Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-07-2000, 02:20 PM   #1
the spacecowboy
Member#: 765
Post turbo ?'s, oil ?'s, trans. ?'s, etc...
to start off im looking forward in running a turbo as soon as i can find a all in one kit for a cheap price....
to start off if i run a turbo, do i have to run the intake and/or exhaust that comes with the kit?...or can i run my own setup?
What kits are available and what do they comes with them? which is the best for the money?
next, i heard that you shouldnt change the oil in your transmission so soon.....is this true? and if not when should i change it? what kind of oil should i run?
thanks,
ThE sPaCeCoWbOy
the spacecowboy is offline
Old 08-08-2000, 06:00 AM   #2
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Post
with the turbo intake/exhaust, im thinking that you need to run the intake that comes with the kit, or modify another intake to work with the kit. you can run any exhuast you want, but make sure its sized properly. why would you want to run a different intake?
what turbo kits are available? try a search for that one. minnam, jc sports... and rallispec and someone else is coming out with one.
check your manual or the SOA homepage for the recommended maint schedule for when you should change your tranny oil.
dunno if i helped much
boomer
BoomerRS is offline
Old 08-08-2000, 09:58 AM   #3
the spacecowboy
Member#: 765
Post
i wanted to try running a round k&n filter
(the kind that has the chorme top and is about 8inches in diameter) rather than the intake tubes with the k&n cone filter on the end.....
anybody knows if this would work?
space
Old 08-08-2000, 03:09 PM   #4
Andre Vandenberg
Member#: 501
1998 2.? RS Turbo ;)
RBP
Post
Hi there,
I am running a K&N round filter that came with a turn 3 cold air intake system on my Minnam Stage II kit. The only Down side to doing this, is the car now sounds like a wheezer for air at idle, but performs much better at higher RPM (acording to butt Dyno). Anything is possible..... It's just in how inventive and artistic YOU are, in making the brackets and adaptors...
Andre
Andre Vandenberg is offline
Old 08-08-2000, 07:28 PM   #5
the spacecowboy
Member#: 765
Post
andre...
do you have any pictures?
what all did you do and how did you make it?
where did you run your breather tubes at?
thanks,
space
2005 wrx trans. ?'s faststiwagon Newbies & FAQs 1 12-05-2007 06:43 PM
FS: turbo, I/C, trans, seats, etc... couldnthinkaone TXIC Private Classifieds 13 07-06-2006 07:00 PM
Best gear oil and trans oil victory by design Service & Maintenance 19 04-28-2006 09:42 PM
FS: Complete Motor/trans/diff/etc. 03wrx set-up 13brewtt Texas Impreza Club Forum -- TXIC 17 07-11-2003 05:41 PM
Complete Motor/trans/diff/etc. 03wrx set-up 13brewtt Car Part Reviews 2 07-11-2003 05:25 PM
