the brake pedal all the way to the floorboard, then when I release and push again, the brakes finally engage. It is like you have to pump them to get them to work. I did accidently remove the brake line and a little fluid was lost but not much. Any suggestions?
05-23-2000, 06:27 PM | #2 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
fluid was lost but not much. Any suggestions? you need to bleed the lines to get the air out of the system [email protected] |
05-23-2000, 06:29 PM | #3 |
Member#: 1337
You need to bleed the brakes. I have to do this all the time on my CRX (Race car) and
about twice a week end. When you pushed the piston back in install the new thinker pads you, changed the pressure through out the system Its a two person job, and you start with the tire farthest from the master cylinder, and work you way closer. once your done your brakes should be rock solid, If not take it in to get look at. I am at [email protected] If you need more detailed directions. Hope that helps |
05-24-2000, 06:42 AM | #4 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
4 channel ABS equipped cars don't follow the standard bleeding pattern. You still end up at the master cylinder (in our case, and in most cases left front), but this is the right order: LR, RF, RR, LF
05-24-2000, 07:27 AM | #5 |
Member#: 677
Since you have ABS the ABS has to be on when bleeding brakes. Keep the ABS on by turning the key one notch.
05-24-2000, 07:29 AM | #6 |
Member#: 677
One more thing, I believe you don't need to bleed the master cylinder, just the 4 other.
Brake vibration gone after pad change | leecea | Brakes, Steering & Suspension | 2 | 08-19-2005 09:06 AM |
What noises are NORMAL after Turboback install? | henzly23 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 08-17-2004 04:56 PM |
Please help, brake light on after DRL disconnect. | Family Guy | Electrical & Lighting | 5 | 07-15-2004 07:09 PM |
Help with exhaust leak after uppipe install | formulator | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 09-26-2002 08:31 AM |
Please help! Brakes dont work after spring install | cvcsmkr | Brakes, Steering & Suspension | 4 | 01-19-2002 03:05 PM |
