Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 05-10-2004, 12:33 PM   #1
Sexymama
Member#: 23361
1989 dl
white
Unhappy help me
something is wrong with ym dl
i think the altnater belt is loose or powersteering belt it squels when i crank her and also i think my starter is going
help me
Sexymama is offline   Reply With Quote
Old 05-10-2004, 02:21 PM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Ummm "ym dl" Your DL wagon/sedan??
If the belt is loose and squealing its needing to be tightened. Tossing a new belt/belts on there from your dealer couldnt hurt, if its on a DL its not hard at all. On the alternator, there should be 2 bolts holding it on. Oh yes, disconnect the battery FIRST!
Loosen up both the bolts on the alternator and swing it down toward the engine. This should loosen up the belts. Then slide the first one off (you may need to wiggle them a bit). Then slide the back one (if there is one) to where the front one was, then all the way off.
Reinstall new belts and make sure your power steering pump (up on top in the center) is full of ATF. It it comes up low, fill it til its full.
Why do you think the starter is going? the car has little cranking power? or does it just <click> sometimes? More info needed there.
Flowmastered87GL is online now   Reply With Quote
Old 05-10-2004, 11:03 PM   #3
JWX
Member#: 28990
why do you have to disconnect the battery just to tighten a belt? and ya what makes you think your starter is going out
JWX is offline   Reply With Quote
Old 05-11-2004, 03:38 PM   #4
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
You ever had sparks fly when you put a wrench in the wrong place?? Its better to be safe
Old 05-11-2004, 04:56 PM   #5
JWX
Member#: 28990
what did you do place it on the battery? theres onlt one place on the alt to mess up like that and that should be covered. but you are right better safe than sorry.
Old 05-11-2004, 11:35 PM   #6
Sexymama
Member#: 23361
1989 dl
white
yeah it just clicks some times that is all it does
Old 05-12-2004, 01:07 AM   #7
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
I have run into that with 3 of my 5 subarus.. only once did it turn out to be a bad starter.. all the other times it was corroded battery posts/cables.. this past time they were so bad I had to get a new set of cables.
Calebz is offline   Reply With Quote
Aaargh! Help me Neek! Help me Tom Cruise! banman Off-Topic 16 09-08-2006 01:50 AM
Help Me, Help Me, Help Me! againstdan Newbies & FAQs 9 11-11-2005 10:26 PM
I need to get a sound clip from ATHF... help me Obi W... I mean help me OT! Asinine Off-Topic 7 03-03-2005 12:33 PM
Help Me! Help Me Please! wrxxxappeal Factory 2.0L Turbo Powertrain 8 05-10-2003 11:14 AM
Help me/Help YOu/Help ME MichiganRS General Forum Archive 7 12-15-2000 08:54 AM
Message Board Statistics All times are GMT -4. The time now is 09:21 PM.
