Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-08-2000, 06:55 PM   #1
scoobysport
Member#: 1671
'16 WRX Sport
Question Whiteline end links (torque wrench)
Recently I installed the adjustable whiteline rear sway bar with the polyurethane bushings and end links. I want to know if I should use a torque wrench with a specified torque when tightening the end links. The reason I am asking is because a day after the installation, one of the end link bushings (the one's that look like an hour glass) developed a crack. I am not sure if it is all the way through, but I noticed it. Also, because this bushing is sandwiched between two fairly large washers, should I be driving my car, or should I go back to stock until my new end links arrive? (It hasn't gotten any bigger and still handles like stink)
P.S. It is the top bushing, the one that the sway bar is attached to.
[This message has been edited by scoobysport (edited August 08, 2000).]
scoobysport is offline
Old 08-08-2000, 07:03 PM   #2
BG5
Member#: 695
Post
it was too tight, despite what the included instructions say, you are suppose to tighten only to the point where the bar makes contact with the bush (so no play in the bolt) and no further... I had to replace the bushing spacer and all the hardware on my links after learning the hard way...
BG5 is offline
End link torque spec - Perrin Aaron B Brakes, Steering & Suspension 2 03-24-2005 10:34 PM
RSB and end link torque specs? Topshelf Brakes, Steering & Suspension 2 03-24-2005 06:40 PM
Quick whiteline end link Q RED WORKS(WRX) Brakes, Steering & Suspension 7 02-28-2003 01:21 PM
Whiteline end links and ALK ryball Bay Area Impreza Club Forum -- BAIC 6 01-25-2002 04:27 PM
Whiteline end links did not fit! 240se Legacy Forum 5 07-03-2001 10:34 AM
