Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 05-10-2004, 11:31 AM   #1
STI-C-YA
Member#: 56825
2003 STI
Silver/Gold/Euroversion
Default Slick Tires In Racing
Hi everyone!
I have this question. I'm racing my Sti in the circuit track every 45 days and I want to use slick tires for that. Someone told me that slick tires may damage the drive train of my car due to the amount of pressure that the car puts in it. I want to know if this is true because I also use my car for daily drivig and I dont want to damage it. Thanks
STI-C-YA is offline   Reply With Quote
Old 05-10-2004, 11:47 AM   #2
jmott
Member#: 6713
2007 Prius
brown
Default Re: Slick Tires In Racing
Originally posted by STI-C-YA
Hi everyone!
track driving puts a whole lot of abuse on your car and may damage it, race tires or not.
however, the STI can put up with extremely sticky tires, that would be the last of my concerns.
a good track tire is the Kumho Victoracer. If you want to step up to something better and more expensive, then try the hoosier road race DOT tires. (R3S04s? I think they are called)
neither of these are techinically 'slicks' (they have token grooves), but most track day guys run tires like these.
jmott is offline   Reply With Quote
Old 05-10-2004, 02:42 PM   #3
STI-C-YA
Member#: 56825
2003 STI
Default Re: Re: Slick Tires In Racing
Thanks a lot for your advise. I will like to know wich things I need to check after each race to try to keep the car in optimum conditions. Thanks
Old 05-10-2004, 03:35 PM   #4
jmott
Member#: 6713
2007 Prius
brown
Default Re: Re: Re: Slick Tires In Racing
brake pads
brake rotors
might want to step up to a good DOT4 brake fluid, might change your tranny and diff oil more often.
be sure to run high quality gasoline at the track, watch engine temps and such. If you can buy 100+ octane gas at the track it wouldn't be a bad idea.
Don't do too many hard laps in a row.
Old 05-10-2004, 04:01 PM   #5
STI-C-YA
Member#: 56825
2003 STI
Thanks again. Actually I'm using Motul DOT 4 brake fluid, Red Line's Water Wetter along with a Crucial Racing Thermostat and 98 Octane Gas. I also have my Camber set to -1. What I been having are high raises in the preasure of the tires, sometimes more than 10 pounds. I heard someone said that inflating them with nitrogen will reduce this. Is it true?
Old 05-10-2004, 09:54 PM   #6
jmott
Member#: 6713
2007 Prius
brown
you can crank the camber all the way to -2.5 or so if you want =)
Old 05-10-2004, 10:09 PM   #7
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
The pressure raising in tires comes from moisture in the air thats in the tires, filling them with an inert gas like nitrogen instead will get rid of the pressure fluxuation dramatically.
afpdl is offline   Reply With Quote
Old 05-10-2004, 10:13 PM   #8
D_REX
Member#: 8945
MY02 WRX
PV = nRT
This s the ideal gas law, if temperature increases so will the product of pressure and volume.
I'm trying to figure out how moisture would effect the pressure rise due to temperature. I'm really not very clear on it. You have any links to info?
Thanks,
Dustin
D_REX is offline   Reply With Quote
Old 05-10-2004, 10:33 PM   #9
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
yep not moisture, just the good ole PV=nRT, nitrogen (a major component of breathable air, ~70%) is more temperature stable than oxygen (IIRC).
Do a few laps, your tires will heat up to operating temp and then adjust pressures. They will stay (or at least stay close) to that pressure when the tires are hot for subsequent laps.
TyrannoSullyRex is online now   Reply With Quote
Old 05-10-2004, 10:57 PM   #10
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
If you have moisture in your tires some of it will be in liquid form as small droplets on the inside of the tire for normal driving. Hard driving will heat these droplets into vapor, which makes a huge difference in the pressure in the tires. If you fill your tires at a typical gas station air line you can usually see water droplets coming out of the line when you start the air flowing. That water in your tires causes the pressure build up.
speedyHAM is offline   Reply With Quote
Old 05-11-2004, 09:05 AM   #11
D_REX
Member#: 8945
MY02 WRX
This is the part that's not so clear. Water droplets represent a reduction in volume, water is essentially noncompressible at these pressures. When in turns to vapor you trade off that volume reduction for an increase in the n term of the ideal gas law. So does this produce a net increase in pressure???? And if so is it greater than the increase due to just the temperature change???
Old 05-11-2004, 03:45 PM   #12
jprowland
Member#: 7298
2008 STI Black
2002 WRX Wagon White
Speedyham has the right of it...Rule of thumb #1 for thermodynamics, air is not an ideal gas and does not behave according to the ideal gas law (my professor used to mark problems with air wrong if we used the ideal gas law!) Too many impurities, like moisture which expands faster than gas when heated. That's why something like pure nitrogen works better...
JP Rowland jeremyrowland -at- mac.com
Co-Driver, Wazoo Racing Subaru WRX, PGT
http://homepage.mac.com/jeremyrowland
jprowland is offline   Reply With Quote
Old 05-11-2004, 03:54 PM   #13
D_REX
Member#: 8945
MY02 WRX
So, how different is dry air than nitrogen? Dry air is much easier to get than nitrogen.
Old 05-11-2004, 05:46 PM   #14
STI-C-YA
Member#: 56825
2003 STI
This gets more interesting with every reply
Old 05-11-2004, 10:45 PM   #15
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
With dry air, I have to work very, very hard to see much pressure increase. Like 10 laps per pound of increase.
Nitrogen may be better, but you have to be running stints longer than a sprint race to find out.
hillman is offline   Reply With Quote
Used (cheap) DOT race tires in Cent FL Oceanus South East Region Forum 14 03-18-2008 06:12 AM
Wood bridge + rain + slick tires Howl Off-Topic 15 09-22-2007 02:39 PM
racing slick tires adofly Motorsports 11 07-19-2007 01:49 AM
Attn: Luke - Help with Slick Tire Sizing zoomfactor Tire & Wheel 2 09-11-2005 09:11 PM
How do I scrub/break in race tires? N8S_WRX Brakes, Steering & Suspension 4 10-11-2001 07:33 PM
