Old 05-11-2004, 11:09 AM   #1
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Default EGT Probe in Turbo cars
Why does Autometer recommend installing the EGT probe 1-2 inches from the turbo inlet and 1-2 inches from the headers for NA cars?....
Why the difference?.
maxiav is offline   Reply With Quote
Old 05-11-2004, 02:39 PM   #2
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
this is where all of the exhaust gases "come together". You will have the most accurate readings if you put it in this location. If you put it too close to the headers the exhaust doesn't have time to mix and you might get a false reading due to the egt picking up only one of the header exhaust stream. does that make sense?
Pi7467mp is offline   Reply With Quote
Old 05-11-2004, 03:39 PM   #3
maxiav
Member#: 40413
2001 BRP RS-T EJ257
makes sense, but at the same time, it makes more sense to have it closer to the headers....
anybody else????
Old 05-11-2004, 04:05 PM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
how does it make sense if this is true?
Goober
benjaminetanyahoo is offline   Reply With Quote
Old 05-11-2004, 10:15 PM   #5
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
People put it near the #3 cylinder because that one runs the hottest. The other cylinders run cooler than that so if you put it in the #3 runner you will be safest.
Drac9 is offline   Reply With Quote
Old 05-11-2004, 10:21 PM   #6
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
That is the conventional wisdom, but most people seem to melt #4 piston when they go...
yamarocket630 is offline   Reply With Quote
Old 05-11-2004, 10:58 PM   #7
maxiav
Member#: 40413
2001 BRP RS-T EJ257
number 4 it is then
Old 05-12-2004, 12:06 AM   #8
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
or you could do the parallel fuel rail mod, and put it where it is supposed to go.. or you could spend about 1000 and get an egt computer that tells you what the egt is for each cylinder., this way you know exactly what is going on in the motor..
Old 05-13-2004, 05:18 PM   #9
maxiav
Member#: 40413
2001 BRP RS-T EJ257
k.... now Im confused.....
3....?
4..???
Old 05-13-2004, 05:36 PM   #10
kaos200
Member#: 2692
If you do the parallel mod, put it in 3
if you keep the fuel lines stock, 4
kaos200 is offline   Reply With Quote
Old 05-13-2004, 07:19 PM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
i second that
akcel is offline   Reply With Quote
Old 05-14-2004, 08:17 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I did man by number 4...just about 3 inches down stream...
Old 05-14-2004, 09:32 AM   #13
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Thanks! I tried drilling yesterday without taking the headers off.... .... that never happened. Guess Im gonna have to go to a midas or something.
Old 05-14-2004, 09:46 AM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
take the piece to a machine shop, i dont know much but i do know i would NOT drill+tap w/ it on the car too many options for problems, theres no way ur gonna be able to clean it that well so just pull it, drill+tap and pour like paint thinner all over it to get some of the dust out or brake cleaner
Old 05-14-2004, 01:30 PM   #15
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Going to a midas tomorrow. Car is not turboed yet so I'll just let the pieces fly through the exhaust.
Thanks for the help #4 it is
EGT probe in TurboXS Downpipe 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-01-2002 01:32 PM
Anybody Local with EGT probe in Manifold? jamz New England Impreza Club Forum -- NESIC 3 02-08-2002 11:17 AM
('93-'01) Can't find anyone to install EGT probe in KC. viodea Impreza Forum 23 10-17-2001 08:03 AM
finally got my EGT probe in RidinLow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-07-2001 03:37 PM
Placing EGT probe behind turbo Tim Prudence Technical Forum Archive 7 05-27-2000 06:42 PM
