Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 04-24-2000, 07:51 PM   #1
Rimmie
Member#: 1350
Question Painting Sideskirts:
This week i took my sideskirts to a respectable paint shop in town to get an estimate, and he recommended that i not paint them because of bonding problems. Is this true?? Most mouldings on cars are made of plastic anyway. How much should i expect to pay to have both painted??
Rimmie
Rimmie is offline
Old 04-24-2000, 09:23 PM   #2
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
Post
it is possible to paint the sideskirts..the only thing to it is to scuff the sideskirts so that the paint can bond to it..see if your subaru dealer will do it for u..they offered to do mine for $200 canadian..good luck =)
MixeD_MenacE is offline
Old 04-25-2000, 08:20 AM   #3
Rick Buckner
Member#: 320
1999 Impreza 2.5
Silverthorn
Post
It has been quite a few months that I had mine painted but I think it was like 175.
Rick
http://roads.to/ricksrides
Rick Buckner is offline
Old 04-25-2000, 09:15 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
Post
I just dropped off my side skirts, rear skirts, fog light covers, and the orange covers from the front dam (below the turn signals) to get painted for $310. This includes a dip to remove wax/grease and flex agents in the paint to bond it to the plastic. They had no problem painting that stuff, and this place is well known in Ventura. YMMV.
Julian is offline
Old 04-26-2000, 09:34 PM   #5
Snyder2.5
Member#: 520
1999 Impreza RS
Post
I was told by my guy that he couldnt paint them either. He said that if I took fiberglass fabric and laid the fiberglass over the skirts that it would be enought to bond to. He said the skirts were made of some nylon material that would flake in a month or two. Is that what you heard or did he just not want to do it?
Thanks
Snyder
New Age Motorsports
Snyder2.5 is offline
Old 04-27-2000, 02:56 AM   #6
Pinoy
Member#: 400
1990 300ZXTT
Post
I had mine done. Cost is $100. They used some material called FLEX or something to that extent. Its been on my car for over a year now and is still as shiny as the day they were painted. No flakes or scratches.
Kenneth
Pinoy is offline
Old 04-28-2000, 10:35 AM   #7
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
Thumbs up
I had my side skirts and fog light shrouds painted by Maaco almost a year ago for less than $100. The color match was perfect, I have a guarantee, and have yet to see a chip or a scratch.
Pete Holt is offline
Old 09-05-2000, 03:43 PM   #8
Swivel1000
Member#: 1168
2004 Jeep Grand
Cherokee Limited 4x4
Post
Do i need to get mine sanded?
matt
Swivel1000 is offline
Old 09-05-2000, 04:34 PM   #9
Boom
Member#: 1101
04 STi
like theres a choice BLUE
Post
The body shop was lying to you, I work at a body shop and there is nothing that paint won't stick to without proper prepping,I painted my own, all I did was sand the black plastic until there was NO shine its really important that you sand the snot out of the plastic, thats what the paint will stick to. You don't need to sand the plastic flat, you know all the roughness in the plastic (thats what the primer will do) but just sand until all the plastic looks cloudy (white) then I primed them with cheap primer, sanded the primer flat (this will determine how flat the paint looks on top of the primer, the flater the primer the shinyer the paint will be. then painted them with base coat/clear coat (thats the type of paint used in the factory) I haven't had a problem with them flaking or chipping, though chipping will eventually occur because of how much abuse they take. The wheels spit rocks right into them. But over time, just get them painted again its easy. Any body shop should be able to do it for around 100 bucks at most. Good luck.
Steve
Boom is offline
Old 09-05-2000, 07:04 PM   #10
ballistic
Member#: 2163
Exclamation
Steve is correct from my experiance as a painter i have found that plastic can be one of the better materials to paint BUT! you must prep the serface properly and it must be cleaned with a solvent to remove all the wax, oil, ect. if you dont the flex additive and sanding will do nothing for you Dan
ballistic is offline
Old 09-05-2000, 08:23 PM   #11
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
I read on Mike Moffa's site that he paid $250 to get his done. Apparently a little high accourding to this board. I would not go back to that guy. He obviouly dosn't want to do it, and if you confonted him, he would probably do it, but do a bad/lazy job.
Hit up the local mom&pop shops and find an old coot that know what he's doing. Oh and get some mud flaps to protect those babies, especially if you like to dirt/rally race.
ChosenWon is offline
Old 09-06-2000, 08:24 AM   #12
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Post
i did my side skirts with boom... if possible, do all the prep work yourself including the sanding and priming, and just have them paint them. see if you can find a shop that will do this. and boom forgot to mention, before you prime them wipe them down with a solvent to clean it... i forget what we used.
BoomerRS is offline
Old 09-06-2000, 10:13 PM   #13
markus
Member#: 438
2004 STi
White on Gold
Post
ChosenWon,
Keep in mind that Mike Moffa is probably giving the price in Canadian dollars, which at C$250 converts to something close to US$165.
markus is offline
Old 09-06-2000, 11:23 PM   #14
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
Post
My other car is a saturn. The whole car is plastic. I never had any paint problems. I was told if I had to get it painted to make sure they use the proper flex agent. I'm sure the same goes for the side skirts. You may want to ask your respectable paint shop if they have ever painted a saturn.
Kcz is offline
tailight paint DCsubieSTI Interior & Exterior Modification 3 06-01-2010 11:39 PM
painting my sideskirts: Need a painters advice designfate Interior & Exterior Modification 3 10-01-2007 03:44 AM
Painted Sideskirts: Have them painted or buy pre-painted? jamapor Interior & Exterior Modification 16 02-02-2007 07:31 PM
Silver OEM sideskirts: $190 shipped slvrwgn Private 'For Sale' Classifieds 8 09-13-2003 04:52 PM
Painted sideskirts: what about these pieces? DragII Interior & Exterior Modification 16 05-15-2003 03:58 PM
