Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 05-11-2004, 02:50 PM   #1
mikaust
Member#: 7468
Default slight bucking 4th gear pull
On a 4th gear pull ( it does not do it in 1st,2nd,or 3rd) starting at 4000 once it gets around 5300 there is a bucking sensation no flashing cel (utec) but yet it feels like timing being pulled. We changed the vacuum lines and boost controller. It holds boost fine 1.8 down to 1.6 at redline. Plugs are new and gap is 28. Changed maf and it reads 4.5. Where do I go from here? I have a version 7 long block sitting there. What about using the coils from that? Could they be the problem? I do get misfire codes, but not often. Thanks in advance Michael
mikaust is offline   Reply With Quote
Old 05-11-2004, 04:49 PM   #2
mikaust
Member#: 7468
just pulled the codes, misfires in all cylinders and cam position sensor.
Old 05-11-2004, 08:19 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Maybe you could get a bigger maf pipe to make the reading lower? What kinda gas are you using? What kinda engine/turbo? You're running a lot of boost huh? How much power does that thing put down?
Old 05-11-2004, 10:49 PM   #4
mikaust
Member#: 7468
stock 2.0 block and heads, FP 18g turbo and c-16. dynoed at 364 whp so far the highest trap is 117.88
Old 05-12-2004, 01:21 PM   #5
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.7 @ 102, '09 spec.B
dyno'ed 364 on a TXS topmount... he is currently running their frontmount... which SHOULD be good for, what, another 20 whp?
def
dug-e-fresh is offline   Reply With Quote
Adviced Needed: 07 USDM STi Stg2 Master Map 4th Gear Pull Linkseal Open Source Reflashes 15 08-14-2009 12:55 PM
Fuel cut at 4900rpms in 4th gear hard pull MRF582 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 09-19-2007 01:03 PM
Videos posted to my site: Launch, 4th gear pull etc... TurboQueef Proven Power Bragging 41 10-04-2006 07:19 PM
4th gear pull/Cobb vf34 93 oct dcdub23 AccessPort 4 04-28-2006 07:36 PM
overseas dyno differences: 3rd vs. 4th gear pulls annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-25-2002 04:53 PM
